Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Dispenser out of alignment
I removed the dispensing unit on my Saeco Italia to clean it. After replacing it, it is now "out of alignment". Something is open on the left side of it, blocking the grounds tray and I cannot reset it to it's correct position. This happened once before years ago. Someone in tech supprt had me move something to realign the little arrows in the front of the machine. As I recall, it took about five seconds to fix the problem. I cannot remember what they had me do but it is now Saturday and tech suppoert is closed until Monday. Can anyone help me with this?
  • 1,089 Answers
HiTo return the brew group to the centered position, you first need to drop the funnel. To do this look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. Push the "Press"button and the shark fin moves up and down. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not just push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and insert the brew group.
Posted on May 31, 2009
"grinder blocked"
You can try th clean the grinder following the instructions here below
http://www.fixya.com/support/r5572092-saeco_italia_automatic_espresso_coffee
Good luck and thanks for your vode
May 08, 2010 | Starbucks Saeco Italia Digital Barista...
No water through the dispenser
http://www.starbucks.com/customer/faq_qanda.asp?name=brewequip
try this link if it cant help u fix the problem it can direct u to someone who can
Nov 30, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco Italia Sup021 YR flashing red malfunction light
I found a link in the forum where there are some informations.
http://cerinicoffee.com/Saeco_technical_documents.asp
Hope this will help you.
/Mirran
Aug 22, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco magic deluxe - no water flow
How old is your machine?
Do you descale it regulary?
I think it´s your boiler that has to be replaced
Aug 05, 2008 | Saeco Magic De Luxe Espresso Machine
Cannot properly align Saeco Italia Coffee Dispenser
new to you what make that turn is 2 plastic gear inside maybe gear are loose and jump maybe that why it doent aling to check that out you need to open like everything a big job but if you whant a saeco coffee and belive me it worth it cheers
Jan 22, 2008 | Coffee Makers & Espresso Machines
Saeco itallia malfunctions
Check this document out to make sure the gear is in the right location. The machine in the document is a different type however the way the gear lines up is the same.
www.cerinicoffee.com/custompages/Tech/Brew_Group_Removal.pdf
www.CeriniCoffee.com
Saeco Parts and information
Nov 17, 2007 | Starbucks Saeco Italia Digital Barista...
Coffee Dispenser won't snap back into unit
If you're talking about the double dispenser on the left side of the unit, then you need to push the button on the top of it while you're putting it back. I put it back with the screw holes toward the machine so the smooth side is toward the viewable front.
Nov 04, 2007 | Starbucks Saeco Italia Digital Barista...
Dispenses very little coffee / steam
Just program the button by holding it down until the coffee is dispensed and then let go when it is at the length you want it to be.
Johnny C
Oct 17, 2007 | Starbucks Saeco Italia Digital Barista...
Water leaking from coffee dispenser
Hei dory may be this can be helpful.Inside the machine take out the brewing group on the back panel there is asmall metal piston with 2 small orange rubber o ring.Try to replace that(is not easy since the position)were the o ring are locate is very unconfortable but is something i believe you can do it.That one is the main connector between the inside and the conjunction with your brewing group.
Good Luck
Sep 09, 2007 | Saeco Incanto Classic Espresso Machine
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
168 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
