Question about Vacuums
Dyson DC05 problem with filters.
My dyson DC05 has good suction but the dirt is not going into the clear collection unit, it is gathering around the filter in the top of the machine. I have cleaned the filter and replaced it when dry. still no luck...HELP PLEASE!! Thanks, Kate.
  • cjmeredith1 Apr 19, 2009
    You are exactly right my friend. Looking at a blow up of the parts, the complete bottom half inside the collection bin is gone. Er indoors must have emptied it into the bin, New one on order. £23.00
    Women ! Can't live with them, Can't kill them.
    Many Thanks.
  • Philip Gaut May 11, 2010
    Hi!  I'm posting this as a clarification request rather than a solution because I'm not sure if I can help. But here's what I think...
    First, and for sure, the problem is in the collection unit (CU), not the filter.  Is it possible that something is missing from the CU?  When you remove the CU to empty it, and you lift off the top, a conical yellow part remains attached to the inside of the lid; another yellow part remains in the bottom of the CU, with a big black rubber seal on top.
    I think the problem you describe will occur if that black rubber seal is missing, displaced or damaged (perhaps it dropped out with the dirt and you didn't notice).  A healthy seal between those two yellow parts inside the CU is essential.
    Please let me know if this helps.  I can then post it as a solution so it helps other people.  If it doesn't help, also let me know and I'll think again.
    President:
  • 389 Answers
Please rate my response if this helps.  If it doesn't help, also let me know and I'll think again.
Posted on Apr 19, 2009
  • Philip Gaut Apr 19, 2009
    Thanks for your feedback.  I'm happy to be of service, and it's always good to know when one gets it right (although I never guessed the whole lot would be missing)!  Please be kind enough to rate my response.
I purchased a Dyson DC05 cleaner from a garage sale.The suction is great,however I noticed that the debris does not swirl around in the cylinder when I am vacuuming.I think the suction could be even...
Hi there VacuumGuru from Vacuumspot.com.au here. You will find there are 2 reasons will not spin in a dyson DC05. 1 is that it is missing one of the 2 parts in the dust container, there should be an upside down funnel in there and a rubber boot on it. Without those dust just goes either to the bottom of the bin or to the filter. The 2nd cause is that even though the filters have been cleaned they are simply too old. When you hold the washable filter (the one with the plastic outer and the foam insert) up to the light and take out the foam bit you should be able to see light through the filter. If not you are probably only running on maybe 80% suction which still works but isn't as good as it could be.
The filters are available here if you need them.
Hope this helps! :)
Oct 06, 2010 | Dyson DC05 Cylinder Bagless Canister...
Have lost Manual to DC05 and I am unsure how many filters there are that need to be cleaned as I feel it has lost some suction.
Hi there VacuumGuru here. There are 2 filters for your machine, one is below the dirt chamber and the other is underneath the handle. If you have lost your suction it is most likely the washable filter that is to blame. There is a manual available for free download here as well to help you out.
Basically when ou remove the spongey blue insert from your washable filter you should be able to hold up the other bit (white with a coloured plastic collar) to the sun and see light through it. If you can see no light then it will need to be thrown out and replaced.
Hope this helps!
Sep 23, 2010 | Dyson DC05 Bagless Canister Cyclonic...
Dyson DC05 top filter keeps clogging even immediately after cleaning it. Does anyone know why ?
Hi there VacuumGuru for Vacuumspot.com.au. I would say that you are missing a part out of the vacuum dirt container. There is supposed to be a part a bit like an upside down funnel with a rubber seal on the end of it. Without this dirt will go straight to your filter. If you need any vacuum cleaner parts just go to Vacuumspot.com.au.
If you think this is a good solution please rank it!.
Regards Guru
May 01, 2010 | Dyson DC05 Cylinder Bagless Canister...
Weak suction on dyson dc05. The suction is not as good as usual
Hi its Darran at Dyson.
Try washing your pre filter and checking the machine through for a blockage. These are the most likely causes.
A full blockage procedure and filter washing instructions can be found at www.dyson.co.uk/support.
Kind regards
Darran
Dyson Customer Service
Feb 16, 2010 | Dyson DC05 Bagless Canister Cyclonic...
Dyson dc05 takes the dirt up the cyclone cone instead of spinning it in the clear cannister and blocks the top filter within a few minutes??
From your description of the problem, it sounds as though the bin inner is missing. If you remove the bin and cyclone assembly from the machine and then seaprate the two pieces as if you were going to empty it, you should have a coloured piece of plastic in the bottom of the clear bin with a large black rubber seal around the top. If you dont, you will need to purchase a new bin assembly via our website at www.dyson.co.uk or via our Helpline on 0800 298 0298.
Kind regards
Darran
Jan 19, 2010 | Dyson DC05 Bagless Canister Cyclonic...
Dc 05
I assume you have confirmed that the hose is not partially blocked at all. With it removed from the machine, try running a small round stone from one end to another to see if it is totally clear.
Secondly, the filter on top of the machine (the one you see when you empty it), this needs to be cleaned/washed on a regular basis - follow the instructions on the filter.
Thirdly, does the lack of suction apply to all the attachments? If it is the carpet attachment, this does become clogged up with hair etc winding itself round the brush and the internal drive unit in the head, thus slowing it down. Also dirt and dust cloggs it up inside the head as well. It is posible to take the head to bits to clean it.
Jan 16, 2009 | Dyson DC05 Cylinder Bagless Canister...
Dyson Animal
Obstruction in the hose?
Your vac has developed a hairball possibly.... when a piece of flexible media ie.... cardboard, plastic etc... gets lodged in the hose, and begins collecting hair & dust to the point it no longer has enough draft to pull debris from the floor.
Here is a video that you may find useful
http://video.aol.com/video-detail/dyson-not-picking-up-dirt-no-suction-how-to-repair/2334249387
PS I Thought DYSONS were guranteed to NOT lose suction? What a RIP!
Jan 06, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Poor Suction
I recently bought a second hand Dyson DC07. Its suction was poor. I removed all the un-clipable pipe bits and to remove any blockage but it all looked clear. The Final Sponge and hepper filter did have a lot of dust in it and the rotating brush was full of hair but nothing bad.
I eventual gave in to curiosity and removed the three screws in the top or the yellow removable dust collection tube and cyclone bit to see what was in there. The mechanism to release the flap at the bottom of the collection tube does not allow you to remove the lid completely but it does open far enough to get inside. I found the whole top section of the yellow plastic bit blocked by a big plug of compacted dust and a champagne cork. If you are willing to take the risk and have a torx 15 screwdriver handy it that part may be blocked. It did get a bit messy.
If I was going to attempt the same procedure I'd remove the dust collection unit from the vacuum cleaner as I did before, but leave the clear tube attached and the emptying flap firmly closed to reduce the mess from the dust falling out the bottom while cleaning the top part.
Oct 23, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson dc05
your vacuum is not picking up because the infamous dyson has lost suction "which they claim to not do" first you have to make sure the filters are taken out and cleaned, then check the hose and make ure there are no clogs in there. usually they are see through so they will be visable. also make sure there is no debre blocking the cones on the machine
Sep 12, 2008 | Dyson DC05 Cylinder Bagless Canister...
Dyson lsoing suction
Hi.
Turn the 3 plstic screws under the machine to unlock position & remove sole plate,
You can now see if belt has snapped & replace it.
http://dysonmanuals.inc.io/
Chris.
Nov 21, 2007 | Vacuums
Vacuums Logo
148 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
