Question about GE Energy Star WCVH6260F Front Load Washer
Front door boot gasket on a G E front loader
How do i install the new gasket
  • mikemyrickg Apr 20, 2009
    how to install gasket
  • 121 Answers
How to get rid of black mould?
Do a long hot wash, add bleach. Stop using fabric softener. If the rubber boot on the door (Front loaders) has been stained with black mould, you wont get the stains out. It will need a new gasket.
Mar 20, 2017 | Washing Machines
My front loader leaks water because the door gasket, called a boot I believe, is torn and needs replacing. There is nothing in the manual that gives even a clue as to how to remove this boot or how to...
There should be a spring loaded clamp on the outer panel and a screwed together wire clamp on the tub. You may have a water inlet clamp on this model and possibly a drain clamp at the bottom center. Take your time so you do not tear the new one. If you are really a go getter you can remove the top panel of the machine, the control panel, the door lock, the bottom panel and the entire front of the machine to gain easy access to the tub side of the boot. Remove the outer spring loaded clamp first before attempting to remove the front panel.
Sep 18, 2010 | General Electric WBVH5200J Front Load...
Door boot seal on a front load washer how to change
front gasket/door boot.... replacement isn't easy but do-able. first remove three screws that hold front lower panel on and remove panel (where lint filter is). then remove 3 screws that hold on top panel (screws located at rear of top of washer), next remove 3 screws on top front of washer, then remove 4 screws that secure the contol panel. you must remove the washer door at this point, just a few screws and pin hold the door on. now, remove control panel by gently pulling the top away from the washer, it's held by a few plastic snaps. then, remove three screws that secure front panel of washer. now you're ready to remove the old boot/gasket. first look toward lower right side of gasket and pull the spring and remove wire that secures front of gasket. next... at about 3 o'clock on the gasket you'll find a longer screw (about 3 inches) that secures the rear of the gasket. loosen this screw until you can remove the gasket. remove the water inlet and hose from the boot/gasket.... now remove gasket from washer. you're ready to install new boot/gasket. find the small triangle on the new gasket and line this up w/the triangel at the top of wash tub. begin working the gasket onto the lip of tub, make sure to align the triangle and water outlets of the gasket w/the triangle and outlets of the washer tub. once back of gasket is on install the rear wire holder and tighten screw to former tightness. now work front of gasket onto the lip of washer, install spring wire to secure the front. place water inlet and hose into respective holes on the gasket. put front panel back on, put door on, put control panel on, put top on... and wash. like i said, not easy but do-able... i completed it in 1.5 hrs w/no instruction.
Nov 11, 2009 | GE WSXH208A Front Load Washer
Front loader gasket leaks WFW9200sq00
there is likely a tear in the door boot/gasket from something having been left in a pocket. you will need to get it replaced.
Oct 13, 2009 | Whirlpool GHW9400SU Front Load Stacked...
Stinky clothes
you should run a empty load with bleach but no detergent every month or so to clean the washer, I also recommend cleaning the boot (door gasket) every couple of loads with windex or other cleaner. also every load check inside the bottom of the boot and make sure the drain holes (x3) are clear of lint, etc. this is normal maintenance for any front loader. GE is a very good brand and is my preferred brand, I repair appliances everyday, Whirlpool keeps me busy. I have GE front loaders in my house.
2nd poster, you will need a door hinge for this most likely. Not too hard.
May 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Torn gasket
Catriver(fixya) has a solution:
Remove the top, by removing the 3 screws in the rear. The top will slide off toward the back. Next remove the control panel. Remove the 2 screws on each end on top. Remove the detergent drawer. Remove the torq screws behind the detergent drawer. The control panel will now snap off, pulling from the top and lifting up. Once freed, remove the control panel ribbon cable from the side of the main board. Now remove the screws holding the door switch mechanism in place. Remove the spring that holds the outer part of the boot from the front panel. Now remove the 4 quarter inch screws that hold the front panel and door on the front. Now you can install the new boot with ease. I know it sounds like a lot, but it is not that bad. Just reverse the process when the boot is on the tub. Make sure to have the mark on the boot ^ lined up with the mark on the tub on top.
Apr 14, 2009 | Kenmore 44072 Front Load Washer
Kenmore 3.5 frnt loader always has inches of H20 in rubber gasket
does your model start with 417? if so then there is a new door gasket that will help with water left in the boot.
if you have 110, then there is no new gasket/ boot...
you need to clean the drain pump sump screen.
either unit will have a clean out screen that is a removable cover on the front of the pump and it allows you to unscrew the sump filter and clean it out.
Feb 23, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
295 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
