Question about Acer Aspire 4930-6862 Laptop
Help me my recorded video is lame. the sound didn't match the video.. the video played first, a few seconds later then only the sound comes out.. so, when the video is playing, mouth movement is earlier from the sound that should come out.. i use acer crystal eye webcam for acer aspire 4930 laptop.. help me how to solve it
My pioneer pdr-509 starts recording for about 5 to 10 seconds then stops and says repair, and it will play that back, and it will let me finalize that to.I am using sony cd-r for music, i bought some air...
Such problem is a result of a dirt's on the lens area. Try to insert a lens cleaning disc to the drive and have it played for at least 5 minutes. Repeat the cleaning process and check if the problem has been fixed.
Sep 02, 2011 | Pioneer PD-R509 CD Recorder
How do I transfer a video from vcr to dvd on magnavok dvd/vcr recorder ?
Use the Dub video feature. This will work if the source is not copy protected. Make sure you have a writable (or rewritable) DVD with sufficient space available in the DVD tray (closed) and put your tape to dub in the VCR.
Press Setup on the remote and navigate down (up/down arrows) to Recording and press OK. Then select Dubbing Mode in the next menu level and press OK. When the Option menu opens, highlight VCR to DVD and press OK. Press Setup to exit this menu. Choose a recording mode using REC MODE on the remote. Press Play and then Pause when you reach the point where you want to start the recording (press quickly if you want to dub the whole tape; you will lose a few seconds while the dubbing starts so include 5 seconds extra if starting later in the tape). Then press Dubbing on the remote. The duplication will start. Press Stop when you reach the end of the section to record.
I hope this helps.
(only the Setup and Rec Mode buttons do not have a matching button on the front of the unit. The later steps (setting up the start point, starting the Dub and stopping it) can be done with the remote or the buttons on the unit.)
Oct 27, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
CD player can't play recorded audio cd's
That sounds right, some of your cd players will not be able to play recorded cd's . It's lame, but that's the way it is. Sorry.
Jun 17, 2009 | Audio Players & Recorders
Icecam2 sound
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Feb 25, 2009 | Macally IceCam Personal Web Camera
Audio
use windows taskmaster, select process, find dazzle, right click, select priority, real time.
Dec 24, 2008 | Pinnacle Dazzle DVD Recorder
Video picture does not match sound
Download the latest version of quicktime to get new codecs, and the reconvert videos using media converter
May 02, 2007 | SanDisk Sansa e260 MP3 Player
Olympus FE-130 Video Playback has no volume..............PLZ HELP!!!!
well did u use zoom while u made the videos???? if u did forget because the camera while doing zoom doesn´t record sound, u didn´t use zoom, probably the camera microphone needs to be replaced.
Feb 09, 2007 | Olympus FE-130 Digital Camera
Open Questions:
See all Acer Aspire 4930-6862 Laptop Questions
Acer Aspire 4930-6862 Laptop Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
