Question about GE GSS22IBPCC / GSS22IBPWW Side by Side Refrigerator
GE GSS22IBPH WW
Freezer blower fan is making a howling noise when fan speed varies. At a certain rpm the fan makes a whirrling noise. The sound is not constant, but usually acts up in the evening. I have visually confirmed that it is the fan, but not positive which part would need to be replaced. Through research, i have found that it could be the "board" that needs to be replaced.
  • LGerber Nov 25, 2007
    Freezer fan makes a soft whistling noise. Tried moving items around to minimize any obstacles to air moving freely. but it still whistles.
4 Suggested Answers
SOURCE:
hotuna
  • 288 Answers
SOURCE: GE GSL25JFR Freezer fan noise.
It is very common for the fan inside the freezer to develop a loud noise as it runs. Its in an environment that is hard on them, cold, wet. Its a small and simple motor, and you are right in believing there will be more problem in the future, as the stator is probably touching the housing. It has a sleeve type bearing, and its probably worn a little causing the shaft to wobble. Eventually it will stop completely and the freezer will get warm.
Posted on Mar 07, 2008
aasc
  • 1606 Answers
SOURCE: same howling noise here
Ok nx , I will try to help you .
1 ) unplug the refrig , and on the back , remove the panel covering the
board.
2 ) unplug the blue conector on the board , with 3 larger wires connected to it . looking at the connector , you will see
wire1 , wire2 , space , wire3 .
3 ) find a short piece of insulated wire , and strip both ends about 1/2 inch , and insert one end into wire2 , and the other into wire3 . Leave the connector unplugged .
4 ) plug in the refrig . After about 1 min , look inside the freezer , at the bottom , looking for a red glow . If no red glow , then the problem is the heater or defrost thermostat ( the 1" cylinder , with a pink and blue wire going to it , clipped to the top right on the coils ) . If you replace the heater , replace the defrost thermostat also .
5 ) if you do get a red glow , then the # 4 thermistor is probably bad . This is the 1" white torpedo looking piece , with 2 wires going to it , clipped on the top left of the coils . This thermistor works off resistance by coldness , and sends the signal to the control board . When the control board registers this resistance for so long , it will go into the defrost cycle , causing the heater to come on .
The fan howling , could be from trying to pull air up thru the frosted coils. The # 5 thermistor , located at the bottom of the freezer , slightly foreward of the drain , inserted into a holder , with 2 white wires going to it , tells the control board what the freezer temp is . This thermistor , could be bad , varying the resistance message to the control board , causing the fan speed fluctuations .
Posted on Sep 30, 2009
Testimonial: "Thanks for your info. My repairman NEVER tested the defrost heaters or other parts, and simply ordered the comp. board - I'll see how this goes."
  • 291 Answers
SOURCE: Howling noise from freezer fan, GE side-by-side
Replace the fan, Remove the evaporator cover in the back of freezer, and probably another cover for the fan. Unplug your refer first. Usually their are two screws holding the fan bracket to the wall or mount. disconnect the wires, and replace. Their is a newer model evap fan motor that does not have wiring terminals to disconnect, it is hard wired together and you have to practically remove everything in the freezer compartment to get at it. You have to cut wiring and splice the new fan motor in. Fairly tough job. Usually an evaporator fan motor bearing fails from the refer being moved or in storage for a few days at least with the doors closed and the unit unplugged. This allows all that moisture that was in the freezer to get into the metal parts of the fan motor and cause this problem. To prevent this always block the doors open if your refer is going to be off for a few days. This will allow the unit to dry out without damage. Sometimes it was just a bad motor from the factory. Good Luck, Appliance Specialists
Posted on Dec 17, 2009
Same howling noise here
board.
Sep 30, 2009 | GE Profile PSW26P Stainless Steel Side by...
Replace the fan motor is my guess to cure the noise.
Mar 01, 2017 | GE Profile¿ 42" Built-In Side-by-Side...
Noisey ge side by side
hi thanks for the question that noise is the fan in the freezer.you replace the fan motor the water disp problem is the little switch inside the freezer door difficult to get at please accept with a positive feed back thanks the appliance doc
Sep 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE side by side refridgerator makes a "howling" sound. Any ideas?
the problem you are having is in the main control board. ge has had a problem with this part causing the fan motor to go into high and low speed which causes the howling noise. unfortunately it is a costly fix, around $125 for the part. if you are savy to changing this part it is a matter of unplgging about 5 connections and replugging them. the new board has an extra set of pin that nothing connects to. READ the instuctions and it is a simple fix, saving about $50-60 in labor costs.
Sep 08, 2008 | GE GSH22SGRSS Side by Side Refrigerator
Howling sound from freezer fan section
it is most likely the fan bushings that are making the noise. you can try to lube them with a light oil if you want to buy some time. but the fan motor will need to be replaced soon.
Jul 05, 2008 | GE Refrigerators
Noise
this fan is a variable speed and is controlled by a board in the rear of the unit. your bearings maybe going out. The fan will ramp up to speed depending on the call for cooling the Thermistors is asking for
May 20, 2008 | GE GSS22JFMWW Side by Side Refrigerator
Mar 07, 2008 | GE DSS25KGT Side by Side Refrigerator
You are correct in believing the fan is going to be a problem. The evaporator fans inside the freezer compartment are common at going bad. I believe it is due to the extreme temperature and moisture conditions inside the application. The noise is the stator or bearing equivalent going out, the speed should remain constant. It may eventually make a screeching noise upon start up, or just lock up completely. The good news is replacements are relatively cheap and easy to find. If you do replace it yourself, make sure the fan blades are blowing in the right direction. If possible, remove the old one and bring it with you to the local appliance parts supplier and he should be able to help you get the right one, it will probably be a kit of some sort with multiple mounting brackets, screws, and maybe even a couple of blades. don't let this intimidate you. Most of this you will not use.
Dec 17, 2007 | GE GSL25JFR Brushed Steel Side by Side...
GE GSS22IBPCC / GSS22IBPWW Side by Side Refrigerator Logo
90 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Tmik
Tmik
Level 1 Expert
