Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA 52 is los the configuration after a blackout.
First Do not turn on, then I Press the up channel key and turn on, you can still turn it off with the power button but need to configure the channels again. Then the menu comes out with out pressing any key and start changing very fast from menu to menu and setting . I hit menu and goes way for a wile then it come back a do it again. If you try to used the volume and channel on the tv panel the menu come out.
  • 147 Answers
One or more of the buttons on the front of the set is bad. Best thing is to take the front panel off. About eight TORX T-20 screws from the back to get the speaker grille and panel off, then three more on the front and the whole panel with the button assembly will come off. Simplest fix is to just pull the plug off and disconnect the button assembly. the remote will still work.
Posted on Apr 25, 2009
My rca model#r52wm24 has double image yellow and blue
por lo general ese modelo es un tv de proyeccion . y ese problema se debe a que le esta fallando uno de los cañones ya que son tres cañones de pantallan los que trabajan para dar los colores exactos . asi que al fallar un cañon da este tipo de defectos atentamente : roro8228@hotmail.com
Mar 29, 2011 | RCA R52WM24 52" HDTV Projection Television
Estoy en mexico, pero ya habia usado la tv sin problemas, solo que ahora no se ven los canales del cable (la señal de cable no tiene consola como en USA). la tele trae configuracion para USA y ALASKA,...
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Apr 06, 2017 | RCA 27V550T 27" TV
Hello my mother's rca tv is stuck on channel 91. when i turn it on and use the channel keys on the set, they don't change the channel. i'm trying to get it on channel 3 so she can watch her cable.
Press Setup until you see AutoProgram... press Volume ... you will see the channels start to change. It will cycle to ch 62 or so, then go back and do the lower channels. as soon as it hits 3, quickly press Setup. it will stay on ch3, if not do it again. Once you get it on ch3, press setup until you see Channel Add/Del ... press Volume to add it. Press setup until screen is cleared. Ch /- should now toggle between 3(cable) and 91(a/v in)
May 17, 2010 | RCA Televison & Video
My tv turns on everyday to channel 52 at 7pm and I've never programmed it to do that. Why?
Press menu and look in time sub menu. This TV has an on timer available. Try to turn it off in menu.
Apr 18, 2010 | RCA TruFlat 27F520T 27" TV
My rca 60 inch keeps shuting off and switching channels
Remove the remote(or take out the batteries)from the room to be sure it's not sending out signals. If that dosn't work the problem is likely that the buttons on the front key pad are sending out signals -the front key pad board can be unplugged and you can still use the remote. let me know if you have further questions
Sep 22, 2009 | RCA P52926 52" Rear Projection Television
Hd channels not showing
Your tv has a input named COMPONENT to make work this input you need three RCA conectors (RED GREEN BLUE) plus two audio RCA Conectors red and white. If you have another set that can be plug in in this input and that set (dvd recorder, in ex.) has a digital tuner then you got it, But the Magic about the decoder box is that only cost 40.00 +- dllrs and send the signal to your antenna connector or RCA analog conector. Good luck!
Mar 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
TV Changes Channels on its own
On the front panel board power/ch-/ch+ vol-/vol+ replace contact switches replace all of them.For some odd reasons these contact switches just keep going out they had alot of them bad.
Feb 16, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Black square hiding picture on rca television need to get rid
You have the closed captioning in the TEXT mode. Turn the closed captioning off and it will go away.
RCA HDTV 52 inch television
If a DVD and the onscreen menu looks sharp and problem free, I would say it's the cable box. Since you only reset it, I doubt it has anything to do with the cables unless you removed them and didn't insert them properly or tight enough. Try a power drain on the cable box:
1. Unplug the product's power cable so that the device is not grounded to the house. Do not simply turn off the power-bar if one is in use.
2. Press and hold in the products power button for 1 minute to release the retained electricity from the capacitors and circuit board.
3. Plug the product back into the wall outlet rather than a power-bar to rule it out of contributing to the problem and turn the device back on. This will also reset the cable box again, but draining the power can do wonders.
Oct 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
77 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
