Question about Dell OptiPlex 330 Desktop Desktop Computer
Have two computers and have put both hard drives in the same towe
The system is not seeing the second hard drive
  • cmacelis May 11, 2010
    Are these IDE hard drives or Sata hard drives that you put into the computer.
  • 62 Answers
Let me get this straight, because the title got cut off:
You pulled a hard drive from one computer and put it into the other, and it is not being recognized.
Did you check the jumper settings on the drive? From the factory it was probably set to master. Reset the jumper to CS (cable select)
and try again.
Posted on Apr 18, 2009
Howtosetup
not sure what you want to install whether an operating system or a hard drive
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart
on a desktop computer
wear an antistatic earth strap remove the power lead from the power in put on the computer
remove the side panels on on our computer you will see 4 screws 2 either side unscrew these
then remove the electrical lead and the sata lead remembering where these are located slide the hard drive out then put your new sata hard drive in placing the leads back to there original position then tighten the screws (do not overtighten)
http://www.ehow.com/video_4978913_install-internal-hard-drive.html
utube video install a second ide hard drive
http://www.fonerbooks.com/laptop_1.htm
laptop hard drive
http://www.ehow.com/how_5451891_remove-hard-drive-ibm-notebook.html
hope this helps
Jul 25, 2012 | Computers & Internet
How do i replace hard drive on my acer veriton 3600gt
Depending on the hard drive, it may need to be 'initialized' before the computer can recognize it. This is best done by putting the hard drive in a working computer and going to, if using Windows, right-click My Computer, select Manage and clicking Disc Management where you will see the uninitialized drive.
You will need to create a partition and format it. Then your Acer should see it.
If you don't have a second computer then you will need to insert an operating installation disc in the drive and have that operating system's software format the disc.
Jul 01, 2012 | Acer Veriton 3600GT PC Desktop
Hp hdd no show computer
Is this an external 1TB Hard Drive? Maybe it's to big for your computer. If it's an external drive try it on another computer and see if it works. There is also the possibility that the external 1TB drive is bad.
If it's not an external hard drive then try the steps below.
Click Start/My Computer and see if your hard drive is listed as a device. If not, turn the computer off, remove the battery, remove the cover that houses the hard drive on the bottom of the laptop then remove the hard drive from the bay. Wait 30 seconds and put the hard drive back into the bay and reboot. Now see if the hard drive is shown under My Computer. If not, the drive might be bad.
May 30, 2012 | Computers & Internet
I was using one of my StoreJet 25M (I was watching movie on my laptop). And then, I have pull out USB cable from that one, and put it in my second StoreJet 25M to see something else. Now I can't reed...
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use asoftech data recovery program to recover your files.
http://www.asoftech.com/adr/
Aug 28, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
XP rebooting again and again
Do you now have both hard drives plugged in? You must have the Master hard drive in the IDE1 slot and the second hard drive jumpered to cable select and put on the IDE2 slot. As you are looking at the cable from the open side of the computer, the IDE cable connected to the hard drive should have the red stripe towards you. The end of the ribbon cable should be plugged into the primary hard drive, with the second hard drive plugged into the second plug on the ribbon cable. On the hard drive there should be a diagram for how to jumper each hard drive for primary or cable select.
NOTE: You cannot put a hard drive into the computer and expect it to boot, even if it has an operating system on it. The OS must be installed onto the hard drive after being installed into the system.
Good Luck,
NOLA Tech
Jan 31, 2010 | Compaq Presario 5000 PC Desktop
Acer Aspire 5100 will not boot
Two possible Solutions:
1) The Hard Drive has come unseated - Disconnect the Power and REMOVE all connections, Close the Screen & Turn your Laptop Upside Down and Remove the Battery, Locate the Hard Drive Access Panel and Remove the Screws from the Panel, Remove the Panel, Remove the Hard Drive. Carefully Replace the Hard Drive, Replace the Panel and Reconnect the Battery & Power Supply. See if the Computer will Start
2) The Operating System is Damaged OR the Hard Drive is Dead - You will need to slave Your Hard Dive into a Second Computer and Backup ALL you Personal Data OR RISK loosing it. If the Second Computer can NOT read the Drive, the Hard Drive is Dead (A Computer Repair Company may be Able to Help)
Once your Data is Safe, you can try to Repair the OS by Booting your Computer with the Drive in it. Begin pressing F12 or F10 at bootup (Once a Second). You will be presented with an Options Page for:
System Restore (FIX WINDOWS)
System Recovery (Wipes your Computer and Retores the Factory Software)
Hope this Helps!
Dec 22, 2009 | Acer Aspire5100 Notebook
Loud buzzin sound on start up
If the POST screen is coming up, showing the the correct amount of memory in the system, and then telling your hard disk failure or something similar, your hard drive has failed. Put a new hard drive in the system, reload your operating system and all drivers, and attempt to use the old hard drive as a second drive long enough to get any files you need from it.
Dec 31, 2008 | Azza Xion II Series Gaming Computer Case...
Thanks
Try first to scan the ahrd drive using a good anti virus like Avast and a anti malware software like Malwarebytes , this tow are good in cleaning your computer for some harmful worm, virusess and malware that can also cause this problem..those tow software are free so you can just download thme and use on your system....
DOn't forget to rate the solution FIXYA thank you...
Oct 14, 2008 | Western Digital Caviar SE WD1600AAJS 160...
I had a computer crash I bought a new computer and put the hard drive from the old one as second
yes it is working but I cannot see any of the admin files... I can see the user files.
Any suggestions?
Mar 23, 2008 | Acer Aspire 5500 5570-2609 Laptop
No system found on hdd
  1. go to my computer go inside gigabeat click tools folder option show the hidden folders and system
  2. then u well see 2 or maye one folder or maybe more at all u will delete it all
  3. there is the problem in the final step i have 2 folder when u put them the mp3 work ok 1- his name "GBSYSTEM" 2- "System Volume Information"
  4. this tow folder must be put on and i don't know how to shared to people
  5. can you explant more about that,i realy dont understand the anwser from number 8.thanks
Mar 23, 2007 | Toshiba Gigabeat MEG-F20S MP3 Player
Dell OptiPlex 330 Desktop Desktop Computer  Logo
Alun Cox
