SOURCE: 2001 Grand Am GT interior
a la mejor tiene malos los fusibles o se descompuso la computadora
lo mas probable es que se haya descompuesto la computadora del auto
SOURCE: 2001 Pontiac Grand Prix GT multifunction switch problem?
I had the exact same problem, I changed the "ignition switch" because the contacts inside were burned, this is why you see all those troubles coming in and out at different moments. It costed me 150$ to do it myself, buy the switch on an online reseller, must cheaper than the dealer! Now everything is back to normal on my Grand Prix GT 99 exept that my headlights don't light up automatically when starting the car... I have to check my fuse/relay and switch to make sure everything is ok on that side.
Good luck.
SOURCE: I have a 1999 firebird that keeps blowing
The most common cause for this to happen is if you are getting moisture in your lights. Check to see if that is the case.
