Question about Epson Perfection V200 Flatbed Scanner
Scanned pictures has thin blue line running through it
I have a Epson V200 scanner that is quite new. I've scanned lots and lots of negatives etc. with this scanner, but since yesterday everything has a thin light blue line through it. I've cleaned everything I could reach, and checked the scanner-thingie inside the glass for dirt, but can't see anything. How do I fix this?
  • lizev007 Apr 19, 2009
    Thank you so much! It worked!
    Problem Solver:
  • 19 Answers
I had the same problem with My Espon Perfection V500. I called tech support and they had me do the following sequence.
1. Turn off the unit
2. Unplug the lid from the base
3. Replug in the lid.
4. Turn the unit back on
5. Go into the Epson software in Professional mode, Configuration, Other and select Reset All
6. Rescan the picture.
It worked after that. Of course it also lost all my preset sizes in my Custom box and any other settings I had. I suspect the lid plug is what the problem was.
Another word to the wise. To test it I put in a picture that was laying on my desk and rescanned it and was disappointed to see the line in the result. A few minutes later I discovered that this particular line was in the original picture.
Posted on Apr 18, 2009
    New Friend:
I had this problem with a Perfection 4180 PHOTO. I tried the above and the problem remained. Tried a 2nd time, but this time left the unit off for a few minutes to cool and problem solved.
Posted on Jul 05, 2015
How do I get rid of the line running down the scanned document?
Simple, clean the ADF glass that the paper passes over during a scan (not the flatbed glass itself, just the thin strip of glass at the head of the flatbed glass). A speck of dirt on the glass will appear as a line down the length of the paper.
May 23, 2011 | Epson GT-2500 Flatbed Scanner
How do I scan a slide photo / negitive on my epson perfection V200 scanner?
safemanuals.com/user-guide-instructions-owner-manual/EPSON/PERFECTION%20V200-_E
please go the above link and download the pdf file and you will get a complete pocedure on scanning a photo/negative
Aug 08, 2009 | Epson Perfection V200 Flatbed Scanner
Negative images
Check the settings and try to update the software/drivers if available from manufecturer's website. (ehteshamhusain@gmail.com)
Jul 19, 2009 | Epson Perfection 4180 Photo Flatbed...
Negatives scan as negatives and not as pictures with the plustek 7300
In the Twain driver for your intellscan, there should be a selection for the type of scan. It should be set to "black & White Negative" or "Color Negative". The program you use to edit the scanned file should be able to change it to a positive if the scanned result is still negative. Programs such as Photoshop, Paint shop Pro etc can use Twain to have the scanner scan directly into them. There the phot (negative) can be edited and saved.
May 30, 2009 | Plustek OpticFilm 7300 Film Scanner
My scanner will not scan negatives
Most scanners aren't designed to scan negatives. (Of course the manufactures would never want to tell you their product CANT do something).
Flatbed scanners typically have a light on one side.
To scan negatives properly, you need to have a scanner that has a backlight, or a second light in the bed's lid that you fold down.
Canon USA, Inc. make a few flatbed scanners that have backlights. They range from $60 to $180, depending on the features and resolution you want to pay for.
Please see the below link. This is a more expensive one, but is shown just so you get the idea. In the pictures, note specifically in the picture that shows the lid open, how the white backing on the lid can be removed from a clip at the top. Underneath, is the backlight and clips designed to hold negatives in with the included frames.
http://www.newegg.com/Product/Product.aspx?Item=N82E16838111015
May 04, 2009 | Epson Perfection V200 Flatbed Scanner
No final scan with Epson V200 scanner.
possible driver issue.
Please trash and re-install the drivers.
Apr 28, 2009 | Epson Office Equipment & Supplies
Epson V300 Photo Scanner Streak When Scanning Negative
I also own a v300, and I have noticed that I occasionally get rainbow streaks if I bump the scanner at all while it is scanning negatives, so this might have something to do with vibrations in the machine. Is it sitting on a stable surface?
Mar 14, 2009 | Epson Perfection V700 PHOTO Flatbed...
Size document mismatch
In the Epson Scan software, select Professional Mode and check your Destination parameters - i.e. width (W), height (H), and Scale %.
Oct 17, 2008 | Epson Perfection V200 Flatbed Scanner
Epson Perfection V200 Photo scanner
You have tired all the computery things seemingly
but it is work trying some more
Remove all software.- using the Epson Uninstall routine .
and just to be sure go to Programs.Epson and maually delte all you can find.
Make sure that when you re install- the computer is off line and the ant virus program is disabled.
That should sort the problem Computer wise.
When you go to operate the scanner- does it then go through the motions of Scanning but no light - is that it?
If it is - there is nothing for it but to replace ther scanner
To bad about the warranty card but if you have the sales recieipt
And purchased less than a year ago - the the seller has a responsability [UK wise any way]
But a pleading message toi Epson may surprise you too.
Jun 10, 2008 | Epson Perfection V200 Flatbed Scanner
Dull negatives
are you using the a transparency adapter on the negatives?
Oct 16, 2007 | Epson Perfection 3200 Photo Flatbed...
Epson Perfection V200 Flatbed Scanner Logo
3,161 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
