Question about Garden
John Deere 445 lawn tractor is leaking coolant
It is leaking significant amount of coolant around water pump, have replace gasket, but is still leaking?
  • parkeyus May 03, 2009
    Wow, no answer...thanks a lot!
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 197 Answers
This model has a weap hole just under water pump.If it leaks enough it will stain front cover just to the side of crankshaft.Do not buy the rebuild kit,just replace pump.
Posted on Nov 14, 2009
How do i check my hydaulic fluid for my 445 tractor
JD Mower Maintenance - YouTube
? 16:56
https://www.youtube.com/watch?v=RYeP_QLhsoU
Mar 31, 2013 - Uploaded by GreenMachine757
Doing routine maintenance on my John Deere 757 zero turnmower. ... DIY Mower Seat Repair - Garden Tractor Seat - Zero Turn - eXmark ...
John Deere Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages6/
Service Transmission - John Deere Ag - New Equipmentmanuals.deere.com/cceomview/OMM144042.../OMM144042_D010.ht...DO NOT mix oils. These tractors are equipped with a hydraulic wet disc PTO clutch.... DO NOT use type "F" automatic transmission fluid. John Deere Low ...JD 445 Rider Mower Issues - Need Help Please - GardenWebforums2.gardenweb.com > Garden Forums > TractorsNov 12, 2009 - But I've read a lot of threads hoping to read about my issues, and was ...What tools I don't have my friends do, and both are real mechanics, big Deere fans ....it steer hard due to lack of fluid in the hydraulic steering cylinder. ... You may need to add fluid, run the tractor around a bit, and then check it again.
Jan 09, 2016 | John Deere Garden
I have a john Deere 445 garden tractor with a coolant leak up by water pump. Would this just be a gasket or does it have a weap hole
Check hoses before you tear anything apart. The water pump could be bad as I don't think there should be any moisture around anything. Bad hose will leak some times where they fasten on the pump or could just need to be tightened.
Good luck.
Apr 15, 2015 | John Deere Garden
My 1995 6200 John Deere is running hotter than normal. Done coolant flush. Blown out aircleaner, washed out radiator fins. Whats next?
IF YOU ARE NOT HAVING WATER BLOWING OUT WHEN YOU START IT IT PROBLEY NOT HEAD GASKET I WOULD LOOK AT WATER PUMP THE IMPALER COULD BE BAD IN THE WATER PUMP
Nov 10, 2012 | John Deere 6300,6300l,6400,6400l Tractor...
Where is the drain plug for a Jon Deere 445 lawn tractor
most have a drain fitting next to the dip stick tube its a black cylinder you push in and turn to drain has a small nipple on it to slide on a small hose
Mar 31, 2012 | John Deere Garden
How can I tell the year of my John Deere 445 lawn tractor. Product # M00445C096237 ?
1993: 010001
1994: 020001
1995: 030001
1996: 040001
1997: 050001
1998: 060001
1999: 070001
2000: 080001
2001: 090001
http://www.tractordata.com/lawn-tractors/000/0/4/45-john-deere-445.html
Mar 10, 2010 | Garden
John deere 445 tractor v twin 22 hp engine, john deere k series, no compression, removed valve covers and valves not moving, is there a timing chain, gear ?? or what drives the cam? Do you think the cam...
The cam has broken, this is a common problem with the 425/445. The cams are very cheap, made with plastic. Had mine replaced last year at the cost of about $300. Had water pump replaced as well.
Apr 01, 2009 | Garden
Garden Logo
669 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
