Question about RCA TruFlat 27F520T 27" TV
I plugged in the prongs correctly for my xbox 360 and i went to channel three on the tv and pressed input. But nothing happened
    Problem Solver:
  • 9 Answers
It did that to me one time, unplug everything, plug everything back in and be sure its plugged into the xbox really good. if it continues, the check it on another t.v. because it may need to be repaired
Posted on Apr 20, 2009
I have a daenyx lcd tv, model DN-15, input 12VDC-4A and am trying to hook it up to an xbox 360 console.
If you are using the Red/Yellow/White cable, that's composite cable, but if you're using the one that's Red/Yellow/White/Blue/Green, that's called component. So basically, you set your TV's input to the corresponding color match. 5 colors: Component, 3 colors: Composite.
Sep 13, 2014 | Video Game Consoles & Games
Why doesn't my Xbox turn on?
Only solution i have for you is to check your connections on the Xbox, making sure that everything is right. If that checks out and you are NOT getting the red button of doom on your Xbox, then I would use a new connector or if you are using a HDMI connection use the original connector, the one with the three wire coming out the back that connects to the TV. Sometimes dumbing things down will fix it. Also check your TV and make sure that you have the right input channel on for the Xbox. IE input 2 when it should have been input 1. Not saying anything but sometimes this is the simplest solution and the right solution. Hope this helps.
May 27, 2014 | Microsoft Xbox 360 Console
My dynex tv only shows channel not available message?
Okay- the three cables (red, white, and yellow) are called RCA plug connectors. They are commonly used to carry audio and video signals.
Plug them into your Xbox according to the color codes- red cable connector to the red socket (jacks); then white to white, and yellow to yellow.
Now connect these leads to the RCA input jacks in the back of your t.v. - maintaining the same color code connections (red to red; white to white, and yellow to yellow)
The RCA input jacks on your t.v. should be labeled with an input number, to distinguish itself from the other inputs, like HDMI, S-Video, and such.
After plugging in your Xbox to the wall outlet or surge strip, turn it on.
Turn your t.v. set on.
With the remote control that came with your t.v. set, open the menu bar, scroll to... and open the "External Output" menu.
You should see a list of [however many] inputs your particular t.v has. Scroll to the input number that the 3 RCA cables are attached to, and press that number as the default video screen.
Exit the prompts and your Xbox video screen should be displayed.
Nov 27, 2013 | Dynex DX-LCD32-09 LCD TV
How do you get your xbox 360 to play, on a 65'' mitubishi projection tv,its connected but nothing comes on screen when i put a movie in just a blank screen and no sound,if i'm on a channel,the channel...
Hello
The Xbox 360 connects to a TV using either
- COMPONENT (red blue green for video, red and white for audio
- COMPOSITE (yellow for video, red and white for audio)
- HDMI
So, if your TV is on a "Channel", it is not on the correct input to view the Xbox 360.
Check the Xbox and verify which cables it is using to connect to the TV. When you find this, follow the cable to the back of the TV and find the input selection. It should be listed as the type and a number (i.e. HDMI 2, COMPONENT 1).
Have the Xbox on. Use the TV remote and use either the INPUT or the MENU options to change the input to the input that matches the port that the Xbox is connected to.
This should make the Xbox work.
When you are done with the Xbox, use the INPUT or MENU to change back to the tuner to watch TV.
Nov 03, 2013 | Mitsubishi WD-73734 73" Television
How can i connect my xbox360 to my t.v
well it depends if you hve an old tv or a new flat screen tv and your xbox should come with a cord that has three prongs (red, yellow, and white) and u go behind the tv and plug them into the tv in the colored spots that match the prongs.
Jun 08, 2012 | Microsoft Xbox 360 Console
I recently bought an Xbox 360 and plugged it into the back of my TV. However, the TV refuses to show anything from the Xbox 360. I tried Autoprogramming it, and it erased all of my channels except for 1,...
MOST of their older sets are set up where the AV inputs are channels 90-93 ; if you had no signal other than the game the set will skip all those channels out.
If you have a working remote for it direct enter 90-93 one at a time .
Nothing hooked to cable fitting means set will see no signal and skip them out when auto program is engaged.
SD TECH
Sep 23, 2011 | RCA F25254GY 25" TV
Xbox 360 sound but no picture can any one help
If you've just bought your xbox 360, then you probably haven't got a HDMI cable.
Which I think you could need.
Aug 18, 2009 | Microsoft Xbox 360 Console
Xbox 360
Yes I have mine hooked up to a old Tv
Regards
Mick
Nov 12, 2007 | Microsoft Xbox 360 Elite Console
Xbox 360
Try turning the xbox on and pressing the TV/Video button on the tv or remote a few times and see if the picture comes up.
Sep 15, 2007 | Microsoft Xbox 360 Console
RCA TruFlat  27F520T 27" TV Logo
142 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
