Question about Midisoft Play Piano 2.0 Full Version for PC
I want to plug my keyboard into my USB port
I have a midisoft play piano program. It is suppose to plug into the joystick port in the back of the computer. My computer only has USB ports. I have the midi to USB cable but the program does not recognize it.
Is there something I can do to get it to work?
  • 3 Answers
I just found the same program with the same cables. I am going to try a usb to midi cable made by m-audio only because I have it hooked up right now to laptop running xp and the old version of Mircacle Piano which is the best by far and it works great. It is an M-Audio usb to midi cable called the UNO or something like that. its the one for 39 bucks very simple. It should work as long as your computer is running windows OS thats compatable or try running in 95 mode. Also some of these programs recognize processor speed and dont work on the newer systems. Good luck with it. have you ever used seen this software before? Ever see Miracle Piano? wondering how they compare.
Posted on Sep 18, 2012
How can I send recordings to my laptop? I have a usb connector and i want to connect my portable grand to my laptop but the laptop does not detect the piano and i don't know what to press on the piano...
Hi mjaynneb,
I could be wrong here but I have a number of keyboards and the USB connection is usually for Midi control from software like Cubase and the like. If by recording you mean recording Audio then I think you'll find that it won't be possible using the USB port.
Midi is great and I use it a lot. It enables you to arrange music using your computer. Also you can record the music you play on the Keyboard on the computer as Midi. This means that the computer can play back through your arranger what you just played. Bear in mind though that Midi is purely numbers that represent notes, velocities and note duration so is not actually audio.
My keyboards have the ability to record to SD card or a Hard Drive, however if this is not a feature of your arranger then probably your best bet for recording audio from it is by using the Audio out ports of your arranger and using a connecting lead to a good low noise sound card on your computer. As you are using a laptop you can find external usb sound cards/interfaces so that should do fine. Then you could probably use something like Audacity which is free software, to record to a wav file.
I hope this helped.
Kind Regards
mparkyn
Jul 27, 2011 | Yamaha DGX 640 Keyboard Arranger
I have an older, much older!, Midisoft Play Piano 2.0 software CD. It says it is for Windows 95 or Windows 3.1. I would very much like to get back to learning the piano, but now have Windows 7. Will it...
Hey there,
I don't know if there's an upgrade available, but I really doubt you'll be able to run the program under Win7. The easiest way (and it's still not easy) to run older (win 95/98) programs under XP or windows 7, is to install microsoft virtual pc:
http://www.microsoft.com/windows/virtual-pc/
This will let you install an older version of windows under your current operating system. Its the easiest way i've found of being able to play older games/run older programs.
If this seems like too much of a chore, look for freeware versions of similar programs that will run under Win7. Here's just a few:
http://download.cnet.com/Piano-FX-Studio/3000-2133_4-10394113.html
http://mustech.net/2007/06/12/midipiano-freeware-midi-piano-player-synth-and-more
http://www.pianoeletronico.com.br/index-en.html
Good Hunting
Mar 16, 2011 | Computers & Internet
How install joystick play 2 in pc with usb adapter
From what I gather, your asking how to install the joystick into the usb port? ok install your software first. Then install the usb plug with joystick. it may or may not locate the device right away if not then restart your computer it should find the new device at this point
Dec 11, 2009 | Computers & Internet
Broken usb port piano
If you can take it into a shop it will be about 35 and if it involves a house call at least 75
Jul 11, 2009 | M-Audio US85100 Keyboard
The piano wizard software won't recognize keyboard
you should go to your  utilities --> audio midi setup and make sure your system is recognising your midi device. Play around with your midi settings, see if you can get something going.
Otherwise the problem maybe with the software clashing with Leopard. Double check on the manufactures website that their software is compatible with 10.5.6, or they may have an update for you.
Thirdly you could check if you keyboard is working correctly by opening garage band and making a new software instrument track, press record and see if you get any thing.
Good Luck hope this helps.
Mar 22, 2009 | Wizard Publishing Piano Wizard PREMIER...
Saitek AV8R-01 Joystick - How to install?
No download disk is required. Your PC will automatically 'find' the joystick after it has been plugged into a USB port.
You can just about play any flight sim with this joystick, jat, prop plane or helicopter. The buttons do what ever you program them to do through your game's control settings.
Mar 19, 2009 | Saitek Aviator AV8R Joystick
Midi vs. Sound
Think of MIDI like the old time player pianos where you put a roll into it and the punches on the paper roll told the piano what notes to play. MIDI is a way for computers and musical instruments to communicate what is being played. When you plug your keyboard into your computer and enable it in Cakewalk, then Cakewalk records what notes you are playing on your keyboard (makes a piano roll file). Then when you tell Cakewalk to play this file back it communicates to your keyboard and says play these notes just like a person was sitting there playing these notes. The distinction here is you are recording and playing back your performance (which keys you pressed, how hard you struck the keys, how long you held the keys for sustain, etc...). No sound is actually being recorded, just the PERFORMANCE. When you play it back, the keyboard regenerates the sounds on the fly just as if you were actually sitting there performing the music again. Same thing applies to other MIDI enabled instruments (drums, guitar, saxaphone, etc...). This opens up all kinds of possibilities, you can redirect the recorded MIDI file to a completely different sound or instrument. Example... you record MIDI of you playing piano song, then you have Cakewalk play this MIDI back to your keyboard but you change the sound on your keyboard to guitar, it will play the same song, but now you will hear guitar instead of piano. Get it?
Feb 02, 2009 | Cakewalk Music Creator 2 for PC
Recording on my Yamaha CP33 keyboard using USB
We're talking about audio recording. If so you must conntect your piano by using the L + R outputs with your sound card or mixer line inputs (that's how I do this). USB is ok if you want to use your piano as a master keyboard (MIDI). Another important thing is that you must have an additional application installed called sequencer ( for example Cubase Sx, Sonar...) which will let you store your digital music. I'm not talking about the proper settings of them because it could take a day or so...:)
Overall, you will have to learn a bit about the home studio, home recording techniques. There are tons of informations on web. A great thing is that you can use your CP33 as a master keyboard to control additional virtual instruments (VST) or for example play different piano samples (check Synthogy Ivory). Possibilites are endless!
Regards
Radek
May 24, 2008 | Yamaha Full-Size Keyboard
Suncom Technologies F-15E Talon
i will buy both stick and throttle off of you..."if" the price is right. ;-)
Beowolff29(at symbol here to throw off spam bots)hotmail.com
anyway...this is old technology stuff...as it is non-USB and windows xp and other new windows don't like Suncom stuff too much. but it can be done. attach the Talon stick to the throttle via it's two plug in ends. you'll see how they plug into the back of the throttle. once that's done, attach a NON-USB keyboard (to make the stick and throttle programmable) into the back of the throttle via the backside of one of the plugs from the stick that you plugged in earlier.
go to Radio Shack or elsewhere and buy a Belkin or whatever "joystick port to USB converter" unit. the salesman should know exactly what it is. cheap...maybe 8 to 10 bucks. also while you are there, buy a big keyboard end to little keyboard end (not USB) end converter adaptor. maybe four of five bucks for this. it converts the really old (BIG) keyboard ends to the more 'normal' (SMALLER) keyboard ends that are usually on the back of your computer. okay, almost done.
plug the USB converter into the big joystick port plug that is attached to the split line that is coming out of the back of your throttle, it's only go on one way so should be easy to do. attach the 'now' USB converted plug end into a USB port on your computer. the "OTHER" end of the split 'throttle' cable end will have that BIG keyboard end on it...plug the BIG to LITTLE adaptor that you bought into that...and simply plug it into the back of your computer where a standard keyboard plugs in.
viola! you are done with that. you may have to monkey around with the switch on the USB adaptor to get the thing working right. it has several settings on the slider switch for different things. try one till you get the one that works best.
go into window's control panel and pull up your GAME CONTROLLERS program. it should now show USB ADAPTOR CONNECTED in the joystick window. configure as per usual and test. there may be some jerky stuff while configuring but keep trying till you get it like you want it. that's it. go in game and TRY it out. some adjustments (trial an error) may be needed, but it should now show up in game and with the keyboard attached, all buttons on both throttle and stick should now be programmable and useable.
not perfect, but it will work fairly well. remember, this is old technology and it is hard to get and keep it tuned into the newer working systems. you may occasionally lose your stick, and have to RE-CONFIGURE all over again. a small price to pay for a WONDERFUL, REALISTIC fighter stick! u can email me if you get into a jam.
Oct 22, 2007 | Suncom Technologies F-15E Talon...
Midisoft Play Piano 2.0 Full Version for PC Logo
1,585 people viewed this question
Top Midisoft Computers & Internet Experts
David Payne
David Payne
Are you a Midisoft Computer and Internet Expert? Answer questions, earn points and help others
