Question about Toshiba 36AFX61 36" TV
Toshibe 36AFX61 36" TV
Good day, I recently encounterd a problem with the 36AFX61. While viewing a program, I went to change the channel using the cable remote and the TV set just shut it self down. I turned it back on however, no picture or sound is present. I'm also unable to change channels using the TV or cable remote. I thought the TV had gone bad however, I'm able to view channels using the Picture In Picture feature. This confirms that the TV is receiving the signal and working properly. It seems that I can't change the settings from PIP to Main. i've looked through the manual as well but nothing helpful regarding what I'm experiencing. I may have hit a feature on the cable remote by error. No luck with that as yet. I even unplugged the TV for a while and plugged back in with no change. Here is the link to the manual: Any help/tips would be greatly appreciated. Thank you all in advance.
I uncovered the problem. The "analog tuner" seems to have gone bad. The part is $25 -$36. The set can still be used however. I just removed the coaxial cable from ANT 1 in the back of the TV (this is what I believe has become defective)which was going to a VCR. I then just used composite cables(red,white,yellow)to bring the signal directly to the TV from the cable box, rather than the VCR. All works however, will replace the defective part.
Posted on Sep 20, 2007
I cannot change the channel on Westinghouse TV. Model SK-19H2105 - Tried to do the fix mentioned for channel scan - cannot find the channel scan.
Press the “Menu” button on your remote or the side panel to access the On Screen Display
—Use the right/left arrow buttons to scroll across to the “Setup” menu
—Use the up/down arrow keys to select “TV” and “Quick Setup”
• Use the arrow keys to select your “Time Zone”, which allows you to receive
proper HDTV programming information
• Continue with arrow keys to select your signal source “Air/Cable/IRC/HRC”
—If you use a rooftop or indoor antenna, select “Air”
—If you use a cable service, select “Cable,” “IRC” or “HRC” (depending on the frequency
used by your cable service)
—Press the left arrow key to start scanning for channel
Aug 16, 2016 | Westinghouse Televison & Video
Why did my sanyo 19" hdtv all of sudden went black? what to do now?
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Aug 12, 2014 | Sanyo DP19647 19 in. LCD TV
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
Parental Control Menu
Lock Enable
Change Code
Main Menu
Parental Control
Channel Setup
Press Right to Enter
Press New Code
Off On
TV Rating
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Impossible to change channels, turn TV on, Power and Opc blinking
go into programming mode and search for channels   it will do this automatically to find all antennae and all cable channels    if this is hooked up to a receiver box then only channel 3 will be found or used    also most tvs are computerized these days and at times it will need to 'rebooted'     unplug the power and wait 10 seconds and plug it in again    this may have to be done whenever you are locked out from changing channels or using the volume controls
Nov 05, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Recorded programs in english come out in Spanish
Make sure your TV hasn't been set for SAP (you'll find it in the audio settings menu). Second audio programming is often used to carry alternate languages, and if it's turned on you won't know it until you watch a program where it's being used. There may be a single button labeled SAP on the remote. If so, it's easy to change the TV setting without realizing it.
Feb 06, 2009 | JVC AV27F476 27" TV
Tuning video programs
I have solved the recent problem myself. I simply retuned the Menu option on channel * and then stored the channel into the TV
Feb 04, 2009 | RCA 32F531T 32" TV
Sanyo tv channel stuck
A POSSIBLE solution. I have the same it used, but it's in good condition.
It was stuck on a channel. I went iinto the menu and fiddled with the channel programs and "deleted" the channel and now I can freely change channels.
By the way, I could use a manual for this one?
Nov 08, 2008 | Sanyo DS27590 TV
Will only record 1 channel
hello..please refere to your user manual...and choose the chapter of installing can use "autostore" and when search is finished and can sort your channels to the correct program position.......please tell me how it went...good luck...Ron
Mar 07, 2008 | LG DR275 Recorder
Some channels not programable
Bad tuner = verify part # from back of set to get part #...
Let me know..........................T.
Nov 22, 2007 | JVC AV-27D303 27" TV
Toshiba 36AFX61 36" TV Logo
100 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
