Question about Car Audio & Video
How do you hook up the wires other then positive and negitive
How do you hook up the wires other then positive and negative?
    Scholar:
  • 80 Answers
Blue goes to your head unit's blue wire. It switches the eq on when the head unit is switched on. It also gets tied into the amp's blue wire (if you are using an amp, and I guess you are since you have a passive eq...). The fact that there are 2 is just for conveinience I think (99% sure) If I recall one may have a white stripe, and the other none. If you want to be sure, with all power DISCONNECTED to everything, and the harness plugged into the EQ, use a multimeter to see if there is continuity (connection) between the 2 blue wires. Then you can rest assured they gave you a second one just for a "pass thru" to your amps, but inside they are electrically connected, and are essentially the same piece of wire.
Posted on Jun 12, 2009
What wires go to my positive and negitive side on my battery on my 03 yamaha r6
Positive wire is red whereas negative can be either black or brown.
Hope this clarifies your doubt.
Aug 14, 2014 | 2003 Yamaha YZF-R6
I just got my subs and amp i have my amp wired up but what do i need to hook the amp to the sub?
you need speaker wire. you will hook one end to the negitive on the amp and one end to the black(negative) spot on the speaker. then hook one end of the other wire to the positive on the sub and the other end to the red(positive) spot on the speaker
Aug 27, 2013 | xXx XBX1200 Car Speaker
Rear door speakers wiring diagram
Left rear speaker driver side color is Black/Yellow positive and Black/Orange is negative. Right rear speaker passenger side Black/Green Positive and Black/Blue negative.
Jun 26, 2012 | 1998 Land Rover Discovery
Wiring after market spekers need to know if a or b is positive or negitive
dont know about a or b but wiring should be color coded. these should be the colors and description for 02 silverado
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Dec 31, 2011 | 2002 Chevrolet Silverado 1500
What wires need to be hooked up to the positive wire and which ones for negitive
Red = positive to battery
Black = negative/ground to body
solid colored wires - positive speaker
while lined wires = negative speaker
Yellow = starter switch
Jun 06, 2010 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Is the black wire negitive and white wire postive
The Black wire is the Hot or positive wire and the White wire is the nuetral or negative wire.
The green wire gets hooked to the frame or any metal part of the dishwasher...usually there is a green screw inside the little box where the wires hook up
Heatman101
Apr 15, 2010 | Bosch SHU9925UC Built-in Dishwasher
How do i hookup two 12" championship series pioneers wit 2 positives and two negitive for each speaker
Hook up one positive wire to the right side output of your amp, do the same with the negative wire for that speaker, right side out put. Then repeat the same for the other speaker, but on the left channel.
Mar 28, 2010 | Pioneer TS-SW2541D Car Subwoofer
I need help installing a 4 Channel Power Acoustik Amplifier to Two Pioneer Subwoofers. I hooked up the power wire to the positive battery terminal in the engine compartment. I then cut the power wire and...
You are doing right on what you described. I really like to work with a clearly described what involved in an issue.
Now we have to use a Voltmeter to check if there is power to the amplifier. If there is power to the amplifier terminal, then the problem is at the amplifier, not the connection. Let check it out:
1- Turn on your Kenwood radio, make sure to hear sound from your regular speakers.
2- Turn remote control knob to the mid level between min and max.
3- Measure the blue wire where you spliced to ground to see if you have 12V, if it is not then the problem is right there.
4- Measure the Red wire power from the Amplifier to ground ( the bolt that you connect the negative power to see if there is 12V, if not trace back to the Fuse that you inserted between the positive terminal of the battery and the wire going through the firewall to correct it.
5- If you have 12V at step 3 and 4, then you have a defect unit, return it to the manufacturer for a replacement.
Sep 06, 2009 | Car Audio & Video
I need to know the sequence on how to connect my Power LED, Reset Switch, HDD LED, and M/B Switch up correctly. I have an MS-7142 VER:1 Can you help me?
Hi carlmtclem, your not alone when it comes to hooking up the right led connector to the MSI MB. Firstly, you need to know what wire color is positive & which is negative. Most commonly the color white is ground/negative. Wire colors do vary from case to case. So look at your case led wires. Which ever color is common for each 2-pin connector, is negative. (Except the speaker wire).
All other colors are positive.
(The speaker wire color for negative is usually black & red is positive).
Your MSI board has two separate sets of pins.
JFP2 is used for the speaker only. Do not connect the power led there.
Pin one for JFP1 is shown in the manual. Pin 1 is positive & pin 3 is negitive for the HDD-LED, ECT.
Thats it.
Need more information?
Post here.
Good luck carlmtclem!
Thank you for using fixya.
Mike
Jan 11, 2009 | MSI K8MM-V Motherboard
Don't know which is the positive and negitive wires
To be honest, it really doesn't matter - the speaker is just a resistor electrically, which is not a polarized component. You can hook either wire up to either side and you will get the same sound. In any pair of speaker wires, do you have one with a stripe and one without? If so, the striped wire is the negative wire. If you have a light colored wire and a dark colored wire, usually the darker one is ground (ie, yellow wire and purple wire in a pair for example - the purple would be the negative and the yellow would be the positive). But honestly it doesn't really matter which one goes to which terminal - electrically they have no real difference. If you hook them up "backwards" from what the factory intends, when the speaker plays, it'll pulse inward rather than outward from its mounting frame. It'll move the same distance with the same velocity however, so it'll create the same sound.
Sep 27, 2008 | 1994 Ford Club XLT
Car Audio & Video Logo
217 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
