Question about Raypak 130,000 BTU Propane Gas Pool H...
I need the wiring diagram to wire up from heater to mains supply
  • ruro0302 May 11, 2010
    What kind of heater is it?
  • 62 Answers
You should not be doing that one yourself, unless you are a LICENSED electrician.
There are VERY important safety issues here, or is the intent to electrocute yourself or others?
Posted on Apr 18, 2009
Need wiring diagram for Delonghi MG15EW heater
DeLonghi may be able to supply a wiring diagram if you inquire directly.
Dec 05, 2014 | DeLonghi Heating & Cooling
Wiring diagram for circuit breaker IEC 61009-1 to main supply
Copy following link:
http://waterheatertimer.org/See-inside-main-breaker-box.html
Illustrations include 120Volt single-phase, and split-phase 240Volt..
Mains supply is only split-phase 230volt.
Nov 21, 2012 | Electrical Supplies
I need the diagram
You want wiring diagram? With recommended wire size?
This particular water heater has a factory-pigtail, and is direct-wired into octogon box, and appears to be 240Volt 6500 watts. Connect water heater to 40 amp breaker and 8 gauge wire.
Here is illustration:
http://waterheatertimer.org/images/Main-subpanel-Tankless-4a-8.jpg
Look at nameplate on device for amp and wattage rating to confirm exact power requirement.
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
Oct 14, 2012 | American Heat ADK-3 - Electric 6.4KW...
Xerox 4150 workcenter says fuser module needs to warm up. This appears usually first thing in morning. I have to power off then on to stop this from showing on the screen. also, it wont print until after I...
1. Switch off the machine, then switch on the machine.
2. Enter dC330 code 10-100 to heat the fuser to 180 degrees. Enter codes 10-200 (centre
thermistor) and 10-210 (front thermistor) to verify the condition of the thermistors.
3. Enter code 10-300 to check power supply unit 2. If necessary, install a new power supply
unit 2, PL 1.10 Item 4.
4. Switch off the machine. Remove the fuser assembly. Check that the thermistors, PL 10.25
Item 9 are clean and in good contact with the fuser heat roller. Check the wiring to the
thermistors. Install new components as necessary, PL 10.25.
5. Check for continuity between the two pins on the fuser assembly connector, PL 10.25
Item 8.
NOTE: A cold fuser has a resistance of approximately 11.5 ohms (220V/240V) or 2 ohms
(110V).
6. Check that there is continuity through the fuser heater and across the over temperature
cut-out.
7. Check the wiring between the fuser connector, PL 4.15 Item 20 and CON3, CON8 and
CON9 on Power Supply Unit 2. If necessary, install a new fuser connector, PL 4.15 Item
20.
8. Check the wiring between CON4 on Power Supply Unit 2 and CN7 on the Main PWB.
9. Install new components as necessary:
• Fuser assembly, PL 10.25 Item 1.
• HVPS, PL 1.10 Item 2.
10. Perform the OF5 Main PWB Check RAP.
4250/4260 Checkout
NOTE: The main PWB has test points. The location of the test points is shown on the Main
PWB PJ location illustration.
Refer to Wiring Diagram 17, Wiring Diagram 18 and Wiring Diagram 21. Perform the following:
unit 2, PL 1.15 Item 4.
4. Switch off the machine. Remove the fuser assembly. Check that the thermistors, PL 10.28
thermistor assembly. Check the wiring to the NC thermistor, PL 10.28 Item 19. Install new
components as necessary, PL 10.28.
5. Check for continuity between the three pins on the fuser assembly connector, PL 10.28
Item 8.
(110V).
6. Check that there is continuity through the fuser heat lamps and across the over temperature
cut-out. Install new components as necessary, PL 10.28.
7. Check the wiring between the fuser connector, PL 4.15 Item 20 and CN5 on the Main
PWB. If necessary, install a new fuser connector, PL 4.15 Item 20.
8. Check the wiring between CON1 on Power Supply Unit 2 and CN7 on the Main PWB.
• Fuser assembly, PL 10.28 Item 1.
• Power supply unit 2, PL 1.15 Item 4.
May 10, 2012 | Xerox WorkCenter 4150 Black and White...
Bought a Fahrenheat 5' baseboard heater and a single pole thermostat to replace an old heater. What's the difference between a single and double pole thermostat? Which should I use? I have a 240v line...
Here is a link to the wiring instructions, which has detailed pictures and instructions. This should make it a lot easier. http://www.marleymep.com/en/multimedia-library/pdf/fahrenheat-pdf/products/f2500-series/F2500wiring.pdf
Feb 14, 2011 | Fahrenheat F2545 Electric Baseboard Heater
Heater isnt wired up but flame part works
It sounds as though you are going to have to trace through your unit's components and wire it without a wiring diagram specific for your fireplace.
Here is a Installation & Troubleshooting Guide for another electric fireplace that includes a wiring diagram. Perhaps this will help? Check it out and request additional help if you have any questions.
Without being there onsite with toolbox in hand, I hope this information is very helpful to you moving forward. :-)
Mar 28, 2010 | Heating & Cooling
I need a wiring diagram for st7100
if you contact me via my company website, I can send you the manual and wiring diagram for your thermostat/timer.
www.emshvac.com
My contact info is listed on the main page.
Richard
Oct 31, 2009 | Honeywell Electronic Programmable...
Need replacement part # and wiring diagram for Nordyne Intertherm E1EH O12HA sequencer
take it to a hvac supply house and they will match it up for you. The wiring diagram will be on the furnace
Oct 30, 2009 | Heating & Cooling
Can you give me wiring diagram for honeywell thermostat RTH6300B1005-0825
http://customer.honeywell.com/TechLit/pdf/69-0000s/69-1717.pdf that is the best I can give, as wiring is dependent on the type of equipment that you are controlling with the thermostat. Be sure to cut your power supply off before you start or you'll need a new transformer and a wiring diagram for your furnace too.
Oct 25, 2009 | Honeywell Electronic Programmable...
Hooking up the thermostat
Thermostats are typically low voltage only no more than 24volts that is supplied from the transformer in your heating unit. you need to look at your low voltage wiring that is in the furnace and write down the terminals that are hooked up. Usually (this is a very typical set up) red wire goes to R which supplies 24 volts. green goes to G powers fan motor, white to W terminal and blue or yellow goes to Y terminal this terminal will usually have another wire in its terminal with it to control an outdoor ac unit likely another red or white wire, and lastly the C terminal has a white wire. That is for a basic heating and cooling system just match how they are hooked up at the main unit to the terminals on your thermostat. the thermostat is just a switch breaking and connecting terminals that allow voltage to carry through it. Shut down your unit while working on it as not to blow the transformer otherwise you are gonna need to replace it to if it isnt fused, that is probably my most common repair from people who have tried to change their own thermostat. Hope this helps
Sep 20, 2009 | Fahrenheat Electric Hydronic Baseboard...
Raypak 130,000 BTU    Propane Gas Pool H... Logo
738 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
