Question about Home
I have a triton ivory II shower, when the shower is switched off water continues to flow
    President:
  • 1,902 Answers
Replace all or just your shower handle seat and washer on the shut off. Seems like a seal has gone bad and is not letting anything seat properly
Posted on Apr 18, 2009
The water flow from my triton electric shower does not stop even after unit is switched off
28487001 is not an electronic shower head made by Hansgrohe. It is an overhead shower head that has no electronic parts. Triton is a completely different company. If you have an electronic shower system by Triton you will need to contact Triton. If you have a Hansgrohe product feel free to contact Hansgrohe at 1-800-334-0455.
Apr 13, 2013 | Hansgrohe Showerhead Shower Power ...
Triton ivory 2 shower water is very hot even on lowest setting any suggestions?
Hi, You possibly have a defective thermostat. Have the unit checked by someone who is qualified on you type of unit. Good Luck --Ned
Mar 14, 2011 | Home
Have triton ivory electric shower but flow rate is rubbish when set to 7 or 8 too make water hotter why?
How cold is the water coming into the heater?
How long has it been in use?
Do you have 'Hard' water?
It sounds like a scaling, and flow restriction problem--
Tell us more what you are trying to do, and what you are working with-- (as far as water, hardness, pressure, age, etc.)
Dec 27, 2010 | Heating & Cooling
Triton Ivory 2, 8.5 kw electric shower flow has been getting porgressively weaker. Mains pressure if fine. Shower head is clean.
there could be a blockage on cold water connection which may have a filter which needs cleaning or the heating tank inside the shower could be blocked with limescale try cleaning the filter you cvould also check the shower hose for blockages or kinks
Dec 09, 2010 | Home
I have a triton r2 which has suddenly stopp working no water no power there is power at isolating switch
My guess is that the solenoid valve on the inlet pipe has died. This assembly is held closed by water pressure and power is needed to pull it back to allow water through to the heater coils. These systems are designed not to operate in the absence of water flow for safety reasons. The valve will be fine, it is the electrical coil within the solenoid which is at fault. Disconnect the shower unit from the mains supply and disconnect the solenoid terminals, Its the little cylindrical device immediately to the right to the stabiliser valve (the lower knob). Try a voltmeter across the solenoid and it should register some continuity, if no continuity the coil is fried. Triton will be the best place to get a replacement part.
Apr 29, 2010 | Water Pik Waterpik& Elements& Fixed Mount...
My Triton (Jade) electric shower has abruptly stopped supplying hot water. The pressure appears unchanged and altering the temperature control dial has no effect on the heat. Is it likely that, if needed,...
I have a Triton Ivory 111 shower, twice this week the water as just stopped flowing mid flow, presure ok and power still on what could be the trouble??
Stew.
Apr 05, 2010 | Home
Triton ivory 2 drips from shower hose when switched off any ideas or does it all need replacing thanks
heat from my shower keeps changing temperature, it will not hold the same temperature for very long...any tips ?
Mar 20, 2010 | Grohe 25 597 Talia Tub Filler w/Personal...
Triton Millenium Power Shower
generally if the flow sensor notices no water through the pump it will auto matically shut the pump down. so it could be the flow sensor is bad or the pump is not working like it should. now it depends on how old the pump is. i would start with the flow sensor.
Aug 30, 2008 | Home
Home Logo
491 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
