Question about SanDisk Sansa e250 MP3 Player
My Sandisk Mp3 player does not open up when i press the open button(i have tried holding the button for more than 15-16 seconds). I have charged it for more than a few hours. When i connect it to the computer i am able to view the files and enter files in it but i can't open it after disconnecting it from the computer.
  • schusterslfp Apr 19, 2009
    I was loading some songs on the SanDisk when it froze. Since then I can't get to the main menu. It will turn on but all I see is the SanDisk logo. It belongs to my granddaughter and I told her I would load the music and now I'm afraid I've ruined it!!! Please tell me not!!
You maybe entered to settings and went to usb mode and turned it to mcs and left it like that and you have to turn it back the other mode and i think you can open it after disconnecting it to the computer....
Posted on Apr 18, 2009
After charging my player doesn't respond to pressing buttons.
Hold down left or back button and press on button at same time. Hold both buttons for at least 30 seconds. This should reset player.
Mar 19, 2014 | SanDisk Sansa Clip MP3 Player
My sansa is not charging
Check the cable is connected correctly and if it is OK try resetting the device this way:
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
gylacz
Mar 16, 2011 | SanDisk Sansa e260 MP3 Player
Sansa express won't turn on
Normal 0 Press and hold the Volume Up (+) and Select buttons at the same time for about 20 seconds
Make sure that the player is charged up.
Try to power reset the device by pressing and holding the center and volume up button at the same time, while connecting it to the PC.
If power reset fails, charge the device for at least two and a half hours. The computer should not be in sleep or hibernation state while charging.
You may need to update firmware.
Feb 07, 2010 | SanDisk Sansa MP3 Player
Mp3 player froze when plugged into pc. screen is blank but lit. is charged. what do i do?
Make sure the player is fully charged.
  • 1. Connect the player to your computer.
  • 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode,
  • 1. Turn device OFF.
  • 2. Slide the Hold switch down to Lock (orange color showing).
  • 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC.
Next Be sure the battery is charged
  • 1. Leave the player connected for approximately 2 hours to charge.
  • 2. Disconnect the player from the PC.
  • 3. Verify if you can turn on the player.
  • 4. Reset the player if necessary.
To reset the player:
  • 1. Press and hold the Power/Menu button for approximately 20 seconds.
  • 2. Release the Power/Menu button.
  • 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Then try and see if it will come on with out the battery but hooked to your computer.
Feb 02, 2010 | SanDisk Sansa e250 MP3 Player
My sandisk sansa wont charge or turn on after plugging in to charge
Does the computer recognize it at all? These mp3 players have a problem with the power button which you push up to turn on,,,, the switch some times become dislogged and require the consumer to either open it or replace it... you can try to reset the device by holding the power button in on position for 10-20 seconds
Jan 18, 2010 | SanDisk Sansa Clip MP3 Player
My mp3 wont charge
This issue may be resolved by resetting it, try this.
Resetting the device:
Jan 02, 2010 | SanDisk Sansa m240 MP3 Player
MP3 is dead. Is there some trick to reboot?
Press and hold the power button (menu) in your e140 for about 30+ seconds. Now try powering on your Sansa.
If it doesn't work, press and hold select (center button) alongside pressing and holding power button. Probably this should work for you.
Dec 24, 2009 | SanDisk Sansa e140 MP3 Player
Sansa mp3 player e200 version
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Oct 28, 2007 | SanDisk Sansa e250 MP3 Player
My sansa e250 mp3 player is not turning on and charging.
i had the same problem.  the solution i used was to unscrew the back and pop the battery out and put it back in.  the only other option is to wait for the battery to die, which can take a while.  it's definitely a flaw with the sansa.  its happened twice within 6 months...  good luck
Oct 20, 2007 | SanDisk Sansa e250 MP3 Player
Not responding
Press and hold the power button for 20 seconds to "reset" the device. That always works. ;0)
Sep 03, 2007 | SanDisk Sansa c200 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
69 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
