Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Kenmore Side by Side 53234300
I have the same problem. How do I get it fixed or should I buy a new refrigerator? Light wt get cold.
  • lhershey14 Apr 18, 2009
    How do I know if the compressor is working?
  • lhershey14 Apr 19, 2009
    If it is a bad compressor switch what should that cost me in labor and parts? Is it worth fixing?
  • 11,896 Answers
Part of the relay switch can become so overheated that it fuses to the compressor terminals.
Pull the refrigerator away from the wall so you can remove the lower back cover.
Unplug your refrigerator first!
Once you have the back cover removed you will be able to see the compressor.
The start relay will be located on the side of the compressor. The start relay shown on this side by
side whirlpool refrigerator is white and has a white and red wire going to it.
Remove the old start relay by pulling it off by hand. If it does not pull of by hand easily you may
have to put the tip of a flat blade screw driver between the start relay and the body of the
compressor to help pry it off. Most of the time you can remove them without any force.
Shake the relay, if it rattles, then its definitely bad.
LESS THAN $ 500 TO FIX!!!!!!! WITH COMPRESSOR, EVEN CHEAPER IF IT'S JUST A RELAY
Posted on Apr 20, 2009
  • Nate Stansfield
    Nate Stansfield Apr 20, 2009
    The sound you here every minute or so is probably the compressor trying
    to start. If it won't start and you have installed a new relay, then
    the compressor has problems. In some cases a special start relay called
    a "Hard Start" relay can get some compressors started. However, there
    is no guarrantee. If the compressor is bad, it is, in most cases, not
    worth replacing.
  • Kenmore Master
  • 19,396 Answers
If the refrigerator is not cooling at all , start ensuring that thermostat settings are ok, and that door gasket is insulating.
Possible faults that can cause same problem concern the thermostat/timer , the overload, relay, or capacitor, the defrost timer.
Try to understand if the compressor is kicking in. If the compressor is working all the time, but there is no cooling , then problem is the compressor. If the problem is the compressor, that is under warranty for three years, in that case call the phone number listed on the owners manual to have it replaced.
If the fridge is over three years old, then replacing the compressor may be expensive.
If the compressor is not even starting, then problem is the thermostat/timer , the overload relay or capacitor, the defrost timer.
In that case the part is not expensive, and the repair can be done in about one hour by a technician, providing that he already knows what is wrong and has the part.
See Kenmore
Side by Side
Appliance Parts From PartSelect
Posted on Apr 18, 2009
  • Ginko
    Ginko Apr 18, 2009
    The compressor is located at the bottom side at the back of the fridge, you know that is working because you hear the motor kicking in and running. If it is running all the time and there is no cooling, then you have a bad compressor. If it is clicking but does not start, then it is a bad compressor switch solenoid, or capacitor, this are tested using a multimeter.
    If the compressor kicks in only sporadically, then it is a thermostat, defrost system or control pcb problem.
Refrigerator noisy and runs almost constantly
If the noise is coming from the back it could be the Fan or the compressor_ is the unit keeping the food cold enough? If not could be a bad compressor with low refrigerant or bad internal pistons-either way costly to repair- maybe be cheaper to buy a new fridge_ how old is it and is it under warranty?
Oct 25, 2016 | Kenmore Refrigerators
I have a kenmore elite coldspot side by side refridgerator and it is not cold enough on the fridge side. How can i fix this?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 08, 2011 | Kenmore 56983 Side by Side Refrigerator
Fridge not cold
The overload/relay is probably burnt out . This is the piece which plugs onto the compressor , with 2 or 3 wires going to it . It is easily replaceable , and not near as expensive as a new refrig .
Oct 02, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side model#59652679201 freezer not working
Dear tlmassey -- did you get this problem fixed? I seem to be having the same issue.
Thanks,
Ahoward
Apr 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer in my kenmore refrigerator isn't cold
Make sure the freezer fan motor is running. The wires may have come off when it fell.
Mar 08, 2009 | Kenmore Refrigerators
Refrigerator light doesn't work
then tyr and replace the door switch on the refrigerator side. they are relatively inexspensive to buy and are real easy to replace.
Feb 01, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Noise from top inside near temp control nob
There is a fan close to where the cold air comes in,Its running dry and thats the noise you here.
oiling the fan motor can help other wize you shoud replace the fan...
Good luck.
Sep 09, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Light bulb
Sounds like you got a defective bulb. Make sure it is for 120 volts or thereabouts....not 6 or 12.
Jun 19, 2008 | Kenmore 22.0 cu. ft. Side-By-Side...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
