Question about KitchenAid KUDS24SE Built-in Dishwasher
Kuds24se dead We have a 7 year-old KitchenAid kuds24se dishwasher. This morning it would not turn on. All lights on the control panel are out. I have verified the power and water supply. Any advice other than calling for a repairman? I am handy, have multipurpose electrical meter. Thx
  • 1 more comment
  • t1062 Sep 19, 2007
    Can you refer/provide me with more detailed instructions on how to do this?
  • t1062 Sep 21, 2007
    Expert suggested "HAve you check the power supply to the control panel? you may need to open the panel and check the circuit."
    Please tell me how to open the panel and check the circuit.
    By the way, the dishwasher went DOA after starting a wash cycle (we don't know which part of cycle)
  • Anonymous Mar 16, 2014
    clean light
  • 725 Answers
Check the black and white wires that come from the plug. be careful but it sounds like a bad control..
Posted on Sep 22, 2007
  • Franklin Ouchida
    Franklin Ouchida Sep 29, 2007
    you have to open the inner door there are screws on the inside of the door. remove them separate the doors there is a box that covers the controls it should just snap off or my have a screw that holds it on. check for burned/black marks on the circuit boards the black is the hot side and the white is a neutral .. also check power to the door switch... and check the door switch for continuity with the power off.. if the door switch is not working it will stop all the power to the dishwasher.
    Master:
    Sergeant:
  • 461 Answers
Posted on Sep 18, 2007
SOURCE:
Start button not activating my kitchenaid sculptura dishwasher
Yes the control panel (also called switch panel) can be replaced.
Refer this site for details. You are probably referring to item 3 in the diagram.
Oct 30, 2011 | KitchenAid KUDS24SE Built-in Dishwasher
KUDS24SE KitchenAid door latch broke. How do I take the door apart
If the door cannot be opened, remove the the outside lower panel. (2 screws at bottom of panel, then lift off. Take a long screw driver (be sure power is removed first!) and push up behind the control panel at the latch at the very top middle of the door. You can them open the door and remove the screws that hold the control panel on. When the control panel is removed you will have access to the door handle and latch pieces. These parts can be ordered through sears partsdirect web site. Good luck.
Jan 09, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
Should I have kitchnaid KUDI01IL circuitboard replaced or buy new
unplug it and call a qualified repairman to give you an estimate and then choose what to do
Apr 16, 2009 | KitchenAid KUDS24SE Built-in Dishwasher
GREEN LIGHT FLASHES
when the green light comes on open then close the door its to remind you there are clean dishes in the washer and opening the door acknowledges this
Jun 01, 2008 | KitchenAid KUDS24SE Built-in Dishwasher
How do I change door panel and disconnect the control panel?
I am actually looking a stainless steel panel myself. Where would you able to buy one?
Apr 30, 2008 | KitchenAid KUDS24SE Built-in Dishwasher
KUDIO1ILBS2 KitchenAid Dishwasher, two years old, not heavy usage: control panel is dead, no other power problems in the apartment, the apartment's electical box shows all breakers ok.
These dishwasher have a thermal fuse near the contol panel protecting the heat sensitive computer. Do you use the Sanitize or Anti-bacteria cycles?? If so then these cycles get very hot and could have made the fuse blow. Kitchenaid also had some loose connection problems at the fuse making the fuse heat up due to the electicity and not actual temperature. The new fuse comes as a kit with connectors already attached to the fuse (dont mess with them) and a junction block to splice the wires.
Jan 18, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
Removing the detergent dispenser
I have the same problem--mine is about 10 years old. To disassemble, looks like you will need to disassemble the complete door--screws around the inside edge of the door. At that price for a replacement dispenser, I will either try to fix or replace the blue arm, or replace the dishwasher. I don't believe its worth putting that kind of money in an old dishwasher.
Lew
Dec 10, 2007 | KitchenAid KUDS24SE Built-in Dishwasher
KitchenAid kuds24se dishwasher DOA
We had same problem - took dishwasher out from counter and found it to be unplugged way way in the back 1
Sep 21, 2007 | KitchenAid KUDS24SE Built-in Dishwasher
No lights on panel and will not start
Pull panel off and check thermal fuse for continuity,probably bad.
Jun 07, 2007 | KitchenAid KUDS24SE Built-in Dishwasher
Dishwashers Logo
376 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
