5.5 HP GX160 Engine Logo
Alan Bothma Posted on Sep 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to restrict the engine, or un-restrict. I have a GX160 and its tuned for racing but I was told it was restricted, So i was wondering how one would do such a thing.
Pete Maisey
Level 2:
New Friend:
  • Expert 51 Answers
  • Posted on Oct 04, 2013
Pete Maisey
Expert
Level 2:
New Friend:
Answers
51
Questions
Helped
20602
Points
112
tip
How to tune / de-restrict a 2 stroke
2 strokes in lower ccs are usualy slow, so heres a list of things you can do to de-restrict and tune your 2 stroke.
1) Get a racing exhaust, Key part too most 2 strokes is a good exhaust, this will remove some restrictions. Gianelli, Big One, fmf and many others are available on ebay or your local bike shop.
2) Big Bore kit, adding a big bore kit can give up to 30% more performance, and will usualy de-restrict the bike. search ebay for (Bike Model) (year) Big Bore kit. it will come usualy with everything you need for the upgrade.
3) Carbon Reed Valves, are a key part too your acceleration, also removing the little cages that stop them opening all the way and replacing with big washers is another good step, make sure theres nothing for your reeds to nock on when removing the cage.
4) Boost Bottle, a boost bottle will help 2 strokes with no reed valves more then reeded bikes but will give alot more low and high end performace. search ebay for (bikes cc) boost bottle.
5) Jets, are a key thing when getting a bore kit or race exhaust. you MUST change the jets if you change exhaust, get bigger ones if you get an exhaust go a few sizes over and check the spark plug if its a brown tan/ grey collor you got it all right, if its black it means you have to much fuel so go smaller, and if its white it usualy means not enough fuel. you can buy jets from any motorcycle shop usualy around $1 a peice. you onyl need to change the Main jet.
6) Air Filter, you dont need it on most bikes but it could add extra acceleration, measure your carbeurator intake and search it on ebay for a K&N style filter, Power filter.
7) Restrictors in the intake, some 2 strokes have restrictors between the carb and the cylinder, it is key to remove these or drill them out to the size of the carb/ cylinder hole size.
8) Sprockets, if your lucky enough to have a chain and sprockets, its a nice trick to change sprockets on your bike.
For Top Speed - Bigger front sprocket & smaller rear sprocket
For Acceleration - Smaller front sprocket & bigger rear sprocket
by bigger or smaller i mean more or less teeth on the sprocket. if you go for speed your acceleration will lack and vice versa if you go for acceleration you will loose top speed.
9) Electical Restriction, Some bikes are restricted in the CDI, if yours does not want to reach a good RPM search up CDI, de-restriction. usualy it involves cutting a wire between the CDI and engine. and will unlock that slow engine into a screaming 2 stroke.
If you follow all these steps your 2 stroke will no longer be restricted and slow and will be the fastest arround.
on Feb 16, 2010 • Motorcycles
3answers
This is a honda gx160 driving a generator. Engine starts OK but when any load is put onto generator engine splutters then stops. Display says low engine power. Any ideas?
check oil level .low oil causes vacuum in the carb, causing fuel starving .
also check capasator has not blown in generator .
1helpful
Why do none of your so called experts know how to de restrict an a.j.s.125 dde, or even answer if it can be done
different bikes restrict by different means, sometimes smaller carbs are put on other times the jets are just changed to a lower width, the exhaust shape can restrict airflow from the engine. sometimes the airbox restricts flow into the engine. so first stop is check how high a jet you can get for carb, maybe get a jet air filter racing kit.may need to change exhaust for a power pipe. you can put a bigger sprocket on front end for less accelleration but higher top end or smaller for higher accelleration. you can put a bigger sprocket on back for greater accelleration loosing top end. you could change the piston for a higher compression piston and/ or have the head skimmed. the list goes on and if its a 2stroke there's reed valve to play with.
Mar 18, 2013 • Motorcycles
2answers
Is a restriction code my imei 353377041042255 i think this is no payment
Restriction code mostly asks for Nokia Mobile Phone@!!!Your Phone is Nokia?what Model,?Because it locked to network so it asking for restriction code...
If your Nokia mobile phone displays Phone Restricted with an Undo option and selecting Undo results in an Enter Restriction Code error, your Nokia mobile phone is Network Locked. This means your Nokia mobile phone has been restricted for use on one specific network and a Restriction Code or Unlock Code must be entered before the phone can be used with alternative networks.
You can get the Restriction code from here Classicunlocking
Aug 25, 2011 • Cell Phones
How do you un-restrict someone
When you are signed into Facebook, do the following:
A. Click on 'Account' (Top right of screen)
B. Click on 'Privacy Settings'
C. Click on 'Block List'
From here you should be able to see any people that you have blocked and un-block them.'
Good Luck
1helpful
Do i have to change the cdi unit to get full power
thats right the cdi lmits the revs of the engine via the coil and the stater plate you need a unlimted race cdi box you can pick these up from ebay they are not that expensive hope this helps ben
4helpful
3answers
My honda gx160 generator keeps cutting out after 2 mins
Sounds like fuel flow is restricted.
Is the vent cap on the gas tank clear?
Pull the fuel hose off at the carb and let run into a container from the tank......is fuel flow good while filling a cup or two worth of fuel?
If not check filter at fuel switch or at hose connection at tank for restriction.
It takes about 2 minutes to use up fuel in the carb with engine running.
Sure sounds like a fuel problem.
1helpful
2answers
Asks for restriction code for nokia t-mobile 2610b
salut j*ai un nokia 2610 b l*horse que j*allumer il ma demande code de restriction svp envoyer moi ce code ce tel vien de usa et je veux utiliser en maroc merci. type rh-87 ic 661ab-rh87 imei:011673/00/355095/2 code:0565017hp204v
Top Honda Vehicle Parts & Accessories Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
