Question about HP DeskJet 940c InkJet Printer
Pulls in multiple sheets of paper
My 940C will pull in 3-4 sheets of paper when it prints. It prints OK, but sometimes the extra paper causes slight misalignment on documents I need to look professional. Also a hassle to put blank pages back every time.
    Problem Solver:
  • 8 Answers
You must not use thin paper. you should use thick paper so that it will only pull one paper at a time...
Posted on Apr 18, 2009
Canon ip1800 is experiencing paper jam.whener tries to print, cannot feed the paper properly
Sometimes a printer just needs some cleaning.
Remove the jammed paper following the procedure below. (1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the Paper Output Slot, whichever is easier.If the paper tears and a piece remains inside the printer, turn the printer off, open the Front Cover, and remove it. Be careful not to touch the components inside the printer. After removing all paper, close the Front Cover and turn it back on.If you cannot pull the paper out, turn the printer off and turn it back on. The paper will be ejected automatically. (2) Reload the paper in the printer, and press the RESUME/CANCEL button on the printer. If you turned off the printer in step 1, all print jobs in queue are canceled. Reprint if necessary.
Make sure to clean the paper feed rollers if paper is not fed properly. Cleaning the Paper Feed Roller of the Auto Sheet Feeder consumes it, so perform this only when necessary. 1. Make sure that the printer is turned on, and then remove any paper from the Auto Sheet Feeder. 2. Open the Printer Properties dialog box. 3. Click the Maintenance tab and then Roller Cleaning. 4. Confirm the message, and then click OK.The Paper Feed Rollers will rotate as they clean. 5. When the message appears, load three or more sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder.Set the Paper Thickness Lever to the left. 6. Confirm the displayed message and click OK.The paper that is loaded in the printer will feed through the printer and be ejected. 7. When the confirmation message is displayed, click OK. If this procedure does not solve the problem, clean the surface of the roller with applying a slightly moisten cotton swab with water to wipe off dust or stain.
If the problem still persists, contact a Canon service representative.
Mar 28, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Hi Canon LBP 1120 paper feed and paper jam problem: My Printer mostly take in multiple paper sheets instead of taking just one sheet. Sometimes the extra sheets are taken in while the printing sheet...
You need new pickup rollers
google search "LPB1120 pickup rollers" and find your nearest dealer. usualy quite easy to replace as long as your a "can do" person
Mar 18, 2011 | Canon LBP 1120 Laser Printer
HP Laser Jet 1100 - Pulling Multiple Pages thru when printing
Just by Cleaning and changing the Pickup roller
Click here and Follow the steps.
Please rate my response!!!
Jan 29, 2010 | HP LaserJet 1100 Printer
My hp 7410 pulls multiple sheets at one time I
remove paper and try to blow thru the papers so they a loosen from each sheets...then put it back...do a test print.....
Oct 07, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Miss feeds when print multilpe pages
The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
Sep 02, 2009 | Konica Minolta magicolor 2300DL Laser...
Paper Jam C84
Was the printer feeding multiple sheets at the same time, so that the sheer thickness of the wad caused the jam? If so, look into the slot where you load paper (this is called the automatic sheet feeder or ASF). You should see a small roller with a rubber coating. This is what pulls the sheets into the printer. Put one sheet of paper into the ASF and do a print. The Windows test print facility is convenient for this: start-control panel-printer and faxes, then right click your printer icon and select properties, then test print). If this works OK, put two pages into the ASF, then three etc. Observe what happens. If at some point more than one page is pulled in, it infers that the ASF is not working properly, in which case you will need to consult a technician (or have a go yourself at dismantling the printer). If the one-two-three-four etc page test doesn't produce a multiple feed, all it probably means, is that static electricity is holding the sheets tightly together. Make sure when you put a wad of paper into the ASF it has been fanned.
Report back on what you find, or if you have any queries on the above.
Jan 22, 2009 | Epson Stylus C84 InkJet Printer
Printer does not fully pull paper...
You probably need to clean the rollers that feed the paper. Check your manual or go to Cannon web site.
Jan 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Lexmark Opra M410 Laser
Your printer has a separation pad that is worn out and needs to be replaced. This pad prevents the printer from feeding multiple pages. It is located in the inside front of the paper tray Assembly.
Jan 06, 2009 | Lexmark Optra M410 Laser Printer
Extra paper pulled
Some rubber lining or rollers is out of line, if you can fix that it may work properly.
Oct 24, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
HP DeskJet 940c InkJet Printer Logo
248 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
