Question about Home
Spa air button cable has came off, how do i attach it again if i cant reach behind the spa call i pull the button out or will it crak the spa
  • 659 Answers
You will need to pull the apron. If it is faux marble, you will need to be careful not to break it. Usually the apron is only held on by silicone adhesive.
Posted on Apr 18, 2009
Replace aqualink spa side switch
unplug the spaside plug from the bezel board tape a strong string to it remove spa side remote at spa and pull the cable back through the conduit attach the new wire to the string pull it back through to the aqualink then hook back up to the plug then plug back in
Apr 21, 2013 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
96 chevy s10 hood release cable broke need to open hood
On my 2002 s10 the small clip on the hood latch where the cable end attaches to the lever was broken.I finally drove a 3/4" mop handle and by prying,forced the grill down enough to unbolt the hood latch and after messing with it for a while I was able to reach behind the latch and press on it enough to drop the latch off the pin.Sure hope I don't ever have to do it again.
Jan 18, 2012 | 1992 Chevrolet S-10
Hayne's Manual for 1986 Taurus lead me wrong! After removing everything I can, I still cannot "reach up behind instrument panel" and even come close to touching the speedometer cable connection....
if its a manual cable you just unscrew from transmissionwill be at your gearbox and remove all cable ties holdinding outer cable might give ya enough slack to remove from dash end
Jan 30, 2011 | Ford Taurus Cars & Trucks
How do you remove the steering wheel on a 2000 Chevy Silverado?
Reach behind, there are 4 screws. Remove these screws and pull of air bag assembly. Make sure negative battery cable has been disconnected for 10 minutes and SRS fuse has been pulled. Once the air bag assembly is off, pull the horn wire off, then remove steering wheel nut and washer and pull of the wheel.
Good luck...
Jan 16, 2011 | 2000 Chevrolet Silverado
How do you remove the steering wheel on a 2000 chevy silverado
Oct 27, 2010 | Chevrolet Silverado 1500 Cars & Trucks
I cant get the hoodlatch on my 91 chevy prism to release
if it's the cable and not the latch you'll have to replace it anyway, so instead of removing the grill, cut the cable behind the pull lever under the dash where you can reach it. then skin the outer cable insulation away from the actual steel cable exposing an inch or two of it. then holding the insulation and plastic housing with pliers, grab the steel cable itself with pliers and pull it to open the hood. then replace the cable. the further you can reach up under the panel the better your chances of getting past the broken part of the cable and avoid removing the grill. you might also be able to gain access from up under the car if you're lucky.
Aug 05, 2010 | 2001 Chevrolet Prizm
Cable broke on hood latch of 95 cherokee cant get hood to pop
first, try smacking the hood at one of the front corners while someone else pulls the release handle. or even after you've pulled on it. if that works, once open, adjust and lubricate the hood latch assembly. if it still won't open, and it's the cable and not the latch you'll have to replace it anyway, so instead of removing the grill, cut the cable behind the pull lever under the dash where you can reach it. then skin the outer cable insulation away from the actual steel cable exposing an inch or two of it. then holding the insulation and plastic housing with pliers, grab the steel cable itself with pliers and pull it to open the hood. then replace the cable. the further you can reach up under the panel the better your chances of getting past the broken part of the cable and avoid removing the grill. you might also be able to gain access from up under the car if you're lucky.
Jan 28, 2010 | 1995 Jeep Grand Cherokee
I cant take the car seat off the frame
i have the maxi cosi car seat and had the same problem. try this: reach behind the circular attachments that bind the car seat to the stroller and feel around for a small button. i couldn't see back there but could feel it. you have to click this and remove on each side. a little bit of a pain because you probably can't click both buttons and pull up all at once, so for me one side kept slipping back to the engaged position, but eventually i got it. best of luck.
Aug 22, 2009 | Quinny ZAPP Stroller
Fuel filler lid wont open on button push- Toyota Avensis 03
no moter on that if you are going in trunk an reaching in to pull cable and it opens.try bending the latch an gas door lock. pin is going in to far
Jun 04, 2009 | 2003 Toyota Camry
How do I recharge air conditioning system on a 2004 Ford Focus SE?
The low side fitting you hook to is not under the hood(Not in engine compartment)To charge ac you MUST attach charge hose to fitting on the side of the aluminion acumulator LOCATED behind right (pass) headlight, reach under fender in front of right front tire, behind bumper.BELIEVE ME it is there, on side of tank. Reach under and feel for it.
Jul 26, 2008 | 2000 Ford Focus
Home Logo
127 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
