Question about Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television
DLP TV turning on and off automatically - Mitsubishi WD-52327
I have an issue with my DLP TV. I turn it on and all is well for about 2 minutes. Picture quality is excellent. The Timer/Power light is constant green, which mean the TV is on. After about 2 minutes the TV picture and audio turns off and the lamp light turns red for about 2 seconds. Then, the lamp light flashes green for about 1 minutes (This I assume is the TV cooling off per the manual). Finally, the TV turns back on and the picture is excellent. That is done AUTOMATICALLY! I do nothing to turn the TV back on. I have unplugged the TV, but that does not help. I don't know where the reset button is, so I wasn't able to push it. Can you please assist me with my issue? Is this the standard for a lamp failure? I would guess that if the lamp failed, the TV shouldn't (and couldn't) turn back on automatically. I took the lamp out for inspection and did not notice any issues, but I am not an expert.
  • Anonymous Dec 20, 2007
    dlp tv turns off on its on
    Sergeant:
  • 395 Answers
1. Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB part # 930B929001
Posted on Feb 21, 2008
3 Suggested Answers
SOURCE:
  • 1779 Answers
SOURCE: I have a Model WD 52327 DLP TV and the lamp is out.
Dlp lamps.com or "Encompassparts.com"
Posted on Oct 26, 2009
  • 1779 Answers
SOURCE: Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Posted on Feb 14, 2009
My Mitsubishi WD-82738 dlp tv turns off after a minute
You have a power supply issue that needs to be addressed.
Mar 04, 2016 | Mitsubishi WD-82738 DLP TV
Tv turns on works for awhile then shuts down
it seems cooling problem check if fan is working or not
and check the english user guide
http://www.manuals365.com/swf/mitsubishi/wd-62327.html?page=50
Mar 17, 2015 | Mitsubishi Wd-52327 52" 1080i Hd Dlp...
What is the cause tv turns on about half hour turns off red flash
most likely the lamp. pt# 915P020010
Recommend Phillips, OSRAM, or Mitsubishi original, as others may not work at all or have a very short life.
https://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-52327
Mar 17, 2015 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi wd 60735 dlp tv red lamp light
A common issue and it may be your problem is dust and dirt inside the unit---the set intakes air from the front and exhausts it out the rear==I have seen several of these sets where removing rear cover and taking stthe set outside and blowing it with a air compressor clears the issue.
Fans and other critical items that get clogged or coated with a moderate amount of dust will cause this issue.
Jul 17, 2012 | Mitsubishi WD-60735 Projection Television
I have to change the lamp on my mitsubishi dlp tv. where is the lamp located?
Here is a link to the owners manual for lamp cartridge replacement. Specifically go to page 65 for instructions. Good Luck : )
http://support.mitsubishi-tv.com/files/oguide/WD-52327.pdf
Jul 26, 2011 | Mitsubishi WD-52327 52" Rear Projection...
Solid Yellow light and blinking yellow status light after bulb replacement. TV wont turn on.
Sounds like Mitsu is getting sued left and right about their DLP problems. There is a potential overhaul if you contact their parts department.
Oct 13, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-52327 Picture flickers and goes blue
In your case I've seen this and it was a electrical issue between the DLP fan and board. The tv could have a problem with the digital tuner and not kicking a code due to low voltage ... it isn't expensive to fix, just hard to diagnose.
Do you smoke? The fans suck in smoke and it gets tar build up on the connections and that causes this in some cases too.
Dec 28, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television Logo
1,114 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
