Hi my name is Aleixo. I have problem with this set. When I star fix it, it had oppend the mais fuse, I replaced it and I start usin one serial boolb light to save the fuse. It has some shurt but I can't find it. I think: Flyback, Vertial IC, Video IC but like fine, I desconnected the demagnetizer coil. It istill with shurt. I don't have schematic. If someone know please I need help. Thanks
well make sure u have the latest version 6.0.1 and check to make sure your addons and plugins are up to date. if you are still having problem i recommend u create a new profile. close firefox and click on start and select run and copy and paste firefox.exe -p follow the instruction on the screen hope this helps.
The locking clip is according to an USA standart that states that the car seat must not be oppend with one press so all american seats have the chest clip. the rational is that child cans open it.
in European standart it stated that it must be opened with one click so all Europien seats are without the chest clip. the rational is that in rescue situation child can be take out fast.
its up to you to decide what your prioreties are.
any way it is not advised to use the seat different then the manufacture specifications.
If you want to open it, just press on the downside rectangle shaped thing on back and slide the back cover down.You can see the battery and all.To open the front cove, hold the phone upside down and backside facing you.Move the edges to both sidesand push the cover to front
Do not put it in hammer mode and try to unscrew the chuck! This will break the housing internally. To remove the chuck you will have to put a chisel in the chuck. Lock that chisel in a big vice. You will then have to put a pipe wrench on the chuck to unscrew it. It is regular threads but there will be loctite on it. Once that is off your will have a spring and two roller bearings to remove before you can slide the bell off. You will then have 8 5MM screws to remove. This will remove the chuck. You will then have a snap ring to remove. After that you can remove the whole cylinder assy. More then likely your connecting rod is broken.
