Broan-NuTone Allure II QS230SS Kitchen Hood Logo
Gail Ravellette Posted on Sep 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to change the filter on my broan 42000-k range hood. filter number 97006931, never done it before. help?
Strech
Level 3:
  • Master 1,562 Answers
  • Posted on Sep 21, 2013
Strech
Master
Level 3:
Answers
1562
Questions
0
Helped
484022
Points
4382
Look at this exploded view:
http://www.appliancefactoryparts.com/hvac/broan/423601.html
Part number 11 is a retainer clip.
Here is the instruction manual:
http://www.appliancefactoryparts.com/content/pdfs/137548-2.pdf
Page five, illustration 13, shows that the retainer clip is turned 90 degrees to release the filter, turned back to retain the replacement.
Here's a cut and paste of the manual:
"FILTERS
40000, 42000 & 42000D Hoods Only:
Remove aluminum filter by turning filter retainer to
one side. (FIG. 13) Filter should be washed once a
month in a hot detergent solution. Aluminum filters
are dishwasher safe. When installing filter, make sure
that filter slides under retaining tabs on back of fan
housing. Turn filter retainer so that arrows on retainer
point toward front and back of hood."
4 Related Answers
jdthefixer
  • 747 Answers
  • Posted on Dec 18, 2009
SOURCE: I just had a Broan Elite E662 hood installed and
It sounds like the fan blade may be installed upside down, or the entire motor/fan assembly is upside down. Typically, these small motors aren't reversible, so you should check the blade first.
Paul Bade
  • 1818 Answers
  • Posted on May 19, 2011
SOURCE: Broan Allure range hood fan
The fan switch contacts are probably welded together or the actuator mechanism is broken. Your best bet is to replace the fan switch, probably with a similar type having a higher current rating so the new one won't also be susceptible to contact welding. If you have an industrial electrical supply dealer or electronic surplus parts store in your area, those would be good places to look for a replacement.
Anonymous
  • 3513 Answers
  • Posted on Jul 26, 2011
SOURCE: All electronics in the Broan
Hi
Turn off the main switch and rcd and open the CU. A residual-current device (RCD) is an electrical wiring device that disconnects a circuit whenever it detects that the electric current is not balanced between the energized conductor and the return neutral conductor. Connect temporary wires (preferably some bright color you would not normally see in a CU so it can be easily removed later) between the earth bar and the neutral bars.
Check for continuity with a multimeter between the earth and neutral wires at the cooker hood feed position .If there is no continuity at this stage you have serious problems and should get a sparky in then disconnect the neutrals of each circuit from the CU neutral bar one at a time and retest continuity at the hood (start with the likely ones like kitchen sockets and downstairs lights and cooker circuit if present) .When you find out which circuit it is put its neutral back in the bar and start breaking that circuit in various places until you find where it's spurred from .
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Anonymous
  • 998 Answers
  • Posted on Sep 13, 2011
SOURCE: I have a Broan range
Sir try to check the starting capacitor and the ac supply feel free to send feed back good day and best regards.
Broan QS3 Nutone Allure III Range Hood. Has anyone tried to disassemble the Braun QS3 controller to degrease or repair it?
Question edited for clarity. This appears to Broan rather than Braun. Added full model name.
This answer on Fixya hints that the original boards were faulty. I thought he was from Broan, but it sounds like he is a repairer.
https://www.fixya.com/support/t668741-braun_qs3_range_hood
No instructions online, but the board is available
https://www.google.com/search?q=broan+qs3+controller+disassembly
Broan Nutone Allure III Range Hood Switch Control Board
Build.ca https://www.build.ca > part > R111653-Broan-Nutone-...
Broan Nutone R111653 Switch Control Board. Main Control board switch assembly. Use with QS3 Alllure III Range hood. Product Specifications ...
$237.89
Missing: Braun ‎' Must include: Braun
Broan QS3 Allure III Range Hood Parts
Store for Parts https://www.storeforparts.com > Broan > QS3
Part Key Part Number Unit Price 0 SV02544 SV02544?LED 1 SR740013 View 69 more rows
REPLACEMENT PARTS GUIDE
img-b.com https://s1.img-b.com > product_parts > broan PDF Attachment Screws #8-18 x ¼" Type AB or B, 1-Suction Cup. (Rubber Bulb Removal Tool), and 3-Wire Nuts. QS3. Allure III Hood. 97010792 Damper 7" Round -.
I need manual for broan range hood with light &fan
If you need a manual for your Broan range hood with light and fan, you can find it online. You can search for the specific model number to find the correct manual for your range hood. You can also contact the manufacturer directly to inquire about purchasing a replacement manual.
How do you repair a loose kitchen range hood light switch?
usually there is 2 small screws that hold switch. Since you did not give model number here is a link to broan range hoods hope this helps.
https://www.ereplacementparts.com/broan-range-hood-parts-c-153547_153677.html
Speed only work number 3
problem with circuit board change it
2helpful
Light button blinking why
The fan light switch blinks when it is time to clean the filter. Clean the filter, then press and hold the switch for 3 seconds to reset it.
Brian range hood model CJD130SS fan light on display flashes with fan off or on.
I believe that's the "change or clean filter" indication. Clean the aluminum filters in the dishwasher, replace the charcoal filters if non-ducted, press the fan light over 3 seconds and it should reset.
Broan elite hood vent has blinking light that won't reset with power off/on. What gives?
I turned both the light and fan on then pushed the filter button. After a loud beep the filter light reset went off. This worked for me.
3helpful
Can not get halogen bulb out of my kennmore elite range hood
You will have to do the following steps.
1. remove filters
2. Unscrew 2 screws retaining metal plate under the filters.
3. Now you must remove the whole light panel. 5 screws in all, three under the front lip and two at both back ends of the same panel.
4.You now unhook the light wires (plastic connector with two wires)
Now you have the whole pnale in your hands. Unclip the socket of "problem side" and unscrew the socket from the bulb. Re-do steps 4.3.2.1
3helpful
2answers
My broan allure turns on by itself
Isn't it suppose to turn on automatically? The broan has a heat sensor!
Filter light on Problem
ControlBoard. Part # R111638. I do service calls for broan & Nutone
We have the part: www.inventex.com
Jean-Marc
Top Broan-NuTone Kitchen Ranges Experts
ZJ Limited
ZJ Limited
Paul Bade
Sean Wright
Sean Wright
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
