Question about Panasonic Lands Phones
When we installed our kx ta1232 our children were young so it was programed for them not to be able to make or receive phone calls.Now that they are older we want them to be able to make and receive phone calls.How do i program this feature?
  • Ynot56 Apr 26, 2009
    Carl was so helpful i could not have completed this work without his help.It is great to know people like Carl will help you without expecting anything in return.
  • Panasonic Master
  • 2,460 Answers
I think I've stepped into the Twilight Zone. Asked and answered a few days ago, but here's the long answer.
If you don't have a complete set of manuals, go here http://www.public.carl.airpost.net/TA-1232/
At the very least, you need the FEATURES manual and the PROGRAMMING manual. Since you're the only one with programming access to the 1232, you'll have to find out HOW the system was programmed. There are several ways to restrict extensions. The easiest is COS. The FEATURES manual, page 194 describes setting up Toll Restriction. The companion to that is 500-514 which describe how the phones will perform when different COS's are assigned. Program option 601 defines a station class. COS 7&8 are the most restrictive, meaning you can't dial out, and 1 is the most permissive.
Besides COS, a phone has to have lines assigned to it in order to make calls. That could be as simple as mapping the CO's to buttons, or as complex as physically assigning the lines in programming. Button programming starts with a display phone on the extension and using PROGRAM 99 and pressing the buttons to see if they are assigned. 0xx STORE saves CO's to buttons. If they are assigned, they may also be restricted. Those are the 605&606 areas I mentioned in the previous post.
That pretty much covers outgoing calls. Your toll restriction tables reside in 301-305 for restrictions and 306-310 for allow numbers in COS 2-6. Toll tables and ARS plans can take minutes or hours to design, it just depends on the complexity of the situation.
Incoming calls are probably just the ringing assignments in 603&604. Changing each extension from NoRing to Immediate will solve the incoming ring problem.
I think the TA-1232 was sold as a non-restricted DIY system :-)
It's a dumbed-down TD-1232 system. Believe it or not, there's even a DOS based programming tool that you can get. If you get desperate, you might want to contact me at carl@airpost.net for arrangements. You need a system with a serial port and a DB-25 male to whatever your serial port needs cable to program it.
Carl
Posted on Apr 18, 2009
  • Carl Navarro
    Carl Navarro Apr 27, 2009
    Thanks for the rating and BTW do you remember HOW the phones were restricted? Was it by COS 7?
CO light is not lighting with a received call
While I do not see a programming guide for the lights on the unit, here is the programming guide where you can take a look yourself.
http://www.wedophones.com/Manuals/Panasonic/KX-TD%20208%20telephone%20system%20Additional%20Features%20update%20for%20version%203.pdf
Jan 21, 2014 | Panasonic KX T7436 Corded Phone KX-T7436
Unable to receive calls on Panasonic KX T624
There is a reset code for each handset which I believe is 790,
Jul 14, 2012 | Panasonic KX-TA1232/KX-TA624 phone
How can I get the music on hold to work on the Panasonic Advance Hybrid System KX-TA624?
On the cabinet, there is a jack marked EXT MUSIC. You plug in an audio source to the jack and then go into system programming and turn it on in program 111.
Carl
Feb 04, 2011 | Panasonic KX-TA1232/KX-TA624 phone
Display screen shows "Will return soon" Would like
You need to cancel absent message on your phone. The method depends on which Panasonic phone system your phone is connected to. Following are the methods for three different Panasonic phone systems. Once you cancel absent message, your screen should return to date and time, if not then press * until it does.
KX-TA624 Phone System
Press intercom button, dial 750#, lift handset then return handset to cradle to end.
KX-TA1232 Phone System
Press intercom button, dial 7500, lift hanset then return hansdset to cradle to end.
KX-TDA100 or KX-TDA200 Phone Systems
Press intercom button, dial *7500, lift handset then return handset to cradle to end.
Jan 27, 2011 | Panasonic KX-T7633 Corded Phone
How do I program the phone to ring on an incoming call? The ringer is on.
The solution will depend on why the phone is not ringing. Do you have a good cable? (Can you get a dial tone and make outgoing phone calls?) If you don't have a dial tone, use another phone to check if the phone is the problem or if the jack is at fault.
Next is the phone forwarding calls or in the "do not disturb" mode.
If the problem is one of the above, which model of the Main Unit do you have, KX-TA624 or KX-TA1232?
If the unit is in the "do not disturb" mode, to cancel: pick up the handset, press Program then 0 followed by # with the TA624. For the other model, press Program followed by 0 . Then hang up the handset. For this the manual says press the FWD/DND button not the Program button. I'd check both.
To cancel Forwarding, except for Follow Me Forwarding, pick up the handset, press FWD/DND and then 0 and # (TA624) or 0 (TA1232) then hang up the handset. To cancel Follow Me Forwarding: pick up the handset, press FWD/DND then 8 followed by the extension number. Then press # for the TA624 and hang up; just hang up the handset for the TA-1232.
I hope this helps.
Sep 23, 2010 | Panasonic KX-T7730 Corded Phone
How do i delete speed dials on panasonic kx-t7730
since panasonic kx-t7730 does not have a delete option
we can however replace the number to a another number or a dummy number as per the model
KX-TA624 ....PRESS 2 *
KX-TA1232...PRESS 3 0
.... TYPE DESIRED NUMBER(eg: 0000)
AND HANDUP
This would replace the existing number
tell me if this works
Feb 24, 2010 | Panasonic KX-T7730 Corded Phone
We want to transfer a call to a phone number (external party). System programming is required. Can you help me? Thanks, Gina
Panasonic KX t7730 call forwarding function to external party:
If you are using the Kx-TA624 pbx (TES 824 models) system, program your phone unit (t7730) as follows: lifet handset, press FWD/DND button, press 3, then the outside line access code, then phone number, then #, then return handset.
If you are using the kx-ta1232 (higher models) of pbx system (usually with 9 or more CO lines cabable, use the following command:
lift handset, press FWD/DND button, press 6, then the outside line access code, then telehone number, then # then return handset to cradle.
Jun 11, 2009 | Panasonic KX-T7730 Corded Phone
Panasonic KX-TA1232, Setup and use
You can purchase a manual for about 10 dollars
Email your system/phone model number to sales at aaa-avad.com for further instructions.
Mar 31, 2009 | Panasonic KX-TA1232/KX-TA624 phone
KX-T7730 programming manual
i have 10 extentions but my call ring to all extentions. but the ring to one extentions 101 only plz tell me
Aug 05, 2008 | Panasonic KX-T7730 Corded Phone
Lands Phones Logo
148 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
