2002 BMW M3 Logo
Posted on Apr 18, 2009
BMW M3 E46 Stereo whine
When the stereo is on, on all inputs (radio/CD) there is a loud whine. Coming from unit so leads to me thing there is a short or something? It increases as the volume is increased.
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on May 29, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
5422
Points
17
What you are hearing is ground loop interference. If you have an aftermarket headunit/amplifier this is a common occurrence. A ground loop isolator in line with the low level amplifier inputs should solve the problem. Otherwise, it may be a malfunction of the stock cd unit or amplifier. BMW used a balanced input on some of the stock amplifiers, which would make ground loop interference all but impossible.
2003 bmw sunroof installation
BMW Sunroof Repair.wmv - YouTube
? 10:23
https://www.youtube.com/watch?v=TATFSv8CIsI
Jul 25, 2010 - Uploaded by 325xitgrocgetter
Repairing the Sunroof Shade on a 2003 BMW 325 xiT E46. Thisrepair will apply to all E46 models from ...
E46 3-Series BMW DIY Sunroof Repair - Up
www.lincomatic.com/e46sunroof/e46sunroof.html
One night, while driving my 2000 E46 3-Series BMW 323i, I tried to open my sunroof, and heard an omnious loud crunch; it sounded as if my sunroof had ...
E46 Sunroof ' eBay
www.ebay.com/bhp/e46-sunroof
eBay
Sunroof won't slide back, anyone know whatsup? - Bimmerfest - BMW ...
www.bimmerfest.com > ... > 3 Series / 4 Series > E46 (1999 - 2006)
May 25, 2013 - 15 posts - ‎8 authors
E46 (1999 - 2006) ... Mein Auto: 2003 BMW 325i ... about a week ago the sunroof quit sliding back, it tilts up even if i push the button back. DIY: BMW E39 Sunroof Repair (Video Tutorial)
Nov 22, 2013
Sunroof won't close completely, expensive fix?
Sep 26, 2010
Sunroof Shade Clip DIY
Dec 28, 2005
Retrofit sunroof on E46 M3, is it wise?
Mar 21, 2005
More results from www.bimmerfest.com
BMW e4 M3 P0012
there is a special procedure that needs to be done with the DIS machine see BMW for initializing the vanos units
My radio stopped working on my e46
Just reset the power and programming to it to fix the issue. Remove the red lead from your battery then reinstall it a few seconds later. You will notice that the radio works again! If not, your radio fuse is blown.
Jan 22, 2011 • 2001 BMW M3
Bmw e46 m3 how to install short shifter
Here is a link to a good DY to walk you through the steps... take your time and you will have this done! 3
Sep 17, 2009 • 2006 BMW M3
I removed my stereo for my 86 bmw 325 and now i am lost with the wiring.where do i start?
How to set up radio without wiring diagram : First you need to hook up the lead and ground power wire to your radio.(the lead usually has a line all the way down it). Turn power on to the radio and switch to am/fm. Locate any lead speaker wire and connect it to front right -. Then take all ground speaker wires one by one and touch them to front right +. As soon as you hear a sound, find out which speaker it is coming from, as soon as you have identified correct speaker remove wires from right speaker and mark them carefully. Do this with the rest of speaker lead wires an speaker ground wires and you will be able to connect your stereo.
1helpful
The radio on my bmw e46 has topped working and the
did u ever find a solution? running into the exact same problem as we speak! grrr
Jun 06, 2009 • 2001 BMW M3
1helpful
Radio and cd changer for bmw m3 e36 ea88906
If you go to www.crutchfield.com they will have a menu for all upgrades to your vehicles sound system including which head units (or stereos) will fit your Bimmer.
~Stillin~
2answers
I have an early e46 with the cassette player in the front and the cd changer in the boot. Can I swap the head unit for one with a cd player in it, and do I need anything else ? Thanks
You can replace the old radio and cassette player with a new modern aftermarket dvd player gps navigation unit like this.
Car DVD BMW E46 Navigation System E46 DVD GPS Navi
It's with more features except navigation system, USB, iPod, AUX, SD, DVD player, rear view camera video input, and it's touch screen, easy operation.
1helpful
3answers
Hi, i have an m3 e46 2002 year model. my problem is a noise coming from the rear.possibly the diff when i turn left or right at slow speeds.
dont understand if it was the diff the noise would be their all the time like a whining noise sounds a bit like a wheel bearing or drive shaft or a bush bmws are prone to this hope ive helped you
Apr 01, 2009 • 2002 BMW M3
BMW E46 M3 when i put the handbrake on the tele goes off
needs to go on the bmw machine to tell the computer not to turn tv off when handbrake applied, its a safety thing .
Good luck. Davelee
Oct 06, 2008 • 2006 BMW M3
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
