Home | Viking | 24 in. Professional Series VUD141 (Ul... | My viking dishwasher doe...
Viking 24 in. Professional Series VUD141  Built-in Dishwasher
Problem for Viking 24 in. Professional Series VUD141 (Ultra-Premium)...
My viking dishwasher does not rinse the soap scum off the dishes
By drtdcho on Apr 18, 2009
No matter how little powder or liquid soap I use, my Viking dishwasher leaves the dishes with a thin film of soap on all of the dishes, both top and bottom racks. This happens even if I clean the filter on the bottom.
Solution #1
posted on Aug 12, 2009
Not Rated)
mambro
Rank: Wiz
Rating: 79%, 155 votes
Its not soap, its actually calcium from hard water. There is a new product out at www.dishwasherfilter.com that solves this problem once and for all. It is a small filter that goes under the sink and filters out the hard minerals that cause these spots from the water before they enter the dishwasher. It is very affordable (like 70 bucks) and even has a money back guarantee. After just one load you will be amazed how your dishes look.
Was this helpful?
Yes
No
Solution #2
posted on Apr 26, 2009
Not Rated)
CarlosTheJac
Rank: Apprentice
Rating: 0%, 0 votes
Maybe . . . remove the lower rack and invert it. Look for cracked or missing plastic coating, exposed, rusted & possibly "swollen" inner steel rod/wire. If found, remove the upper rack and look for more of the same. What you think is "soap scum" is probably rust and other iron compounds leached by the dish soap out of the rusted steel onto the dishes and the dishwasher interior. The following worked for me . . .
To clean the interior (with both racks removed), set to "No Heat" dry, then "Pot & Pan" wash and allow to fill. Open door, dump in a bottle of "Lime A-Way", close & latch door and allow to complete cycle. This should remove most rust and iron-sulphate deposits from interior. If not, scrub them with Lime A-Way and a ScotchBrite pad, then cycle again.
Racks must be replaced (Viking are very expensive, Asko, Bosch, or other lower racks may fit: check your neighbors' racks for fit), upper rack must be Viking unless you can exact-match the Asko or Bosch equivalent.
Possible fix: remove the loose plastic coating and flaking rust with a knife, ruff plastic coating with ScotchBrite, clean with rubbing alcohol, then treat metal/rust with "rust converter" (hardware or home imp store), wash with soapy water, rinse, then clean with rubbing alcohol, dry fully, coat with "high temp" (orange or yellow) silicone sealant (auto part store), covering exposed metal and a half inch or so over the plastic coating. Let set for a day or two.
A trip through the dishwasher for all your stained stainless, glasses and non-metallic coated or non-metallic decorated dishes with Lime A-Way as above (on new or "rebuilt" racks) should get the metallic scum and rust off them.
Was this helpful?
Yes
No
Popular Solutions for Viking 24 in. Professional
Questions and Unsolved Problems for Viking 24 in. Professional
Do you recommend Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher?
Answer
Answer
Viking double oven The delay setting will not turn off or clear - when timer setting and off is... (More)
Answer
Hi - I used the self-clean feature on my Viking oven 2 days ago and now it won't unlock and I can't... (More)
Answer
water was shut off during dishwasher cycle not dish water will not work no water even though water... (More)
Answer
Viking dw 20.3 does not complete cycle or open soap door. It does drain and fill ok . When it stops... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Viking 24 in. Professional...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
