Bjc-85 canon printer the cartridge moves to center beeps 3 times and power light flashes. I have 4 printheads and the all do this. I have a scanner and it is ok. It was working ok and I changed the printhead and can't get it to work again
If the scanner cartridge goes in ok and is recognized by the printer, but print heads are not, it is because the printer still thinks it has a scan job to finish. Install the scanner ( IS-12) do a scan job, make sure you complete it, wait for the scan program to tell you to install the print cartridge, and that will probably solve your problem.
Someone did a scan and then put the print cartridge back in before the scanning program got to that part.
I have not solved the problem. I just changed to a different printer. I had a bj50 printer and it use to do this and would change the printhead but they are expense and I have 3 different ones so believe it is something else that is wrong with this one.
