Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Blades are engaged,but won't cut the grass
All the belts are attached, the blades rotate when I turned them with no problem, BUT when the mower is going it doesn't cut the grass
  • 1 more comment
  • charles raynor May 11, 2010
    Are the blades installed properly? upside down blades will turn, but not cut grass.
  • Rick Reichlein May 11, 2010
    Do the belts rotate when you move the blades?
  • Anonymous Mar 21, 2014
    cutting bade shaft turns without blade attached but will not turn when blade is attacheched
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 109 Answers
Check the blades to make sure that they are not upside down
Posted on Apr 24, 2009
My craftsman DLT 2000 won't cut grass , the pulleys are clean n moving the blades are rotating but when I let the deck down to cut the grass it stops and sounds like the belts trying to turn, making the...
be sure the blades are not bent and you dont feel any wiggle when pushing them up and down. be sure nothing is wrapped around the spindles. be sure the belt isnt damaged and tight when the deck is engaged to cut with the engine off.
Sep 18, 2017 | Garden
Why does the engine slows down when engaging the blade
check fuel filter and pump pressure starving for gas
Jul 02, 2014 | John Deere Garden
Zero turn mower is sputtering and dies
Check everything is clean. Check the air filter is clean, check that the engine cooling fan, cutting blades and cutting deck are free of grass. Check all the drive belt pulleys to ensure accumulated grass is not jamming anything. Check the fuel filler cap is clean and the breather hole works.
Jun 27, 2013 | Husqvarna Zero Turn Mower Z5426
Need a troubleshooting manual for a craftsman mod. 917.287070
Went out to cut grass and the blades will not engage and when I put it in gear it does not move. Belts are intact. I cleaned the deck of dirt and grass. Still nothing. Just replaced the cable to engage the blades last year. Cable seems to be working.
Jun 25, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
When I engage the blades on my ez4824 the blades intermittently stop cutting particularly in higher grass. Do you think this is a loose belt problem? Thanks.
That is the most likely cause of the problem - taller and thicker grass the blades encounter more resitance and the drive belt slips and it doesn't cut. This would likely cause a juddering of the machine when it occurs.
Hope this helps.
Jul 11, 2011 | Husqvarna EZ4824 24 hp 48" Zero Turn Lawn...
The mower blades engage when the PTO is on, but don't rotate fast enough or cut grass
Check the belt to the mower deck, it more than likely has stretched and needs replacing or you may need to adjust the tension.
Aug 01, 2009 | Garden
Mower blades not engaging
is the mower belt on the pulley ?
Jun 12, 2009 | Garden
Lots of smoke when I engaged stuck blades - now runs roughly
Most likely what you did was burn one or more spots on the belt. When the blades and belt stop turning, like in tall grass, the engine doesn't stop and will burn flat spots on the belt at the engine pulley. Every time the flat spot hits a pulley, it will jump and can set up a bad vibration. Run your hand around the sides of the belt or take it off and you will feel or see the thin spot(s) on it. Replace belt.
Jun 09, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 18.5 briggs/str 42''won't cut
It sounds to me like a very loose belt or very worn out belt and also an adjustment problem.
Mar 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Tractor?troy bilt/mtd 2002
the electric clutch that operates the blades needs replaced
Sep 22, 2008 | Garden
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
488 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
