Question about Tools & Hardware - Others
Senco 600 framing nailer / double hitting(nailing)
Lately my nail gun is double nailing(usually at the most inopportune time). what is causing this and how can i fix this?
  • smokinbob Apr 23, 2009
    I don't think I described my symptom's correctly. What is happening is that the nail gun will cycle two times with one pull of the trigger. I do not experience two nails with one "hit". I can literally feel two quick rapid fire cycles with one pull of the trigger and have two nails as a result. The nailer is Senco framing pro.
  • smokinbob May 11, 2009
    thank you, I did more searching and I read that this is a major cause of double nailing.
  • 23 Answers
Double nailing is usually caused when you apply to much pressure on gun causing it to fire on the recoil lighten up just tap it on the surface to be nailed
Posted on May 11, 2009
  • 142 Answers
The 600 had a design flaw, as it was designed for the "happy homeowner" to use
In the nose, where the nails hit before the driver hits, the part wears down prematurely
there is no solution to the problem
Senco let us trade our guns for the 701xp model for a discounted price
Posted on Jul 03, 2009
  • 25 Answers
This problem most often occurs, when the wrong nails are used. Check closely to see if the nails are correct, sometimes generic brands can be made slightly different, this can cause trouble.
Also you can check to see that the nose piece is not worn where the nail slides down. If it is worn the slot may be enlarged enough to allow more than one nail to be within range of the driver as is comes down.
Look carefully, you may see signs of the unusual.
Posted on Apr 23, 2009
  • Roeh Apr 23, 2009
    Okay, This may occur when the trigger is still depressing the button after you release. Check to see if the trigger has any unusual symptoms. Does the lever on the back of the trigger move freely? Is it bent?
    Or the Trigger assembly is worn. You may try to check the O-rings on the trigger assy. This is the long pin with a spring surrounding it. Try replacing the o-rings. Or it is possible that there is dirt keeping the trigger pin from moving up and down properly.
    Hope That this answer is better
I have a Senco SN70 framing nail gun. The gun
One question is do you regularly put oil in the gun? Also you need to make sure that the screw holding the 'clip' near the barrel is tight and not loose. These are the 2 main problems when a gun is misfiring.
Oct 02, 2013 | Senco Air Tools & Compressors
Can My FC 350 A used 28 degree nails
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
Mar 03, 2013 | Porter Cable Factory-Reconditioned...
My 601 won't shoot any spikes it just leaves a 1/4 '' indent were nail should be?
If you're getting an indent in the wood from the driver, the gun is working properly. If the gun isn't driving fasteners/nails it's because the nail isn't under the driver when it's activated. Several things could cause this: Having the wrong angle nails in your gun. There is something in the feed path of the nails preventing them from feeding fully into the nose piece. The feed shoe is jambed or feed shoe spring is broken.
Feb 18, 2013 | Senco & Frame Pro 601 Framing Nailer
Will the 901xp use any brand of papertape 33 degree nails? I have probably 12 cases of collated papertape and would hate for them to just go to waste but the 901 is not listed as compatible.
Most Senco nail guns are great about listing out brands of nails that will work with their guns, they are not particular to using their nails. The 901 does use 33 degree nails but if Senco does not list the brand that you have then I would recommend not using them so you do not damage your gun. Maybe you can sell them on Craigs List?
Hope this helps James
Apr 05, 2011 | Senco SN901XP Clipped Head Framing Nailer
I have seen many nails that supposedly fit the senco sn4 nail gun. Some are 31 degree, some are 33 degree. All have paper collating. What angle nails should I search for to fit the senco sn4?
Senco uses 33 degree paper tape clip head, however many generic brands will label their box 30-34 degree to fit several nailers. This practice causes jams in some guns and others work fine. The goal is to save money but could cost more in the long run if gun is damaged. You can use generic (other than 33) if you take a strip of nails and place them against the outside of the rails aligned with either the line of driver path of angle of the rails. This will give you a visual as to the alignment. Best result is when the complete nail is in line with the path of driver. Next best result is when the head is in the path of driver and point of nail is slightly away from path, worst is when point hits path and head is back. Good luck
Mar 26, 2011 | Senco Air Tools & Compressors
I have a senco framepro 600 clipped head nailer. Nails are only driven 2/3 of the way down. This occurs about 30 percent of the time. The portruding nail will be bent over against the wood. Air pressure...
The Senco FP600 is an older model gun, if it has been getting reguar use check the driver. After a lot of nails the tips tend to get rounded off towards the back side and if the nail hits some dense wood or a knot the head will slip off before it can be driven home. Replace the driver if so, trying to grind the end square will only result in problems with the guide when the driver retracts into the head.
Oct 25, 2010 | Senco SCN56 Medium Coil Nailer, Switchable...
Senco 601 nailer shoots 2 nails each time the trigger is pulled.
the 601 had a design flaw, in the nose, where the nails hit as the are being pushed forward, the peice was made out of a peice of metal that was too soft, it wore down and that is where you get the double nail problem.
Senco offered a trade in, this was years ago, for a limited time and gave us credit towards new guns, which we gladly did
Dec 31, 2009 | Senco & Frame Pro 601 Framing Nailer
Problem accessing nails
Hi, No you can't. They are two different feeds. The F33 uses tape feed and the N79 uses stick feed. The N79 is a basic wood frame nailer that uses 3 to 3 1/4 sticks, while the F33 uses up to 2 1/2 paper feed. The stick nails are the most common for the older nailers and on the box look for Bostitch as the brand to fit, as the N79 was sold under that brand not Stanley. This should Fixya!
Mar 02, 2009 | Stanley F33PT Paper Tape Framing Nail
Makita AN 901 framing nailer blows nose end apart
not too familiar with makita brand nailers but jams are usually caused by cheap nails but I see you have tried senco brand which is a good brand sounds like a mfg defect try using hitachi brand nailers they are good
Dec 26, 2008 | Makita AN901 Coil Nailers
Tools & Hardware - Others Logo
359 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
