Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Change tire I can't get the pin out of the rim so that I can change a tire. How can I get it out? The model is an LT1080 Hydraulic
  • COUGHY_MAN May 11, 2010
    DO YOU MEAN LT1050?
    Dedicated:
    Visited the website for 20 consecutive days.
  • Cub Cadet Expert
  • 242 Answers
I am going to assume that you cant get the wheel slid off the axle shaft. Your best bet is to remove the tire from the wheel with it still on the tractor. The same way they do farm tractors.I put the rear of the mower on a concrete block and use two screw drivers to remove the tires on the mower. What ever you do do not beat on the inside of the wheel with a big hammer with hopes of driving the wheel off the axle shaft. The axle shaft is held in with a paper thin C clip that will let go and the axle will slide out. Then the transaxle will have to be removed and disassembled to put a new one on.
Posted on May 21, 2009
Will 17" rim fit 19" rim like some models have
When changing rim sizes, you need to manage the "height" of the tire to compensate. Usually folks are shifting to larger rims so to keep the circumference the same, a lower profile tire is used. If you are going from 19s to 17s, you will need a much "taller" tire. I believe Tire Rack has a calculator that can help with tire selection. Tire Tech Information Tire Size Conversion Chart
Dec 29, 2014 | Cars & Trucks
Tire size
Yes as long as u change the rims also not just the tires these numbers 195/60/15 195 is tire width 60 is tire height and 15 is rim size, most all Hondas will fit up to 215/35/18 with no rubbing issues on factory suspension ..... Every time the rim size changes u have change the height of the tire so it will fit some go as far as " stretching " the tire to allow larger rims or extreme offsets
Jan 28, 2014 | 2005 Honda Civic
Change tire kawasaki mule
Jeff:
Those tires and rims on the Kawasaki mule are extremely hard to change! To break the bead I use an impact hammer (metal tube with heavy rod going through it.) I have used a long pry bar or long crow bar. Step on the tire next to the rim and squirt a soap solution between the rim and the tire bead... do this all the way around the tire. Set the crow bar upright on the tire next to the rim and a couple of good hits on the top end of the crow bar should give you a little room between the tire bead and the rim.Just get a little room between the rim and tire bead, slip the crowbar between the rim and tire bead letting the other end of the crow bar rest on a piece of wood, and smack the crow bar next to the rim with a sledge hammer. Don't hit the rim!!! You can lay a short piece of two by four on top of the end of the crow bar to give you a better target. You'll need to do this around the circumference of the tire until the bead is broken all the way around the tire. Again, Don't damage the rim!! Take a short break, because you'll need to do the same thing for the other side of the tire!
Break's over... Lay the tire with the short lobe of the rim up, (the deep side of the rim down), and use your crow bar to lever the tire bead over the rim. The side of the tire you're not prying on should sit in the valley between the bead lobes. use another tool (long screwdriver or such to keep the tire from slipping back down over the rim. keep levering the tire off of the rim. Do the same for the other tire bead making sure the other side of the tire stays in the valley between the bead lobes. Installing the new tire is just the opposite of removing the old one. Don't be afraid of using the soap solution to install the new tire, and be careful not to damage the bead area of the tire (The bead is where the tire touches the rim, and any damage there will cause an air leak). You'll get a workout doing this job!!
Nov 30, 2013 | kawasaki Motorcycles
What type of Rim can I buy for cheap for my Volvo?
try your nearest salvage yard or order online dont know where you are im in canada so cant tell you where to go for sure
Dec 11, 2012 | 1989 Volvo 760
Front tire won't come off
Sit on your but and kick the tire with both feet. The tire is stuck. Some tire repairmen use a large sludge hammer and hit the tire,don't hit the rim.
Sep 01, 2012 | 1992 Ford Festiva
Had a flat tire on my GMC Sonoma. Changed the
wheel rim damaged ?? locating pin for wheel not lined up
May 16, 2010 | 1993 Nissan Altima
How do you change a innertube on a back wheel of a mountain bike
You have to remove the entire wheel from the bike. Then change it just like you'd change a front tire... remove oneside of the tire from the rim, pull out bad tube, clean rim, put in new tube, put tire back on rim, inflat tube... good to go. There are 1,000,000 videos on YouTube to show you this process.
Nov 08, 2009 | Bike Extreme Lite Youth Shoulder Pad
I would like to change the front tires lawn mower
Remove the wheel from the mower.
Let all the air out
Lay the tire flat
Push on the tire to release the grasp on the diameter of the rim (use a malet if ou need to)
Apply soapy water to the tire and rim
Insert a standard screwdriver between the tire and rim and pry the tire over the rim in one spot
Then work the screwdriver around the rim, pulling the rest of the tire up and over as you
go
Repeat the last step for the other side of the tire, same side of the rim though!
Viola, there you have it. Shade tree mechanic at it best. And NO labor cost$$$!!!!!
Mar 22, 2009 | Swisher 52" 20 Hp Riding Lawnmower #Zt2052
Rim and tires
Your tires will certainly last longer and your steering may be sharper. Here are the issues (having done this on other cars):
  • cars are generally designed to use one size of tire for a reason...too large a tire is not good in the rain, for example
  • your speedometer/odometer will read wrong
  • there is a possibility of body interference in turns or in full suspension jounce
Assuming you do this: make sure your front end is in good condition and use the same width tire. Your car may have a different model with an oversized tire. Ask your dealer what modifications to address the speedometer issue are available.
Jun 08, 2008 | 1996 Nissan Sentra
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
727 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
