Question about RCA TH1101 MP3 Player
Can't connect my MP3 to my computer
I was trying to connect my MP3 to my computer to add songs and now my computer does not recognize it. Windows media still says connect a device but my MP3 says connected.
  • needsimilac Mar 01, 2008
    I have the same problem.
    My computer won't recognize mine either. And - the USB ports are fine.
    Yahoo music won't recognize it either.
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 24, 2008
3 Suggested Answers
SOURCE: windows media will nt detect my mp3 pearl (RCA
Quue I had many of the same problems as listed above. what worked for me was to go here and download the firmware upgrade installer. Follow the directions and be sure to check the reformat box b4 you start. My pearl th1100a is working fine now.
Hope this helps
Q
Posted on May 28, 2008
  • 758 Answers
SOURCE: My computer won't recognize my Sansa Connect MP3 Player
What i would recommend you to do is to uninstall the device and reinstall it back...to uninstall it...assuming that you are running windows xp...click on start, right click on my computer and go to properties..you should have your system properties open then click under hardware then device manager...look for the sansa device..it usually located under portable device..if its not showing there i would recommend you to look for under disk drives and see if its there..right click on the device and click on uninstall...after you unintall it unplug your device from the computer....Then follow this link below to download the porting kit...http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en .Then check the mode of yuor device to make sure it sunder MTP not msc...To check the mode go under menu, settings and choose usb mode...After you check the mode open up your windows media player click on tools, options and click under privacy...clear the history and caches...after you finish you can plug the device on the back of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media player to 11 even though you have done that already..and try to reconnect your device..make sure you have it connected on the back USB>>>
And if that doesnt work try to obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Computerrep
Posted on Jan 26, 2009
We hooked it up to a usb but we cannot copy music to our mp3 player what do we need to add to our computer to do so we have windows media player and that is what we are trying to download some songs into...
open WMP (windows Media player)... import what songs/albums into WMP. connect your mp3 to you computer. WMP should recognize it if it is a sansa. Highlight what songs you want right click ...add.. to sync list. or you can make a sync list on the right hand side of the screen and drag and drop the songs you want on your mp3 player ... when you have the ones you want click on the sync button and those songs will xfr to the player
Oct 18, 2009 | SanDisk Sansa Clip MP3 Player
How do i download to my player
what brand is your mp3 and model
Sep 19, 2008 | XO Vision X120AUD MP3 Player
CAN YOU HELP ME DOWNLOAD MUSIC UNTO MY EMERSON
Try letting your computer do the work .. If you are operating on a pc use Window Media Player to sync and download music to your player... First put the songs into your library .. connect your mp3 player to your computer and see if the Windows Media Player recognizes it.... If it does you are in business... highlight what songs you want.... right click ....add.... sync list.. when you get the songs you want on yer list sync the mp3 player and your done... hope this helps
Oct 18, 2009 | Emerson MP530 MP3 Player
I cant find place to add music files to my player, SanDisk Sansa m240... I go to my computer open the files and find no music library
use windows media player... open WMP connect your player it should recognize it... use this to sync music to your sansa...you highlight the songs in WMP right click ... go to add music .. select sync .. once you get the songs into a sync list ... you just sync the sansa...
Oct 16, 2009 | SanDisk Sansa m240 MP3 Player
Computer doesn't recognize MP3 player -
Check My Computer. If the PC recognises the Sansa player then simply add the songs by dragging the files into the player's icon on My Computer. Sometimes this kick starts the built in software included on the mp3 player.
Apr 01, 2009 | SanDisk Sansa Clip MP3 Player
Not enough disk space on GPX ML648B
If this problem occurs then your ML648B needs to be formatted.
1. Connect your ML648B to your computer with Windows XP or later.
2. By default your computer will recognize ML648B as GPX MTP Device. Press the POWER button from top of your ML648B, to change it to USB mode connection. You will also see USB on the screen of ML648B.
3. ML648B will now mount 2 drives, one as Tools (as CD-Drive) and second as Removable Disk (Drive) – under My Computer on your Windows Desktop.
4. Right click your mouse and then select the Format option. When the Format Removable Disk window appears select the Start button to start formatting your MP3 player.
-Tha Mp3 Doctor
Jan 29, 2009 | GPX ML648B MP3 Player
Mp3
if it doesn't sync, don't worry just open the folder where the music files are stored on your computer, connect your Sony Walkman to your computer and highlight the music files you want to add to the Walkman and select (copy these files) a windows will open for you to select the place you want to copy to, select your mp3 player and click on copy to copy the selected music to your Walkman
NOTE: if you Sony Walkman has a specific folder for music files, you need to move the songs you copied from your hard drive's music folder to the music folder on your mp3 player for the player to recognize the songs in order to play.
Dec 26, 2008 | Sony Walkman Video NWZ-A816 Digital Media...
Sansa 4Gb Wont let me add or delete songs anymore!
If the PC does not recognize the player, try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jun 12, 2008 | SanDisk Sansa e260 MP3 Player
No change is recognized in the playlist
this is so simple sir because i have same problem connect to the computer and right click to your drive and format it
Nov 15, 2007 | SanDisk Sansa e140 MP3 Player
Computer won't recognize my mp3 player
you could try to reboot/restart the mp3. you are going to have to erase everything and start new, you may have gotten a bug when you were downloading.
Jun 25, 2007 | SanDisk Sansa e260 MP3 Player
RCA TH1101 MP3 Player Logo
26 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
