My top load whirlpool washer fills with water, pumps out the water, but will not agitate or spin
    President:
  • 1,902 Answers
Check your timer if nothing else happens it sounds like a timer problem.
Posted on Apr 18, 2009
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Whirlpool model SM 8525079 fills with water but will not agitate or spin
If you have motor sounds after water fill,but no agitation or spin it could be a broken direct drive coupling. If it will not pump out water,there could be something stuck in the drain pump.
Jan 17, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My whirlpool ultimate II washing machine fills up and agitate but does not spin or drains the water out. how can I fix it.
You have a bad motor. Your washer is a direct drive machine. It turns in one direction to agitate and the other direction to both spin and to pump. You have lost one direction in your motor.
Oct 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
WASHER FILL, NO PROBLEMS AGITATING, WHEN TIME
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is the Whirlpool PDF on installation and maintenance of direct drive washers. See the section on how to bypass the lid switch and on the transmission.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Following is an illustrated description of how to remove the cabinet on Kenmore / Whirlpool top load direct drive washers.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Since it won't drain, the problem points to the lid switch. You already have the cabinet off so replacing the switch isn't too difficult.
The Sears site has the Sears (and probably Whirlpool) part number.
Oct 08, 2009 | Washing Machines
Washing Machine does not agitate
Following is the Whirlpool installation and maintenance PDF on how top load, direct drive washers work with a troubleshooting section.
Following is the Whirlpool parts list for commercial top load, direct drive washers although the consumer washers are basically the same.
The problem seems to point to the Agitate Cams in the transmission that raise and lower the Agitate gear on the main transmission shaft. These are relatively inexpensive to replace.
I'd also check the splines on the main agitator shaft and the two pronged "washer" on top of it.
Oct 03, 2009 | Kenmore Washing Machines
Fills but will not agitate, spin, or drain, motor sounds strained
i have a whirlpool that go threw a wash cycle, but will not shin out the water
Apr 16, 2009 | Whirlpool LSR5132PQ Top Load Washer
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer does not agitate after filling with water
does it spin?
sounds like your coupling is broke.It takes the place of the belt if it breaks it won't spin or agitate. it will still pump though.
Part # 285753A
Nov 04, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Oct 18, 2008 | Whirlpool LSR5132PQ Top Load Washer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
