Question about Samsung SM-352F CD-RW/DVD-ROM (Combo) Burner
I have no sound after uninstalling autodesk. - Samsung SM-352F CD-RW/DVD-ROM (Combo) Burner
  • 702 Answers
Check these steps to solve audio problems in Windows.
Following those steps you should be able to isolate and fix no sound issues.
Posted on Apr 23, 2009
I need to Get the authorization code for this software that my wife got for me in 2002? It's autocad LT 2002 serial #341-88732540. Key#HQZ3U6. Any help would be appreciated. I've tried registering it...
Autodesk AutoCad 2000 serial: 112-11111111
cdkey: 5X8NUG
Autodesk AutoCad 2000 Educational serial: 111-11111111
cdkey: GX8NUG
auth: FFD54A5A
Autodesk AutoCad 2002 Serial #: 400-12345678
cd-key : T4ED6P
Autodesk AutoCad Data Exchange 2000i 400-12345678
Autodesk AutoCAD Land Development Desktop Release 2i s/n: 400-12345678
cd-key: T4ED6P
Autodesk AutoCAD LT 2000 serial: 110-98539662
cdkey: 2ZC3DJ
Autodesk AutoCAD LT 2000i serial: 400-12345678
cd-key: T4ED6P
Autodesk AutoCAD LT 2002 s/n : 400-12345678
cd-key : T4ED6P
Autodesk AutoCAD Map 2000i serial: 400-12345678
cd-key: T4ED6P
Autodesk CAD Overlay 2000 s/n: 110-98539662
cd-key: 2ZC3DJ
AuthCode: 08BB785
Autodesk CAD Overlay 2000i serial: 400-12345678
cd-key: T4ED6P
Autodesk CAD Overlay 2002 serial # : 400-12345678
cd-key : T4ED6P
Autodesk Civil Design Release 2i serial: 400-12345678
cd-key: T4ED6P
Auth : no requiere
Autodesk Civil Design 3.0 serial # : 400-12345678
cd-key : T4ED6P
Autodesk Land Development Desktop Rel. 2 Serial #: 400-12345678
CD-KEY : T4ED6P
Auth : no requiere
Autodesk Land Desktop 3.0 serial # : 400-12345678
cd-key : T4ED6P
Autodesk LightScape name: EzD
company: PWA
s/n: 700-15158000
code: 6A147AF9
Jan 31, 2015 | Autodesk AutoCAD LT 2002...
Unable to initialize adlm
Unable to initialize adlm error after uninstalling Service Pack for 2014...
Solution:
There are 2 solutions available, either of them can help you to resolve the license issue.
Option #1:
Uninstall and reinstall the Service Pack (any of the Service Pack if you have more than one) that you want to keep. This will restore the mismatched file versions to the correct one.
Option #2:
Copy and replace files manually
1. Download the LicenseCrash.zip attachment below, unzip to your local drive, and then unzip the 32-bit or 64-bit package according to your platform.
2. Unzip the package
3. Close all running Autodesk products
4. Stop the FlexNet Licensing Service from the Task Manager:
  • Click Start ? Run
  • Type taskmgr and the Windows Task Manager will open.
  • In the Windows Task Manager, on the Services Tab, right-click FlexNet Licensing Service ? Stop Service.
5. Replace the following 5 files from the unzipped folder into the following locations:
a. Replace adlmact_libFNP.dll and adlmact.dll with the ones (version 11.11.0.3 and 7.0.51.100) in the unzipped folder.
b. Replace adlmint_libFNP.dll and adlmint.dll with the ones (version 11.11.0.3 and 7.0.51.100) in the unzipped folder.
Note: Most products put this file under the root folder of "\Program Files\Autodesk\#Product name#\" i.e. AutoCAD2014, but some other products put this file under subfolder, i.e. Inventor /Alias in \Program Files\Autodesk\#Product name#\Bin folder.
c. Confirm and if necessary replace FNPLicensingService.exe with the one in the unzipped folder to avoid file version incompatible issue.
6. Launch your products.
Mar 20, 2011 | Autodesk AutoCAD 2010
While Removing AutoCad 2006 :FATAL ERROR: Unhandled Delayload "pm8.dll" Module Not Found Exception at 7c81eb33h
This error could be occuring due to the fact that the Application is targetting a dll from an older version.
Uninstall all versions of Revit and Reinstall Revit Architecture 2011 as per the link below:
http://usa.autodesk.com/getdoc/id=TS13712572
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
"Understanding explains better..."
Feb 03, 2011 | Autodesk AutoCAD 2006
I am not able to uninstalled autocad 2006 through Add/remove programs. "Fatal Error while trying to uninstall Autocad 2006.
Reinstall & unistall the programme
or
Use the System restore Utility to restore it to the point before you install the programme.
Hope it helps.
I installed 3ds max 10. when I click modifier list,system hanging, also modifier list not working. then I uninstall max10,re installed max 9. same problem. how to solve this issue.
I installed 3ds max 10. when I click modifier list,system hanging, also modifier list not working. then I uninstall max10,re installed max 9. same problem. how to solve this pls tel me
Nov 21, 2010 | Autodesk 3dStudio Max 9 for PC
AutoCAD 2010 won't start after reinstall.
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCAD-2010-does-not-start.html
Issue:
When you try to start AutoCAD, you briefly see the splash screen and the program does not start.
Solution:
This behaviour can be caused by corrupted license information.
Please check if there are any errors listed in the ACD2010ENGAdlm.log file in the folder:
C:\Documents and Settings\All Users\Application Data\Autodesk\Adlm (Windows XP)
or
C:\ProgramData\Autodesk\ADLM (Windows Vista) (Please note the file name may be slightly different for localized product versions, for example for the German version the file name is ACD2010-DEUAdlm.log)
If the log file shows errors regarding the product information table file, for example "Unable to locate the Product Information Table File" or "Product Information Table file is not found", you will need to:
  1. Uninstall all installed 2010 products
  2. Delete the ADLM folder mentioned above, and
  3. Reinstall the products
Oct 14, 2010 | Autodesk AutoCAD 2010
Fatal error unhandled c00000fdh exception at 30119435h in autocad 2011
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-Error-Unhandled-Access-Violation-Reading-0x0000-Exception-at-bcbdad73h.html
Fatal Error while opening AutoCAD Dec 05 2014
Applies to AutoCAD 2009, AutoCAD 2010, AutoCAD 2011, AutoCAD 2012, AutoCAD 2013, AutoCAD 2014, AutoCAD 2015, AutoCAD Architecture 2009, AutoCAD Architecture 2010, AutoCAD Architecture 2011, AutoCAD Architecture 2012, AutoCAD Architecture 2013, AutoCAD Architecture 2014, AutoCAD Architecture 2015, AutoCAD Civil 3D 2009, ...
See More
Issue:
While in the process of starting AutoCAD , a Fatal Error occurs.
Causes:
Fatal errors usually indicate program corruption or a corruption somewhere within the operating system.
Solution:
There are several ways to address the problem: Note: A fatal error can be caused by DisplayLink Core software. If you have this installed on your system, try uninstalling it and then see if this resolves the issue. Additionally, some antivirus or desktop locking programs can cause errors in AutoCAD as they lock the system environment from working. Your antivirus may even need to be uninstalled.
Sep 16, 2010 | Autodesk AutoCAD 2010
Cant uninstall autocad 2010... the uninstall program from windows does not work
Use your DVD/CD to reinstall and there is a function on the CD to remove the program.
or
You can use the microsoft restore utility to restore to the point before you install the program.
Hope it helps.
Jul 16, 2010 | Autodesk AutoCAD 2010
Samsung SM-352F CD-RW/DVD-ROM (Combo) Burner Logo
43 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
