Question about Kenmore Elite HE4 Electric Dryer
Dryer does not dry
Cycle and controls appear to work normally, except at the end load is still not dry.
  • 10 more comments
  • Hui Jae Sep 18, 2007
    dear barnsleymick: thanks for your input; I omitted one detail that may change your response. Clothes warm up significantly, they're just very damp after a cycle that previously left them crisp dry. thank you.
  • carlazwick Jan 22, 2008
    gas goes on every 90 seconds than it stays on for about 10-12 seconds.. is this normal?? clothes take 2-3 cycles to dry...
  • Anonymous Jan 22, 2008
    i have a McClary dryer. the dryer works but will not produce hot air. i realize that it could be an element or thermostat problem, but the dryer is at least 30 yrs old...where could i find parts that match or can i even???
    also i have a dryer that is about 10 yrs old it won't even produce power, i turn it on and nothing. this dryer is a GE encore. what is my best option?
    p.s how do you open it...there is only a little plate that will come off. just enough room to take motor out at very bottom.
    thanks Bryan
  • Anonymous Jan 24, 2008
  • Miles Pace
    Miles Pace Jun 14, 2008
    i know its the heater element
  • Anonymous Jun 16, 2008
    clothes dont completly dry keep getting E1 code
  • Anonymous Aug 03, 2008
    My dryer stops with an E1 code
  • erknlee Aug 03, 2008
    cycle and controls work normally, no heat to dry clothes. Really haven't taken any steps yet to solve the problem.
  • welcome22 Oct 02, 2008
    clothe dryer does not get hot
  • lezlienelson Dec 14, 2008
    Did you ever get a response ? I am having the same problem and it is VERY frustrating!!!
  • drvanwagoner Jan 24, 2009
    I have the same problem as Guest. Dryer gives an E1 code, heats up but turns itself off while clothes are still damp.
  • Anonymous Feb 21, 2009
    We have the same Kenmore Elite HE4 and it takes 90 minutes to dry a regular load of clothes. I wanted to rule out the vent as the problem so I used an indoor lint vent to troubleshoot. It did not solve the problem.
The suggestion from barnsleymick gave us some good direction in fixing our Kenmore SmartHeat Quiet Pak 9 HE 4. We discovered our vent pipe was clogged with a great deal of lent and a quart or two of water. We cleared the vent of the lent and water and the dryer is now working like a champ! Thanks for the direction.
Posted on Sep 30, 2007
No heat from the dryer at all. McClary dryer. Is there a seperate heat element that needs replacing ar is it a thermostat replacement issue?
Posted on Jan 23, 2009
  • 209 Answers
I am a retired appliance engineer of 20 years this sounds like heater problem check element for open circuit, also there are thermal cut outs to be checked, if these are open circuit the heater will not work, take note of wires etc before removing them, work with safety unplug before testing etc hope i have helped, if so please rate me
Posted on Sep 18, 2007
  • Anonymous Sep 19, 2007
    thank you for the reply, i can only give information back based on information given, normally an engineer such as i was would have ruled that out in a second, working blind can be easy with the right info etc,
    the next thing to try is the ventilation, is the air blowing all the way out at a good force, check any vents, vent pipes, grills, grates, filters & holes, etc for blockages or kinks etc, the drying of clothes is the same in a machine as outside, a sunny hot day with no wind will dry clothes slower than a dry clear windy day,
    it sounds like you are almost there, keep checking, and sorry if i didn't help first time,
6ya staff
SOURCE:
All else appears to be working except the dryness level selection button does not light up and will not allow selection
How do I read the digital display panel and controls on my ...
www.samsung.com/uk/support/skp/faq/1025253
Samsung ElectronicsAug 12, 2014 - The Drying light will illuminate and remain lit until the cycle is ... the indicators will light up until you press the Start/Pause button. ... When you turn on your dryer the Cotton Cupboard Dry cycle is selected by default. ... Drying Level button ... If you do not turn the Drum Light off within 5 minutes of turning it on it ...
Dryer Control Panel And Functions - Samsung
www.samsung.com/ca/support/skp/faq/230147
Samsung ElectronicsJan 7, 2015 - To set Dry Level in the Normal, Heavy Duty, or other Sensor Dry ... An indicator light illuminates next to the selection. ... Temp Selection Button ... When using Manual Dry, you can select the drying time by pressing the Time Selection Button. Important: Clothes may not dry completely if the drying time is not ...
MACHINE OPERATION
docs.whirlpool.eu/_doc/501930002795EN.pdf
Material thickness: whenever there is greater load than the dryer can handle, ... Do nottumble dry: nylon stockings, delicate embroidery, fabrics with metallic ... The indicator lamp above the relevant button lights up to confirm your selection. ... Wait at least 5 minutes, to allow the laundry to cool down, before you unload the ...
501930001546EN.pdfDOWNLOAD
Jan 01, 2016 | Dryers
ALARM
reset the panel by hitting normal-- heat dry NOT at the same time until all lights flash then push cancel and it should start. this resets the controller.
Apr 01, 2014 | Whirlpool 24 in. ADG7540 Built-in...
Error code Ad
Hello Rachael, thank you for your inquiry!
Typically error code AD indicates that the Auto Dry option has been selected. Typically when using no heat in any Auto Dry cycle will result in long drying times and/or wet loads at the end of cycle. I would suggest selecting another option or resetting your dryer. You may either unplug it or flip the household breaker off for approximately ten minutes. Turn your dryer on then select a normal cycle. Your appliance should resume normal operations. If this problem persists, your dryer may possibly have a faulty heating element, blower assembly or a communication problem with the control panel. This is not a normal DIY job. You may want to connect with a local servicer to determine the exact diagnosis. I hope this helps explain the error code you are receiving.
Nov 28, 2013 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire electric dryer error code AD
Hello - Typically error code AD indicates that the Auto Dry option has been selected. Using no heat in any Auto Dry cycle will result in long drying times and/or wet loads at the end of cycle. I would suggest selecting other option or resetting the unit. You may either unplug it or flip the household breaker off for approximately two minutes. Restart unit, select a normal cycle and verify if it will heat. If the dryer does not heat the unit it could possibly have a faulty heating element, blower assembly or a communication problem with the control panel. Contact a professional to move forward accurately.
Jan 07, 2013 | Frigidaire AEQ6000ES Electric Dryer
I have an lg dryer model DLG5966W and the check filter light is on. It takes two cycles to completly dry my clothes. I cleaned the lint filter and still doesnt dry on one cycle. I then removed the filter...
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 17, 2010 | LG DLG7188 Gas Dryer
Not enough heat
You may need to adjust the air flow on your dryer vent.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
Solution:
LG DRYER SERVICE MANUAL
LG PARTS
May 11, 2010 | LG DLG5988 Stainless Steel Gas Dryer
Have a Maytag Dependable Care dryer. Model MDG9606AWW. The glow bar comes on, gas lights and stays on about 30 seconds, go off for about 30-60 sec. then comes back on for about 10-18 seconds. Then goes off...
Apr 01, 2010 | LG DLG5932W Gas Dryer
Hi. Our dryer will start normally and then the
HI. This will occur when the there are issues that concern the integrity of the timer motor. This mechanism is responsible for the rotation of the timer module.It is damaged at this time, and it must be replaced asap.
A damaged timer motor will affect the nature of the drying cycle. It is the main initiator of all functions during the selected cycle.
Oct 29, 2009 | Dryers
Control stuck on, with multiple light combinations
All this is normal except for the lights coming on. could be the panel control board.
Oct 08, 2009 | GE Dishwashers
Whirlpool model # lgr7646ez3
Here are a list of causes that may contribute to this lack of sufficient drying.
CAUSE
• Lint screen is clogged with lint.
• Restricted air movement.
Exhaust vent or outside
exhaust hood is clogged with
lint.
• Exhaust vent is crushed or
kinked.
• One fuse is blown or circuit
breaker is tripped. The dryer
will appear to operate, but you
will not get any heat.
• Cycle Control knob or temperature
selector is set on air dry.
• Load not contacting the sensor
strips and automatic cycle
ending early.
• Fabric softener sheets blocking
exhaust grill.
• Dryer located in room with
temperature below 45ºF (7ºC).
• Large amount of moisture in
the load.
• Cold rinse water used.
• Load too large and bulky to
dry quickly.
Here are the solutions to combat the issues.
SOLUTION
• Clean lint screen.
• Run dryer for 5-10 minutes. Hold hand under
outside exhaust hood to check air movement. If you
do not feel air moving, clean exhaust system of lint
or replace exhaust vent with heavy metal or flexible
metal vent.
• Replace with heavy metal or flexible metal vent
• Replace fuse or reset breaker.
• Select the right cycle and temperature for the types
of garments being dried.
• Level dryer.
• Use only one softener sheet per load and only use
it once.
• Move dryer to a location with temperatures above
45ºF (7ºC).
• Expect longer dry times with items that hold more
moisture (cottons).
• Expect longer dry times.
• Separate load to tumble freely.
This will help you fix this problem. i suspect an exhaust obstruction.
Mar 11, 2009 | Whirlpool LGR7646E Dryer
Kenmore Elite HE4 Electric Dryer Logo
1,925 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
