Question about Goodmans Televison & Video
Goodmans ld3755hd tv - hdmi setup
I woudl like to connect my tv to tiscali+ box with hdmi lead - can this be done and how should i go about it? i have lead plugged in but cant get a picture
Shuttle83
  • 1139 Answers
SOURCE: HDMI Signal gone
The HDMI interface may have suffered a malfunction, this offten happens due to stray voltages on the ground plane. If you do not have electronics experience I would suggest taking the set to the shop and having it repaired
Posted on Sep 24, 2007
shawnlover01
  • 12 Answers
SOURCE: I'm trying to connect my Wi i with my goodmans tv/dvd
it can't becoz it is not the desired model
Posted on Oct 22, 2007
SOURCE: no sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Posted on Jul 04, 2008
bernardlunda
  • 318 Answers
SOURCE: JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Posted on Apr 30, 2009
  • 105 Answers
SOURCE: JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Posted on May 06, 2009
Why is there not an option for my hdmi on my good mans TV ld3755hd
Because it doesn't have a HDMI port is my only suggestion.
Feb 15, 2017 | Televison & Video
Hi. We are trying to setup a phillips tv through a bt vision box please
  1. A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
  2. SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
  3. Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
  4. The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
Jun 02, 2016 | Philips Phillips - 40" Class - Led - 1080p...
I have a goodmans TV is having issues, sky box works fine through the hdmi but, ps3 no display or sound through the same port, my ps4 gets pic but no sound, both consoles have been tested on other tvs
1.Put your PS3 on standby.
2. Unplug the power lead.
3. Connect HDMI cable to HDMI out on PS3 and HDMI in on TV
4. Connect PS3 so that the red standby light is showing
5. Hold down the On/Off button until you hear a second beep. The PS3 will try and detect the display output settings on your monitor.
Dec 02, 2015 | PS4 Video Game Consoles & Games
Is there a step by step process to connecting my panasonic plasma hd tv to my dishnetwork cablebox?
hi does your cable box have hdmi ports if so connect hdmi lead from cable box to to tv hdmi 1, if your tv doesn't have hdmi then connect scart lead from cable box to scart 1 on the tv hope it helps
regards
shaun
Jan 31, 2014 | Televison & Video
I want to hook up a blue ray dvd player they told me to m=buy HDMI cable and this only goes to the tv, but doesn't have to go hooked up through the cable box
If you want to connect your blu-ray player to your tv, use the HDMI cable.
If you want to connect your cable box to your tv, I'd use component cables or get another HDMI cable.
You're right, you don't have to use your cable box to use your blu-ray player.
Mar 10, 2011 | Insignia 50 in. Flat-Panel Plasma HDTV
I have setup a goodmans freeview box model No GDB12X1T to a tv with a scart connection as the setup leaflet shows.The box pulled in a lot of extra channels,but the signal strength on the first time...
hi make sure the scart lead is a tight a fitting also make sure the aerial lead is not to long as you will loose signal strength , thanks
shaun
Jun 15, 2017 | Televison & Video
My Samsung TV picture is supplied via a HDMI lead
yes you need to connect audio out from the tv to audio in on the dvd surround. you need the red/white phono to phono leads, simply connect together and select audio (av,au) on the input selection.
Feb 20, 2010 | Samsung LN46A650 46 in. LCD HDTV
Problem with tv sender
Hi,i learned on another forum that if you connect an hdmi cable apparently it disables the functions of the scart sockets,especially where the remote control is concerned.This is something to do with virgin media's setup and not any equipment fault.If you want to go back to two room viewing try unplugging the hdmi lead.
Jun 22, 2009 | Philips Televison & Video
Oct 17, 2007 | Nintendo Wii Console
Televison & Video Logo
60 people viewed this question
Top Goodmans Televison & Video Experts
Steven Wander
Steven Wander
Henry  Thomas
Henry Thomas
Jonathon summesfield
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
