Question about Black & Decker 18 Volt Cordless Drill Driver W/ Charger
I can't loosen the part where the drill bit goes in. It's stuck!
  • 25 Answers
Try using a large wrench to turn the chuck. It may loosen enough to release the bit
Posted on Apr 19, 2009
How to remove bit stuck in kango drill
Hello, You might try spraying some wd-40 in the chuck to let soak and loosen up, to be able to turn and remove the bit.
May 15, 2014 | Drills
How to change drill
If you asking about the bit usually trap two hands around the head of drill where the bit goes in and twist hands in opposite directions to loosen, you will see a centre grasp of two or three which is where you drop the drill bit into or remove from. Do either of these add or remove then tighten the same way you removed. Make sure the drill bit is centre and straight and well seated within the grasps when tightening back up.
Jun 04, 2012 | Drills
Jaws won't tighten or loosen to hold a bit
Hmmm some times the counterclockwise screw that attaches the chuck to the drill come forward and that is how then it stucks the 3 parts that fix a drill to a chuck. Check if this screw come forward. If yes then destroy it and replace it... We destroy it by using a drill smaller than it (usually it is 5mm so we use 4mm bit and of course a CARBIDE one because even cobalt ones can not drill a hardened bolt)
Mar 26, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
Bit stuck in drill
OK, try to grab the chuck tightener and loosen by pressing lightly on the drill throttle button in whichever direction it takes to undo the stuck in drill bit.
I do this all the time.
Jul 13, 2010 | Ryobi 18v Variable Speed Impact Driver...
Bit is stuck / jammed. Can't seem to loosen. Any ideas on how to fix?
If the chuck is too tight to get the bit out you can either put a glove on one hand grab the chuck and run the drill in the reverse direction or if that will not work use vise grips or a small pipe wrench on the chuck to loosen it but be sure to tape the pipe wrench or vise grips with a thin piece of duct tape so you don't gouge the drill chuck.
May 23, 2010 | Black & Decker BD12PSK 12-Volt Smart...
Black and Decker corded drill won't tighten around a bit.
the chuck sounds like it is bad or maybe stuck from rust, what you can try and do is spray some WD-40 on the jaws and then try and holding the collar with a glove and run the drill SLOWLY in forward/reverse and see if it loosens up if not you will need a new one.
Jan 14, 2010 | Black & Decker Drills
How to change the drill bit for a Dewalt DW995
That tool comes standard with a keyless chuck so all you should have to do is grip the collar and turn it to loosen bit. If it is stuck you might try a rag of some sort on the collar and use the motor to loosen it up. Let me know if you need more help.
Jun 23, 2009 | Dewalt Drills
Black Max 24v Cordless Drill/Driver Model 33643-24v. How do you insert the drill bit? I can't "unscrew" the top and am sure I'm doing it wrong...(as it doesn't work)
grab the top by where the drill bit goes in and press the trigger on the drill motor. The direction of rotation will tighten or loosen the Jaws of the chuck.
Jun 14, 2009 | Mx Black Max 24v Cordless 1/2 Inch Drill /...
Chuckless drill stuck tight with drill bit in
if you trap the chuck in a bench vice or alike and then use the drill in reverse in short bursts until it loosens a good spray with wd40 will also aid the situation
Mar 09, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Chuck will not release bit
the Chuck should be 2 Part.
Use 2 pair of stillsons Or pipe wrenches, Tight On the 2 Chuck Parts, Crack in opposite Directions.
Alternative, Use Wrench On Chuck Jaw, Short sharp Blow With Hammer.
Mike @ compurepair.
Feb 28, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Black & Decker 18 Volt Cordless Drill Driver W/ Charger Logo
430 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
