Question about Dell OptiPlex 330 Desktop Desktop Computer
I have 2 optiplex 330 desktops and am trying to put both hard drives into one tower. I can not find how to switch the secondary one to slave.
    Scholar:
  • 88 Answers
If they are IDE Harddisks, check jumpers at one end. it's wise to set it to CS (Cable Select). On the IDE cable, the furthest connector is the Master.
If SATA Harddisks, there are no jumpers required (only one HDD per connector). you will need to change the setting in BIOS to boot from one. Also SATA connectors should have a label nearby, namely SATA1, SATA2, etc. Use SATA1 for OS.
Posted on Apr 18, 2009
  • 600 Answers
There are jumpers on the unit sl is slave, cs is cable select, and ma is master, i recommned putting it on cs (cable-select) and using the middle connector for it, then goto the bios and confirm
How do I fix a problem were a tower computer won't see the slave hard drive.
It sounds like both drives are trying to be the master on the cable. Have you tried setting both drives jumpers to the CABLE SELECT setting. This allows the BIOS to individually identify them and you specify in the BIOS which is the primary boot drive.
Mar 22, 2016 | Dell Computers & Internet
Will the hard-drive from PACKARD-BELL IMEDIA X2414 go into DELL GX150LINUX
Yes if the data connections are compatible. SATA data interface and SATA power connector, it's a thin black connector.
It is not reccommend to switch drives across operating systems unless you are abolutely sure that you know how to access the drive without damaging/erasing the information that is currently on the drive.
The current Windows hard drive will not boot in a different pc system.
I would suggest getting the orginal pc working again, it may be a simple case of loose connection/contacts. Unless you had a friend that would be willing to help, by attaching your hard drive to his pc as a slave and then copying your data to DVD's.
See my published guide entitled: My Computer is not turning on!!! Is it dead!!! No POST!!!
Take care!
damnor01
Jun 07, 2012 | Dell OptiPlex GX150 PC Desktop
When i start my dell optiplex 330 pc, the power light will be blinking orange and all the fans on the pc do not work but the orange led on the motherboard works.
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
good luck
Sep 16, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
How do I add a hard drive to my optiplex 330
Oplen the cover ... physically install the device ... making SURE it is the proper type ... plug it in following the manufacturers instructions.
May 02, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
What is the commonest problem with Dell optiplex 360 and 330
Most of the early Optiplex systems had poor ventilation fot their power supplies. Most of this was with their desktop Optiplex, and not their Tower models.
Apr 19, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
Switching problem
If the power light is flashing either yellow or orange and you do not hear any fans turn on, your power supply is defective. Contact Dell if you are still under warranty and if not, there are many 3rd party sites, like http://www.pcconnection.com, that you can purchase a new one.
Good luck to you.
Nov 20, 2009 | Dell OptiPlex 330 Desktop Desktop Computer...
Dell optiplex gx110 device detection problem
I'm guessing that the computer is not booting at all. This is saying that it cannot find any hard drive to talk to. Drives are labeled in the computer code with numbers starting at 0. There are up to 2 drives on an IDE ribbon cable, the Primary, and the "slave" or secondary. So, possibilities are that your hard drive died, the power connector to it came loose, or the power supply itself is having an issue with that connection that is attached to the hard drive.
Jun 11, 2009 | Dell OPTIPLEX GX110/200 PIII-866MHz 256MB...
Dell Optiplex Gx280 - cant detect two IDE hard drives
You should attach two hard drives on primary ide. Set both jumpers to cable select ( or one on end is master, middle one is slave). The one at the end of the cable is where your o/s should be. You could try putting the third on seconday, along with your dvd rom.
Hank
Jun 09, 2009 | Dell Optiplex GX280 (99301) Motherboard
How set the hard drive and dvd-rom
first idea is to set the Hard drives on the primary controller on the same cable, having your hard drive with windows as the master and the other as slave ( do this with the jumpers).
Next put your cd\dvd drive on the other cable on the secondary ide (the name is usually IDE2).
turn on your PC and pres delete to go to the bios settings,
once there go to the basic cmos settings page, and make sure you see the settings there as you wanted,
Primary master first hard drive
Primary Slave second hard drive
Secondary Master your cd\dvd drive
helpful ? if not give me a reply for more help
Mar 23, 2009 | Computers & Internet
Dell OptiPlex 330 Desktop Desktop Computer  Logo
156 people viewed this question
Alun Cox
