Question about Refrigerators
Cold air balance is not maintained between freezer and refrigerator sides. If balance is adjusted to the feezer side the refrigerator is too warm. If adjusted to the refrigerator side then the freezer side is too warm. Model is a Kenmore (Whirlpool) 106 57572 790. Coldspot side-by-side. Thanks...
  • ghorback Apr 19, 2009
    Thanks Arjun...appreciate the quick response.
  • 1,170 Answers
#1 Refrigerator side getting warm Freezer still coldProbable Causes
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" settingblocking air flow to refrigerator side. On most refrigerator/freezers,the freezer control closes a baffle when turned to coldest setting, andthis blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
#2 Freezer compartment getting hot.
Probable Causes
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Hope I helped with the repair of your problem.
An Accept from you is how I get paid.
And a positive feed back tells me how I did with the repair.
Arjun
Posted on Apr 18, 2009
Feezer cold frig.warm
sounds like your freezer is not defrosting, causing lack of air flow to fresh food side
May 09, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
The refrigerator is not getting cold. The freezer
don't know - some have a small opening you can adjust to balance the air between the top and bottom compartments - usually inside bottom, at back, just under freezer.
Mar 03, 2018 | Amana ARSE665BS Side by Side Refrigerator
Kenmore refrigerator Freezer is cold but fresh food side is warm
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jan 26, 2010 | Kenmore 57029 Side by Side Refrigerator
Freezer ice cold but refrigeratoer side warm
Must adjust the food compartment settings to a higher level. If that does'nt do it in 24 hours .You have a faulty evaporator fan....The evap.fan distributes cold air from freezer to food compartment...Jack Arevian
Jan 24, 2010 | Frigidaire FRS26H5AS Side by Side...
Jenn-air JCD2289ATW Freezer perfect but refrigerator is warm
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 12, 2009 | Jenn-Air JSD2789GES Side by Side...
Freezer way too cold, refrigerator side too warm on side by side.
This can be caused by lots of faults first inspect the evaporator in the back of the freezer for ice build up if this is the case the defrost system has a fault, if not the unit that opens between the wall of the freezer and the fridge may be faulty check for the grills opening and closing
May 29, 2017 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerator will not maintain proper temperature
Check in the back of the fridge section; there is normally a control that is provided for 'balancing' the cold air between the two sections. That coolled air is distributed by a concealed fan that may not be running; you should be able to ear or feel the air movement when the unit is in a cooling cycle.
Apr 19, 2009 | Samsung RS2534 Side by Side Refrigerator
Refrigerator does not get as cold as I would like
First check the condensor fan and condensor for dust and make sure they are clean. If these areas are not clear the system will not operate correctly. You should be able to place your hand down low on the front of the frig and feel warm air coming out of the grate there. The presence of a flow of air meens that the condensor fan is working. Depending on how forceful the air flow is, would depend on how much dirt and dust the condensor has collected. The temp controls should be set to midway first. There is a dilicate balance for these settings. Over adjusting can cause problems. Then after several hours check the frig. If not cold enough. Adjust only the fresh food adjustment colder a little bit at a time. Repeating this untill your fresh food side is cold enough. If you over adjust the fresh food side too much then food in the fresh food side will begian to freez. If you set the freezer side too high you may be causing too much frost build up on the evaporator and lowering the air flow to the fresh food side and causing it to be warmer than it should be. This would be a check to see if you can balance the frig temp. If you can`t get it to balance and there are no restriction of air flow in either the evaporator or condensor, then we may have to look farther into problems with the compressor. You may need to check for some ice buildup around the air inlet in the fresh food side from the freezer side. Try this and let me know how it is.
Nov 13, 2008 | Whirlpool ED5FHEXMQ Side by Side...
Appliance: Frigidaire 3.1 Cu. Ft. Compact Refrigerator Problem: How do I adjust freezer temp in my mini-fridge with top frost free freezer, has turn dial for refrigerator but no turn dial for freezer and...
The turn dial that controls your fridge temp also controls the freezer temp. The freezer air is directly forced into the freezer compartment and then sent to the reigerator. Adjust the dial for the fridge not to be so cold and it will adjust the feezer also. Allow about 24 hours for any noticeable change.
Apr 19, 2008 | Refrigerators
The refrigerators accumulate ice
the fridge distrubutes cold by air movement. A overstuffed fridge can have trouble. There is a fan that blows a controlled amount of freezer air over to the food side, altho when this goes you usually have frozen freezer and food too warm. Make sure the air is allowed to move.
Nov 29, 2007 | Liebherr Premium CTP 3153 Top Freezer...
Refrigerators Logo
164 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
