I get no sound from my speakers with amp/pre-amp setup
I get no sound from my speakers with my Anthem MCA-50 amp / Integra DHC-9.9 processor setup. However, I do ''hear'' some low level white noise when the speaker is connected to the amp via the binding post. I've tried connections with unbalanced RCA audio cables and balanced XLRs between amp and pre-amp without success.
Here is what I've already tried:
1 - Amp does indeed have power
2 - Checked the 2 fuses attached to the amp, they look brand new
3 - Used different cables between amp and pre-amp (both balanced XLR and unbalanced RCA)
4 - Used different sources to test for audio, i.e., DVD, CD, tuner -- no sources result any sound thru the speakers
I still believe it's a connection problem between amp and pre-amp. But am not sure what else to rule out.
  • shawnmandel Apr 18, 2009
    Thanks very much for your suggestions. This unfortunately confirms that it is probably a transistor output stage problem since I get no sound still when attempting to listen to a CD via digital coax connected directly to the amp.
  • 10,515 Answers
Hi Shawnmandel,
As you have already confirmed the fix, If the output transistor(s) are defective you must replace both of them. While at it, might as well replace the transistors in the good channel, too, as they may be ready to give up the ghost, in this case.
You can also close this thread by selecting 'Fixya'...
Thanks for using Fixya.
Do rate the solution as 'Fixya" if 100% satisfied................
Posted on Apr 18, 2009
  • 19,396 Answers
If the Amp (the MCA-50 amp / Integra DHC-9.9) has no sound out apart some low level static on all conditions, then it is likely a faulty amp because the amp final transistors had blown.
To start unplug all connections from the Amp, and unplug home theater from power for five minutes to reset it .
Test a CD unit on TV to ensure it has sound, and then connect to the amp using no pre amp, digital input connection for audio only, then play an audio cd, see:Digital Audio Connection (Coaxial).
If you still get no sound browse manually the source, but it should be selected automatically when you start DVD unit.
If still no sound under the conditions above, then amp is faulty.
If instead the amp works on conditions above, then test placing the preamp in the middle (CD/DVD signal is already pre amped, you would not need this, unless you want to use preamp graphic equalizer or similar functions). If it does not work this way , then the pre amp must be tested.
How to hook up bose 901 active equalizer to onkyo grand integra pre amp?
You don't.
If you have a pre-amp/power-amp combination then the Bose equalizer connects between the two. If you're using the Bose speakers as front L&R, then the connection is between the front L & R pre-out and the power amp's front L & R pre-in.
Sep 01, 2014 | Audio Players & Recorders
Cracking and poping with Yamaha surround sound system
Try put a ground line from any metal of your stuff to the any metal direct to the ground. these eliminate noise of the speaker.
Jan 03, 2008 | Pioneer VSX-54TX Receiver
How to fix Integra 7.8 display is dead
They will be value of 10 ohms or less in the secondary power supply attached to the front assembly
Jul 20, 2014 | Integra Dtr-7.8 Receiver
Integra DTR-5.6, no sound for am/fm tuner
reset receiver if that does not work You will have a defective processor pcb
Aug 24, 2013 | Integra DTR 5.6 Multi Media Amp
No problem, just advice, have the 7270 reference II amp, what audio cables do you guys recommend (manufacturer/model) I am only going to do this once, want to do it right. Mating it up to a Integra DHC...
With these it all depends on your budget. Some shops will let you try them out for the best results also. If you are in the UK have a word with the guys at Richer Sounds, they will sort you out. Elsewhere try and find a place that will let you try before you buy. After all it's all personal choice, your hearing isn't the same as me or anyone else's.
The link will take you too Richer if any good to you.
http://www.froogle.richersounds.com/products/hi-fi-separates/accessories/hifi-interconnects
May 20, 2011 | B&K Reference 7270 7-Channel Amplifier
Hi I have just got a JBL SCS200.5 BK, 5.1 loud speaker system. I am having the following problem with connecting the loudspeaker system. 1. I have a satellite TV reciever with a single Left, Right &...
I guess you didn't get the owner's manual, huh?
http://www.jbl.com/HI-IN/Products/Pages/ProductDetails.aspx?PID=SCS200.5BK/230
Where are the amplifiers in this scenario?
Page 8: The sub needs a subwoofer Line Level pre-out from an AV Receiver or multichannel processor. Though not elaborated on in the manual, the L and R Line Level RCA connections are probably for use if you lack a Sub Out feed. Running L and R from your receiver would allow the sub to derive a Sub Channel.
The rest of the speakers would connect to the AVR's speaker outputs.
Pasge 9: Alternate method if your eelctronics lacks a volume-controlled sub pre-out. This method routes only the front speaker level power to the sub so it can extract something resembling an LFE channel, then it routes speaker wire out to the front speakers, not as an audio power source but simply as a pathway.
You still need amplifier channels for all but the sub.
Apr 25, 2011 | Audio Players & Recorders
No output to subwoofer per-amp
you may have to go into the onscreen menu and enable it,that shuld work
May 11, 2009 | Integra DTR-8.3 Receiver
Speakers are connected to pre-amp or power-amp? pls explain connections , what connects with what , between cd player + pre amp + power amp + speakers.
Do this, CD audio out jacks to the PRE-AMP INPUT jacks, then PRE-AMP OUT jacks to AMPLIFIER INPUTS then from AMPLIFIER to speakers, This will work similiar with any sound source unit ie. Radio Tuner, Tape deck, etc. Just think of it this way, a PRE-AMP is BEFORE the AMPLIFIER, all the AMPLIFIER is going to do is AMPLIFY the sound to your speakers, HOPE THIS HELPS!
Feb 03, 2009 | Audio Players & Recorders
How do I connect my bose 901 active equalizer to a onkyo tx-sr506
AV receivers are notoriously incompatable for Bose 901s. The problem is the EQ charges the entire system and could damage the surround processor. Some higher end AV receivers, including some of the newer Onkyo models have pre out power in inputs on main or all seven channels.which you could install your EQ directly between pre amp & power amp without damaging processor. You can also add a two-channel amplifier to the pre out jacks front channels and use your recever's remote to control volume.
Nov 30, 2008 | Bose 901 VI Main / Stereo Speaker
Connect Bose 901 eq to Denon avr 2807
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the Tape Monitor with any type of stereo-only sound processor (non-Bose EQ, dbx expander, etc) and the various DSP options to spread 2-channel analog source material around the room. I have a whole stack of analog processors, tape and CD recorders slaved to my single Tape Monitor and then into a dbx400x Program Route Selector. It not only expands my Tape Monitor to handle nearly unlimited external devices but it makes routing for listening or recording easy with simple pushbuttons. But I digress...
The good news. I have a setup similar to what you want to do and it works great! With one caveat - My receiver actually has 5.1 analog Outputs (probably like yours) so I can drive up to 6 external amplifiers if I want to (I drive 4).
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front L&R Pre Out >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> NEW amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Oct 19, 2008 | Bose 901 VI Main / Stereo Speaker
65 people viewed this question
 Grubhead
Grubhead
