Question about Sharp AR-5320 Black and White Copier
Dispays h4 error
Sharp ar-5320 displays h4 error
  • 95 Answers
An H4 error code indicates trouble in the fusing section - a certain temperature has not been reached within a specified time. It could mean a dirty/bad thermistor or dirty/bad thermostat (both inside the fuser unit. Make sure both of these are clean and there is not debris/paper stuck inside the unit.
You can try resetting the code by : Get into SIM mode by pressing the following keys one after the other "#" "interupt" "C" "interupt" then enter 14 and the start key - confirm if requested then make sure the copier restarts.
Hope this helps.
Posted on Apr 18, 2009
Problem for Sharp AR-5320 Black and White Copier Ar 5516 display H4 error?
for AR 5320 just check 1- main corona 2- leveling the developer unit 3- clean cleaning plate,
for H4 just rest the machine as mentioned above, if not plz check fuzing unit -- thermostat
Aug 22, 2010 | Sharp AR-5320 Black and White Copier
Sharp ar 5320 displayed error code h4 and it is blinking
Hello :
It's a bad component in the fuse. It could be a bad thermofuse or thermistor . Better to take it to a Sharp dealer . They should be able to repair it right and quickly .
good luck .
please don't forget to rate !
Apr 04, 2010 | Sharp AR-5320 Black and White Copier
My Photocopier displayed error H4 on the screen
Dear sir
H4 signal is fuser unite problem please call a technician they solve this problem.Just we serve problem location because i am not live your area.
Thanks
Tareq
Aug 12, 2009 | Sharp Office Equipment & Supplies
Irc2105
There is no such error 'E215-0000' in ar 5320, for H4 use "#, Interrupt, C, interrupt. Display goes off, Enter 14, Press Print key.
Apr 08, 2009 | Sharp AR-5320 Black and White Copier
Error h4
it is on you fusing unit of your copier, check the fuse maybe it is open already and need for replacement... H4 means that your heater lamp is not functioning
franklin
Jan 07, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR 5320 error h200
H4 indicates there is a fuser error.
Try resetting it by the pressing the following buttons on the display in sequence,
#, interrupt, Clear, interrupt,
display should go dead,
enter 14,
then press print, This will clear the error code
press CA to get out and return to normal.
However if there is still a problem with the fuser, the code will return. Then you may need to have a tech look at what is the problem.
Hope that helps...
Lbcoaster
Aug 05, 2008 | Sharp AR-5320 Black and White Copier
Error code
Hi, H4 is a heater error. Try resetting it by the following; Enter #, interupt, Clear, interupt, display goes dead, enter 14 then print. That will clear the error code, however if you have a problem with the heater it will return. It is probably the thermal fuse has tripped, which is resetable by removing the fuser unit
Regards
Andy
Jan 22, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 Black and White Copier Logo
466 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
