Question about NEC MultiSync LCD1700V 17" Flat Panel LCD Monitor
Monitor have power but no picture, when i turn on computer few second stay picture then picture goes off and power light stay green.
  • ladybugg111 Nov 30, 2008
    I have the same problem. I have the NEC multisync LCD 1700 v monitor which started off with just blanking out but if I turned it off & on it came back. Then it died totally. Nothing shows. I put another big honking monitor that I kept for emergencies, so not the same!, & it works fine.
  • Anonymous Apr 28, 2009
    picture comes on for a few minutes and then no picture
    Problem Solver:
  • 5 Answers
Exactly what the one in my shop is doing and it turned out to be bad HV board in monitor. Gary(Honkity Hank)
Posted on Sep 18, 2007
SOURCE:
Picture won't display after a few seconds
this is either the flourescent bulbs are going out or the power supply has bad capactors on it. You might open it up and look at the power supply board for capacitors with their ends that look like they are "erupting" on the ends.. this means they need to be replaced.
May 13, 2014 | Envision EN-7410 17" Flat Panel LCD...
Monitor come on for a few seconds then goes black,green signal light stay on green. can you help
the monitor may be losing the back lite. take a flash light or bright light and shine it at the screen after it goes black. can you see a faint picture? if so the back lite has failed. usually the cost of replacement exceeds the cost of a new monitor but there are a couple of web sites that detail the replacement of the "ccfl" cold cathode flouresecent light.
Apr 27, 2011 | Proview PL713B 17" Flat Panel LCD Monitor
Monitor stopped working...checked all connections...light won't stay on green. bought a new monitor to replace it and that monitor says "no signal". is this a problem with the dell computer and not the...
Your monitor is going into power saving mode. When it receives no video signal from the computer, it will stay powered for a few seconds before giving up and presuming the PC is off hence why it stays green for a while, then goes orange.
The problem is with your PC not the monitor(s)
Jul 07, 2009 | Dell Computers & Internet
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Westinghouse LCM-19V7 powers on, but picture only stays for a sec
It's probably bad capacitors on the power supply board. These monitors are notorious for having the electrolytic capacitors blow out; cheap components! I would suggest replacing the two 1000 mfd capacitors and the three 220 mfd capacitors with 35 volt components from Radio Shack. That fixed one of my LCM-19V7s but not a second one which seems to have some other power supply problem.
Mar 24, 2009 | Westinghouse Computers & Internet
Dell e770 Monitor
It sounds like the picture tube in the monitor has burned out. Time to replace.
Feb 03, 2009 | Dell E770 Monitor
No picture on my x5g-komodo7 monitor
A reddish picture is the classic symptom of worn out backlight bulbs.
Sensor circuits usually shut down the power to the bulbs in a second or so.
Monitor Mike.
Jan 03, 2009 | Sceptre X5g-Komodo VII 15'' LCD Monitor
Monitor goes blank less than a second after turning on.
Beautiful screen, lasts about for a few minutes, goes black. Power button still green. If I turn it off, and then back on, it works again for a while. Any ideas?
May 11, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
Moniter
does it display a picture for a few seconds before it goes blank. or do you not get any picture?. i think i might know what it is but if you could let me know :-) All the best John
Mar 02, 2007 | BenQ T701 TFT 17" LCD Monitor
Monitor goes dead AL1914
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
NEC MultiSync LCD1700V 17" Flat Panel LCD Monitor Logo
317 people viewed this question
Top NEC Computers & Internet Experts
Ekse
Steven Wander
Steven Wander
Thomas F. Schneider
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
