Question about IBM Infoprint 1120 Laser Printer
Infoprint 1120 printer
How do i get the printer settings for my printer because i can not find the cd to set up my printer.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • IBM Master
  • 1,362 Answers
If you are doing it as a local printer ( parralel cable or USB it can be done through Start, Settings, Printers and faxes, Add a printer.
Network is different.
You have to assign or let it get an IP address from the network.
You can enter it manually in the printer
Hit the left arrow to
Network menu
hit select
Standard net setup
hit select
Print ( to print out the network settings)
scroll to TCP/IP
select
enter IP manually by scrolling to each number and hitting select
Posted on Oct 18, 2007
SOURCE:
Need print driver for ibm 1120 using win 7 64 bit
You can download the BM InfoPrint 1xxx AIX Print Driver from the IBM support WEB site. Please click on this link and select your model printer to download :- http://www-01.ibm.com/support/docview.wss?rs=95&context=SRATEW&dc=D400&uid=psd1P4000313&loc=en_US&cs=utf-8&lang=en
Dec 12, 2012 | IBM Infoprint 1120 Laser Printer
How to reset an InforPrint 1120 printer
Just switch Off the Power and wait for 1 minite. this method will reset most printers
Jan 17, 2011 | IBM Infoprint 1120 Laser Printer
Need driver software for Printer Installation, where can I find?
you can download a copy for your IBM infoprint 1120 laser printer from here
Click here to Download
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
Manish
Jan 27, 2010 | IBM Infoprint 1120 Laser Printer
Infoprint 1512 prints blanks from int. and ext. print source
How to get on software to setup for printer , infoprinter 1512 ( Ibm ) .
tha for kind wondows ( wondows vista )
Aug 14, 2009 | IBM Infoprint 1512 Laser Printer
Paper tray is in the printer,but the printer says missing tray 1
There are two possible solutions: The first is that the lugs on the side of the paper tray are broken, and the printer cannot "see" a paper tray. In this case you need a new paper tray. The other possibility is that the tray and paper size sensor inside the printer is faulty. Often just pushing the contacts can free them, and sometimes the metal prongs that sense the lugs on the side of the paper tray get unseated. Just use your finger to reseat them correctly. If that doesn't work, the sensor board is likely to have failed, and will need replacing
Jun 11, 2009 | IBM Infoprint 1120 Laser Printer
IBM INFOPRINT 1120 Invalid Engine COde
Invalid engine code --- is a bad engine board - located on the LHS of the printer behind the formatter board
Nov 04, 2008 | IBM Infoprint 1120 Laser Printer
IBM infoprinter operating manual
You should be able to find it in the support section of this page: http://www-07.ibm.com/printers/sg/products/workgrp_laser/info1125.html
Aug 04, 2008 | IBM Infoprint 1120 Laser Printer
Infoprint 1120 929 service toner sensor error code
The problem is caused by one of the following (normally it's the cartridge that's faulty, very common on Lexmark's and IBM Infoprints)
The toner sensor is not operating properly, the developer
drive assembly is not operating properly or the print
cartridge is defective
Jun 09, 2008 | IBM Infoprint 1120 Laser Printer
Invalid Engine Code
This is actually a Lexmark printer, so what I'm quoting is a Lexmark sol.
turn off machine
hold down returnand go buttons
turn on printer
hold  until performing test shows and let go of buttons
it will go to a service mode ( instead of saying ready)
got to printer set up
hit select button
go to engine 1,2 or 3
try each one ( hit select to go into that perticular number)
what you are looking for is a number that has an * next to it. Use the arrow keys to scroll. most likely it changed the setting so go and look for that number w/the * and hit select when you see it.
Sep 26, 2007 | IBM Infoprint 1120 Laser Printer
IBM INFOPRINT 1120
Julie1665, Here are some things that could be causing your problem: -Could be the paper you are printing does not meet the printer specifications. -Could be toner leaking out of the cartridge. -Could be environmental issues, too hot or cold or humid. -The toner density could be set too high. -The electrical contacts that connect the toner cartridge to the printer could be dirty or just not making good contact. -the printer power supply could be defective. -With regards to your toner cartridge are you using new IBM cartridges or refilled/remanufactured? I?ve had many customers call me to fix a printer problem that turned out to be a bad cartridge. All of these are within the capabilities of the typical user except changing the power supply. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 22, 2007 | IBM Infoprint 1120 Laser Printer
IBM Infoprint 1120 Laser Printer Logo
173 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
