Question about Kenmore 24 in. 16539 Built-in Dishwasher
I have a Kenmore dishwasher Model 16539200 that when the unit is off the spply leaks back into it. I don't see a check valve on my parts list. Is this the solonoid then?
  • 2318 Answers
SOURCE: no water in dishwasher
I would suggest to check the information by clicking here if you are planning to DIY.
Posted on May 20, 2008
MNTECH
  • 1543 Answers
SOURCE: GE Dishwasher Leaks
You can easily screw up the drain diverter arm trying to replace that seal. Repair is difficult. Pump assembly is rather expensive. (especially considering this was not a top of the line model) You would be much better off replacing the dishwasher. The new GE models are much quieter and have eliminated the center tower in almost all models.
Posted on Sep 02, 2008
rylee_smith
  • 8619 Answers
SOURCE: leaks water from under dishwasher
Hi
Thanks for using FixYa. If your dishwasher leaks, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
Lower rack
Spray arm
Spray arm support
Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Nov 03, 2009
  • 901 Answers
SOURCE: brand new kenmore dishwasher leaking out the front
Check the door gasket for uniform seating. Align it. If this does not solve the problem, contact the service provider. He may change the gasket or do the corrective action.
Posted on May 25, 2010
heatman101
  • 43501 Answers
SOURCE: Kenmore Dishwasher 363.14471790 is Leaking
You can easily replace that..
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Posted on Sep 29, 2010
To whom it may concern, I have a kenmore Elite dish washer. I have a gree light ( Clean ) flaching and it do not work when programming for washing. Can you help? What shuold I do ? Regards ! Michel S.
On the Kenmore 1312 dishwasher, the Clean light will flash with the following problems: a problem with the Overfill Protection Float, no water coming into the dishwasher, or suds/foam in the unit.
First check the float and see if it will move up and down freely. Push it down to release it. This float is at the front right of the dishwasher.
Next make sure that the water valve to the dishwasher is open and you have incoming water pressure. (If the water is blocked at the valve, the inlet valve can be replaced, if needed.)
Finally look to see if there are suds at the bottom of the washer. Check that the rinse aid compartment cover is secure. The arrow should point to Lock. Use dishwasher detergent in the correct amounts (see the package label). Using the wrong type of detergent or too much can cause the problem.
Most Kenmore appliance manuals are available from Manage My Life. Searching for your model will also give you a link to the matching parts diagram and ordering information from Sears Parts Direct. See http://www.managemylife.com/mmh/owner_manuals?intcmpMMHxG_HomexServices_Menu to search for your model. The model number is usually on the frame inside the door of the dishwasher.
I hope this helps.
I hope this helps.
Sep 08, 2011 | Kenmore Dishwashers
Dishwasher won't fill with water
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Kenmore Dishwashers
On my Kenmore Dishwasher Model 66513749K601, the door is leaking water. I'm wondering if changing the gasket will repair it or if this machine has a history of other issues.
Hi, Just change the door seal... it is very easy to do...and don't cost much at all...
Leaking Dishwasher
heatman101
Aug 14, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
I have a QuietGuard3 that is leaking water onto the floor when it runs. I've resorted to hand washing. What is the problem and how do I fix it?
There are many things that can be wrong.
1. Can be the pump
2 Can be the drain line
3 can be the water inlet / supply line.
It is hard to tell with out you pulling the bottom cover of and running the dishwasher to see where the leak is at. A little more info would be helpful to determine the exact problem.
Also Make and model # would help
Aug 02, 2011 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore dishwasher 15894 water not coming out and soap pod not opening
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly.
Daniel
May 18, 2011 | Dishwashers
My Kenmore Portable Dishwasher model number 665.17769K600 will not fill with water, I have to manually fill with water and it will then work. What could be causing this?
Hi
Hope this helps... Please post back for any further assistance.
Daniel
Mar 24, 2011 | Kenmore Dishwashers
Model 15754 Kenmore built in dishwasher leaking water into basement
take off the bottom panel ....... check for the leak .... could be the fill valve connection ..... motor pump assembly (most liklely) or a drain hose/pump issue....if the DW is noisy as well go shopping ...
Jul 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
I can not get water to go into the Dish washer
You could have a bad timer or a bad water valve. You could also have a wire off the water valve...cut the water and power supply off and remove the inlet hose from the valve. Remove the valve from the unit and check for debris in the valve this also could contribute to you not having water.
Apr 04, 2009 | Kenmore Dishwashers
Dishwasher doesn't drain fully
Some model 665 DW have a check valve that is attached between the sump and drain hose that may have a blockage..... Remove the drain hose from the long plastic valve then carefully unscrew the check valve from the sump. Inspect for debris.
Jan 03, 2008 | Kenmore 24 in. 15079 Built-in Dishwasher
Kenmore 24 in. 16539 Built-in Dishwasher Logo
194 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
