Question about Symantec Norton AntiVirus 2004 - (Open Box) for PC
GHOST ERROR CODE
I got a error code-19205 during make an image.Pls send details
    Sergeant:
    Champion:
  • 293 Answers
If you are refering to Error: "19205 Compression error -4 while creating a spanned or split image" this is a bug on Norton Ghost. It has no Fix. You may try using a Larger Size settings for your image to remove the need to split images. Also try saving the backup file on a larger HDD. Try using a higher version or Use Acronis Disk Image instead. Its a lot stable than NGhost.
Posted on Sep 18, 2007
SOURCE:
88 error code in samsung split ac
What is the OS of your phone.
Aug 19, 2017 | Samsung Cell Phones
WD 73835 has ghosting images during dark or red scenes
Make sure your contrast isn't set too high. Most ghosting is caused by either contrast, brightness or tint issues. Try adjusting these settings. Also check if there is a Dynamic contrast setting for your TV as well as this can cause ghosting also.
Apr 06, 2014 | Mitsubishi Diamond 835 Wd-73835 73" 1080p...
I have prescott 533 mother board also having XP SP3. but i cant installd sound driver. pl send the audio driver download link.
try http://rapidlibrary.com/index.php?q=prescott+533+driver+download
make a ghost image using norton ghost before installing any sound driver. if you installed already any driver, reinstall your windows. the sound driver keeps some files that are very difficult to delete.
if the drivers from the links are not got, reply and i will search different ones
Oct 25, 2009 | MSI : 865PE Neo2-PLS P4 Prescott FSB800...
How to Default Duplex Scanning
  1. Image Scan Can not be Found.
  2. please check and Cable connection
  3. and the scanner is not used by other application.(Code:DS42019)
THIS THREE ERROR WILL SHOW AT MY SCANNER.
AFTER PUT GHOST IT WIL SLOVE.OTHERWISE WIL NOT SLOVE.
COULD U PLS GIVE SOLUCATION
Jul 02, 2008 | Fujitsu fi-4120C Path-Through Scanner
Ghosts
pls turn on your unit & open fc in front of mirror pls plug all compenented with pcb & panel & after some time the image will be clear
Apr 16, 2008 | Samsung HCM5525W 55" Rear Projection...
Ghost image on sony lcd 5 years old
This problem is a defect in the optics block. There is however an adjusment procedure to correct this problem. Please send me and email to [email protected] and I will send you back the detailed alignment process on Monday.
Feb 23, 2008 | Televison & Video
Error code
Hi Sorry cant send manual U have to buy like every one else.But here are the codes you require It is service code 24 sub code 04 to reset PM counter and sub code 07 to rest drum sub code 09 to reset print count and sub code 11 to reset developer. Hope this helps
Aug 18, 2007 | Sharp AR-5316 Advanced Digital Imager...
Open Questions:
Symantec Norton AntiVirus 2004 - (Open Box) for PC Logo
136 people viewed this question
Top Symantec Computers & Internet Experts
Peter Dragonetti
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
