Question about Dryers
My Amana LE8317W2 works for 10-20 minutes then stops. There is a slight burning smell. It wont restart until it cools and when it does restart, it seems to take a lot more energy to get the drum rolli
My Amana LE8317W2 works for 10-20 minutes then stops. There is a slight burning smell. It wont restart until it cools and when it does restart, it seems to take a lot more energy to get the drum rolling. Any ideas?
  • 659 Answers
Make sure your vent is clear of lint from inside the unit and to the termination point outside.
Posted on Apr 18, 2009
I have a Neff multifunction and the microwave part is playing up now, sometimes it stops half way through re heating and then I have to wait a minute or so before I am able to restart. Also there is a...
Is it a plastic burning smell? It sounds like the magnetron is overheating. Can you hear the cooling fan running? Is there anything blocking the vents on the unit?
Feb 03, 2015 | Neff Microwave Ovens
Nav5800aww
The motor sounds like it is overloading and kicking out. Most likely cause: binding brake pads.
Sep 13, 2013 | Amana NAV5800A Top Load Washer
I was using the "dry" cycle and noticed the dryer stopped after 10 minutes. When I opened the door, very light smoky/steamy stuff was coming out the door and there was a slight burning smell. Now, it...
here are two sites, i would say the vent is clogged and that the thermo switch on the motor tripped but I am not an expert, just cheap charlie:
http://www.home-appliance-kitchen-aids.com/dryer-repair.html
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
I prefer the last site, but that's just me. hope this helps Tim
Oct 17, 2010 | Asko T780 Dryer
Amana gas dryer Model #ALG866SWB: When pushing
The motor is bad and needs to be replaced.
Jul 23, 2010 | Amana ALG643RB Gas Dryer
I just bought a used Amana Dryer LEA30aw and when I turn it on it has a slight burnt smell. What could this be?
sometimes youll smell burning lint or dust.let it run 10-15 mins outlet temp should be no more than 160'.smell should go away after a couple of mins.if temp exceeds 160 may need tstat.please rate my solution
Dec 06, 2009 | Amana Dryers
Refrigerator not cooling
You model if the ARB1950C has a defrost timer inside the fresh food compartment and behind the temperature control panel. Need to see if you can manualy turn the timer clockwise until the compressor stops. During that time of 25 minutes the freezer should be in defrost. I believe your timer needs replaced based on how you explained what is happening. The part number for your timer is 67001036 and can be found at the links below. If it stays longer that 25 minutes then it's sticking in the defrost section of the defrost timer and will need to be replaced. If your refrigerator does not restart after about 25 minutes then slowly turn the timer through the opening in the plastic cover. There may be a plug covering the hole to make the hole not so visible. If you should have problems fell free to let me know, Thanks Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Aug 17, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
Burned electrical smell from the freezer compartment
I would check the defrost thermostat usually a button type switch with 2 wires on it mounted to the freezer coil. Size depends on type ; 1 type is about quarter size, 1 is about dime size, and electronic sensor (not had one burn out but the board could smell like your description but I believe these are not in the freezer section).
I have had these cook out and smell up the freezer section before. And if they go out guess what it wont defrost either. If your fan motor goes out it might smell and wont cool all over but the frost should be minimal.
Also a bad defrost heater could make a smelly situation it is usually a black rod or aluminum colored and the rubber ends can burn and make a smell.
If you find its the heater, I would replace the defrost thermostat as well. Its suppose to cut off the heater before it gets too hot.
If this helps you find your problem please rate me as high as possible if not please post back with more information as to what you did find. Thanks for using fix ya and good luck.
Mar 29, 2009 | Kenmore Refrigerators
Smoking washer Amana NAV8800AWW
Ok, that's a different scenario. Generally, when a washer is agitating and develops an overload that stalls or overheats the motor, the problem could be caused by:
1. Too many clothes for the amount of water level selected. If clothes don't have enough water to circulate in properly, it can put excess pressure on the agitator which transfers to the gearcase, drive belt, and finally the motor. The motor is thermally protected and stops running until it cools down, then it will try to restart. In the process the drive belt could burn slightly to completely,so you may want to inspect the drive belt for burned areas.
2. Transmission malfunction, where something inside the transmission breaks due to an overload and jams a gear. End results can be the same as above.
I suspect a clothes overload may have caused the problem and once the overload is alleviated, the washer should operate normlly if the belt didn't burn,
May 27, 2008 | Amana NAV8800E Top Load Washer
Maytag dryer problem
sounds like the motor. if the motor gets too hot then the overload on the motor wont let it come back on until it cools off
Nov 25, 2007 | Dryers
Dryers Logo
202 people viewed this question
Top Dryers Experts
