Question about Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX
Can't find a manual for a older AOpen AX59Pro Mainboard.
  • Josh Collins
    Josh Collins Apr 18, 2009
    Thanks I appreciate it
  • Josh Collins
    I would really like to get ahold of a printable manual.
    Sergeant:
  • 293 Answers
Http://www.fixya.com/support/p365436-aopen_ax59pro_1101_91_87810_413/manual-16498
There's an online version for you.
Posted on Apr 18, 2009
Aopen i945gm pilf motherboard manual
Hello you cam download the manual here:
http://europe.aopen.com/download.aspx
By selecting mainboard and the model number.
Good luck
Apr 11, 2013 | AOpen Computers & Internet
I want to know the right ram for Aopen s661FXm us rev 2.2 plz !!
Hello you can download info here:
http://global.aopen.com/products_detail.aspx?auno=1301
Your mainboard use DDR ram max memory size 2 gb.
The drivers (if needed) can be downloaded here:
http://global.aopen.com/products_download.aspx?sDropDownProd=52
Good luck
Dec 24, 2012 | AOpen s661FXm Prescott Motherboard
AOpen MX46-533V (91.89U10.061) Motherboard compatable sound card
Hello why not download the sound driver from here:
Please select the mainboard in the motherboard menu.
Download the sounddriver and install it.
You need to reboot after the install is done.
You can buy a soundcard in a computershop or online.
I am sure they will be glad to advice you one that fits your pc.
Good luck
Dec 13, 2012 | AOpen MX46-533V (91.89U10.061) Motherboard
I have got a system with an Aopen motherboard which having only a 20 pin connector for smps connectivity. the Atx smps i have is is 24 pinned. i can connect the main line by splitting up the 24pin...
The actual Processor fan connects to the CPU Fan header on the mainboard. It's 4 small pins. It plugs in right near the CPU socket on the mainboard. Check the user manual for exact placement, you may download it from the AOpen website if you don't have one already.
Plug in the 20Pin connector if that is the most Pins that the mainboard will allow. Cable tie the other 4Pins back onto the 20Pin connector.
Then if there is additional 4Pin connector required by the mainboard for CPU power and you don't have that connector on you power supply, you will need to purchase a Molex to 4Pin CPU power connector. When you go to the computer store check with them that all is correctly connected.
Take care!
damnor01
May 25, 2011 | AOpen MX4GER Motherboard
My aopen is an older model dated 1987-2001, do you have any info of what model and motherboard driver where used and if there are any update that i can add on to upgrade it.
conleyarmah I need THE Model Number, (Part Number), of the AOpen motherboard.
A Driver is a small piece of software that the Operating System, (WinXP is one example of an O/S), uses to 'communicate' with a device. The drivers you need are specific to your AOpen motherboard.
Some examples of Model Numbers AOpen used,
http://www.motherboards.org/mobot/manuals/AOpen/
Where the box has - Select Part Number - in it, click on the blue down arrow to the right of the box.
Look for the part number in the middle of the motherboard, or off to one side, or perhaps in-between the white PCI slots.
This is AOpen Support, and their Product Museum.
You may find your part number listed here,
http://global.aopen.com/Museum.aspx?fromPage=products
Dated 1987-2001?
THAT, .....is a large time span for a computer part.
Where did you come up with the above time span?
Please reply in a Comment.
Regards,
joecoolvette
May 03, 2011 | Computers & Internet
SN 91.8B810.003 MODEL AOPEN MX4SGVI-N , POWERS ON BUT DOES NOT BEEP OR BOOT TO SREEN HAVE 1.7 P4 CPU COULD THIS BE THE PROB
DID YOU RECENTLY ADDED RAM?
it can be the problem, or some connections with mainboard,
try to start uip with the less elements possible
if you succeed booting,
from another cpu, download and do a floppy/cd from this BIOS and retry with full devices connections.
Nov 26, 2008 | AOpen Computers & Internet
Manual for aopen mk77m11
http://download.aopen.com.tw/default.aspx
contains the drivers, bios updates, manuals, and other assorted downloads for various Aopen motherboards. You will have to select your particular mainboard from a list, and once the mainboard is selected you may have to suffer a small delay before more pertinent data shows up. Info is coming from Taiwan and even here in Korea is was slow but then again Aopen had a large selection of systems last time I used them.... As always before updating any bios, pay attention to small print.
Jul 31, 2008 | AOpen AK77-8X Max (91.8A710.101)...
SATA HDD
you need to install the drivers for it when loading windows,,
you are on the right track by pressing F6 however you need to have the FLOPPY DISK that came with your mainboard in the floppy drive..
If you dont have the diskette then ,, the drivers are located on the mainboard cd,, its in the sata / raid folder, there should be a text document in there with the insttructions on creating a floppy with the driver files you will need.
Jul 19, 2008 | AOpen AX4B-533 Motherboard
Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX Logo
43 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
