Question about Maytag Neptune MAH5500B Front Load Washer
E3 error code will not wash, what does this error code mean?
Replaced the computer board, thought that was the problem, but 2 days later got the same e3 erroe code
I have a maytag washer and it says E3 and it will not work,does anyone know what that means please let me know...thanks
Posted on Dec 21, 2009
Voltas split a.c error code e3
http://errorcodeairconditioning.blogspot.com/2012/06/chigo-fault-code.html
LED
code = E3
explain = display at off state
LAMP DISPLAY
code = flicker 3/5 SEC
explain = display at on/off state
FAILURE = coil temp. sensor fault
The reason of fault and solution = 1 .Check whether the resistance of the sensor is normal
(the resistance is 5K? in the normal temperature 25°), when it is abnormal the sensor should be replaced.
2 .Check whether there is short circuit or open circuit in the wire of the sensor, and whether the plug is connected well,
3.When the 1 and 2 are both normal, then the components or integratedcircuit is damaged, the electric control board should be replaced.
Apr 29, 2016 | Heating & Cooling
Model wf361. What is causing e3 error?
e3. Drive motor tach fault. This means that the tachometer is not regitering any motor movement when it should. Main reasons for samsung: motor control board fault. Tachometer fault. Motor fault. Also check wireing from motor control board to motor. But this issue is not common at all with samsung.
Feb 15, 2016 | Samsung Washing Machines
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
What is error code E3 in washing machine Beko 91242 LC
This error code is below. Good luck to you:
E3
Constant heat
Nov 25, 2014 | Beko Washing Machines
The last two days I have the error message F1-E9 on my kitchenaide oven. I press cancel and it returns to normal. What does this mean?
F1-E9 - Stack Overflow.
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3.
Jul 15, 2011 | KitchenAid KDRS807SSS Dual Fuel (Electric...
Maytag laundry neptune front loader washer MAH6700AWW. It is showing a E3 code error. what can we do for that
Hi, the E3 error means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code comes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Jun 16, 2011 | Maytag MAH6700AWW Neptune Front-Load...
My washer has passed all the diagnositc test BUT when running through a simple quick cycle it keeps beeping E3
e3 means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code comes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 02, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Got the E3 code, replaced the board. The new board won' even fire up. Thoughts?
Turn the machine off and then on. Enter the Service Mode by pressing the Chime and Exrta Rinse keys for 3 sec. Display the Diagnostic Codes by pressing the Rinse and Spin key. Clear the codes by pressing the Delay and Chime keys for 3 sec. Turn the machine off, unplug and plug in the power cord. This dumps the memory. Evidently, if it gets full, it causes problems with the programming and messes up the cycles.
Jan 10, 2011 | Maytag Neptune MAH5500B Front Load Washer
I got an E3 flashing, what does that mean. The
Okay; This will essentially be a Hall Sensor fault. The Error code (E3) Is issued when the Motor control board is attempting to drive the motor (during the spin out), but is not seeing any tachometer response readings. The Hall sensor monitors such movements to relay the necessary rotation information to the Motor control board. When the Hall malfunctions, the MCB will assume that the motor is "locked" and it will issue the (E3) code.
The necessary actions are to replace the Hall sensor. Here is a picture of the Stator(Motor) and Hall sensor.
Click here to access the service/repair manual for your unit. This manual will help you disassemble the affected area. You will first need to remove the rear access panel, before gaining access to the affected section. Once the rear panel is removed, focus on page 33-34 to help with removing the stator so that you can replace the damaged hall sensor. Please allow time for the manual to download, due to its size.
  • Once you have replaced the defective Hall sensor, the unit will return to its normal operating status.
Jul 25, 2010 | Maytag Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
3,071 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
