Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
Why is the yellow lamp warning light staying on on my Mitsubishi WD-52525 52-inch DLP HDTV
    New Friend:
  • 58 Answers
That means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Posted on Apr 18, 2009
  • gdutchman Nov 20, 2010
    Not the case, if this is the second bulb replacement. My tv was working well but indicating low picture brightness.. Ordered bulb for second time, installed bulb and now this wont turn on at all !!!
Blinking yellow light on Mitsubishi wd 57731
Based on the service manual:
Blinking yellow= Lamp cover is open.
It could be something else!
www.aaatvservice.com
Aug 09, 2014 | Mitsubishi WD-57731 57" Projection HDTV
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
I have a blinking yellow status light on my mitsubishi 73837
blinking yellow indicates no lamp or the lamp door is open. if you had the back off you may have gotten the door switch aligned improperly. the door switch is located just inside the lamp door.
the lamp may also be bad.
lamp part# 915B403001
see website:
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73837
Apr 29, 2014 | Mitsubishi WD-73837 73 in. HDTV
Mitsubishi 1080p dlp hdtv troubleshoot
If it's older. Probably a blown lamp. Check owners manual then shop,new one on eBay. Easy to replace. I have done it twice
Sep 27, 2013 | Mitsubishi Wd-73733 73-inch 1080p Dlp Hdtv
Reset lamp
Here's a video vince suggested as a solution to your problem from YouTube:
Panasonic TY-LA1000 Lamp Replacement Guide for DLP TV
Apr 29, 2013 | Mitsubishi Wd-60738 60-inch 3d Dlp Hdtv
I have the 60 inch mitsubishi dlp. There was a sound just like a light bulb going out. Then there was no picture or sound. I replaced the lamp and still no picture or sound. I hear clicks when trying to...
If the status led is blinking yellow its indicating that the filter cover on the side is open. If its the lamp indicator thats blinking yellow its indicating the lamp door cover isnt attached properly.
Sep 24, 2011 | Mitsubishi WD-52825 52" Rear Projection...
New lamp replaced but yellow lamp light is flashing
Go to this Website they will list all Parts/boards and everything you need for this TV
WEBSITE:
Encompass Parts Distrubtion 1-800-638-3328
Jan 16, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
http://servicemanuals.vstore.ca/
Sep 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Lamp light is steady yellow. TV works fine otherwise.
Order another lamp and have it on standby as the steady yellow light is telling you that the lamp has outlasted the normal rated useage hours so your lamp will fail without warning at any time.
May 13, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
885 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
